tschak909 Posted February 17, 2020 Share Posted February 17, 2020 Has anyone attempted to customize an OS/A+ installation to add something other than a 180K or 360K disk? It's very much possible by modifying DRVTAB, and adjusting the DRVTAB. It is also indicated that INIT.COM needs to be modified (source code available from OSS), has anyone gotten that source code? or will I need to just disassemble it and see how/where the drive parameters are derived? I want to try and make a 16MB disk. -Thom 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 17, 2020 Author Share Posted February 17, 2020 I also find it very interesting that OS/A+ 4.1 needed a separate COPY24.COM command to move files from the Atari DOS FMS to the v4 FMS. This is strange to me, because the ADOS.COM is LITERALLY a resident CIO driver that implements the A: device, which implements a full copy of the DOS 2.0 FMS. What gives? -Thom Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted February 20, 2020 Share Posted February 20, 2020 If you found a good copy, please post it. I WANT a FujiNet, BTW. Can't wait until it's perfected. :) Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 22, 2020 Author Share Posted February 22, 2020 The version that is publically posted, is a good copy. If anything it's slightly out of spec because the first three sectors are 256 bytes. I'll post a copy here that's on a 360K disk: OSA_41.atr 1 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 22, 2020 Author Share Posted February 22, 2020 I _REALLY_ like OS/A+ 4.1, and would like to figure out how we can properly document configuring different drive types, as this is only partially documented in the manual. Fun fact, there is no max directory entries limit. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 22, 2020 Author Share Posted February 22, 2020 Long filenames. The copy utility however, is ported as is from v2, and caps after 12 characters. whoops. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 27, 2020 Author Share Posted February 27, 2020 Ah, I also see why they did COPY24. The COPY command has some _REALLY_ stupid assumptions in it. A2:FOO.COM literally becomes D2:FOO.COM, which uses the wrong CIO driver. sigh. They really rushed this thing out the door. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 27, 2020 Author Share Posted February 27, 2020 Actually nevermind, something else happening. I read the trace wrong. -Thom Quote Link to comment Share on other sites More sharing options...
tschak909 Posted February 29, 2020 Author Share Posted February 29, 2020 #Atari8bit #FujiNet - The production code unifies all of the individual #Arduino tests under PLATFORM.IO. Disk, Printer, WiFi modem, with the N: device to be implemented next. See them all working, here: Quote Link to comment Share on other sites More sharing options...
drac030 Posted February 29, 2020 Share Posted February 29, 2020 (edited) Regarding the OS/A+ 4.1, I remember playing with it some time ago, and: 1) it would be better for it to keep MEMLO lower. IIRC, it was $2C00. 2) the filesystem used does not seem to allow detection of the EOF earlier than at a sector boundary. So, create a file, write 1 byte to it, close the file - and while reading it later you will get back your byte + 255 zeros before status 136 comes in. Apple DOS FS (which is used there) does not hold the file's exact length anywhere, on Apple text files always end with an EOF character, and the rest keeps the actual file's length in the header of the file itself. So the directory keeps actual type of the file: 0 for a text file, 1 for Integer BASIC, 2 for Applesoft BASIC, 4 for binary file... Not very practical thing on Atari, I would say. Edited February 29, 2020 by drac030 typo 1 Quote Link to comment Share on other sites More sharing options...
