ilmenit Posted February 4, 2020 Share Posted February 4, 2020 Is there a simple way to detect overflow in case of addition (ADC) of unsigned and signed value? If I read description of overflow flag it works only for both signed values. I'd like to detect overflow of unsigned value when signed one is added e.g.: unsigned $1 + signed $FE (-2) -> overflow unsigned $1 + signed $1 -> no overflow unsigned $FF + signed $1 -> overflow unsigned $FF + signed $FE (-2) -> no overflow Quote Link to comment Share on other sites More sharing options...
ivop Posted February 4, 2020 Share Posted February 4, 2020 Just to be sure, you want [0...255] adc [-128...127] and detect what exactly? I assume you mean the answer should be in the range of [0...255] and how to detect when it's not? Quote Link to comment Share on other sites More sharing options...
Rybags Posted February 4, 2020 Share Posted February 4, 2020 Note the 6502 maths instructions have no distinction between siqned/unsigned, the flags are just there to help. Also note that behaviours can be different if you're using decimal (SED) mode. The carry bit is set if you ADC and an unsigned # goes beyond $FF The carry bit is clear if you SBC and an unsigned # goes below $00 From memory, the overflow bit is set if the sign (bit 7) changes in either operation. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted February 4, 2020 Share Posted February 4, 2020 Consider: A = unsigned, B = signed if (A >= 129) and (B is +ve) then for A + B, 'C'arry indicates overflow if (A >= 129) and (B is -ve) then for A + B, there cannot be an overflow if (A < 129) and (B is +ve) then for A + B, there cannot be an overflow if (A < 129) and (B is -ve) then for A + B, 'C'arry indicates overflow So because the test on A is not a nice BPL/BMI a CMP #129/BC[CS] would have to be employed so might be be so efficient. Quote Link to comment Share on other sites More sharing options...
ilmenit Posted February 5, 2020 Author Share Posted February 5, 2020 (edited) I know that according to ADC specification added values need to be of the same type, but I was wondering if there is some trick that could be used to identify such case and treat one as unsigned and other signed. The situation can be identified and handled with conditional jumps, but maybe there is some faster way (preset flags?). To explain the use case - I have a page and unsigned byte Index for accessing its data. I move the index forward or backward by adding signed Step value. I need to identify case where Index is "virtually" wrapping or crossing byte boundary, therefore e.g. if Index is $F1 and I add $FF, by 6502 it's overflow, however I consider here $FF as -1 and output value of Index is $F0, therefore for my use-case there is no "wrapping". I'm going through such page in a loop and need to break the loop at the moment when Index moving forward or backward by Step is crossing page boundary. Where it's needed - e.g. raycaster where I move a ray by step on "upscalled grid" to 256*256 resolution (for calc precision), where I need to detect if a ray is crossing 256*256 boundary. Edited February 5, 2020 by ilmenit Quote Link to comment Share on other sites More sharing options...
phaeron Posted February 5, 2020 Share Posted February 5, 2020 Rebiasing the unsigned value to signed might work: LDA unsigned_value EOR #$80 ADC signed_value EOR #$80 BVS overflow It's a trick I occasionally use in vectorized code since SSE2 is annoying non-orthogonal for byte ops. 4 4 Quote Link to comment Share on other sites More sharing options...
ilmenit Posted February 5, 2020 Author Share Posted February 5, 2020 2 hours ago, phaeron said: Rebiasing the unsigned value to signed might work: LDA unsigned_value EOR #$80 ADC signed_value EOR #$80 BVS overflow It's a trick I occasionally use in vectorized code since SSE2 is annoying non-orthogonal for byte ops. Oh wow, it seems to work! Man, you are amazing! ? 1 Quote Link to comment Share on other sites More sharing options...
R0ger Posted February 5, 2020 Share Posted February 5, 2020 I've been thinking about this for hours, and it was driving me crazy .. but in the darkest hour, Phaeron comes to the rescue ! Quote Link to comment Share on other sites More sharing options...
NRV Posted February 5, 2020 Share Posted February 5, 2020 8 hours ago, ilmenit said: e.g. raycaster where I move a ray by step on "upscalled grid" to 256*256 resolution (for calc precision), where I need to detect if a ray is crossing 256*256 boundary. That's the correct "generic" way of doing it, but you also could have different logic for different "quadrants" for the ray (centered in the viewpoint position). So, for example, a ray moving in a "top-left" direction, could check X against the 0 limit and Y against the 256 limit only (assuming coordinate Y grows from "bottom" to "top"). Also, you normally trace rays from left to right ("clockwise"), so you don't change "quadrants" that often. 1 Quote Link to comment Share on other sites More sharing options...
ilmenit Posted February 5, 2020 Author Share Posted February 5, 2020 (edited) 19 minutes ago, NRV said: That's the correct "generic" way of doing it, but you also could have different logic for different "quadrants" for the ray (centered in the viewpoint position). So, for example, a ray moving in a "top-left" direction, could check X against the 0 limit and Y against the 256 limit only (assuming coordinate Y grows from "bottom" to "top"). Also, you normally trace rays from left to right ("clockwise"), so you don't change "quadrants" that often. Correct. I was considering doing different procedures for quadrants (or even octants) or use self-modified code, but in my case I have more space for precalculated data and I can store it for all the "angles", which greatly simplifies the code. Phaeron's proposal is great for some other "clipping" purposes too. Edited February 5, 2020 by ilmenit 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted February 5, 2020 Share Posted February 5, 2020 http://www.righto.com/2012/12/the-6502-overflow-flag-explained.html 2 Quote Link to comment Share on other sites More sharing options...
NRV Posted February 5, 2020 Share Posted February 5, 2020 1 hour ago, Wrathchild said: http://www.righto.com/2012/12/the-6502-overflow-flag-explained.html Nice... never used it, but always believed the common myth about it, that the overflow bit indicates a carry (or overflow) from bit 6.. x) Quote Link to comment Share on other sites More sharing options...
