Grevle Posted March 9, 2020 Share Posted March 9, 2020 (edited) I made my own clock on for the Atari and provide the executable and the Assembly listing. I name it the cheater clock because all it does is look at the rtclock adress 20 ($14) and advance the Counter one second up til 99 minutes and 59 Seconds. It adjust timing for PAL and NTSC machines. It seem to be fairly accurate , but not exactly real time clock.. Cheaterclock.XEX The Listing in Assembler: ; Cheater clock *=12288 ; set adress for program SDMCTL = 559 ; Can turn on and off Antic (needed when creating display list) SDLSTL = 560 ; Shadow display list pointer low - Antic må vite hvor den nye display listen er SDLSTH = 561 ; Shadow display list pointer high ; Here is some equates SECONDS = 1600 TENSEC = 1601 MINUTES = 1602 TENMIN = 1603 LDX #1 STX TENMIN ; set 1 here or the ten minute number get out of sync LDA #0 STA SDMCTL ;TURN ANTIC OFF LDA #0 ; LOW BYTE STA SDLSTL ; store low byte of display list adress LDA #144 ; HIGHBYTE STA SDLSTH ;store high byte of display list adress LDA #34 STA SDMCTL ; ... Turn on Antic again ; set some colors LDX #12 STX 710 LDX #24 STX 708 LDX #34 STX 709 LDX #58 STX 711 LDX #60 STX 712 ;put the clock on screen before it starts LDX #16 STX 40220 STX 40219 STX 40217 STX 40216 LDX #26 STX 40218 START LDX 53268 ; check for pal atari CPX #1 BEQ PAL LDX 20 CPX #60 ;check rtclock to advance time 1 second ntsc BCC START JMP NTSC PAL LDX 20 CPX #50 ; check rtclok to advance time 1 second pal BCC START NTSC LDX #0 STX 20 ;reset rtclock when wanted number is reached LDX TENSEC ;check if tenseconds is = 5 to advance minute counter CPX #5 BEQ CHTENSEC CONT LDX SECONDS CPX #10 BEQ TENSEC2 LDA SECONDS CLC ADC #16 STA 40220 INC SECONDS JMP START TENSEC2 LDA TENSEC ADC #16 STA 40219 INC TENSEC LDX #1 STX SECONDS LDX #16 STX 40220 JMP START CHTENSEC LDX SECONDS ; check if seconds = 9 to advance minute counter CPX #10 BEQ SETZ JMP CONT MINUTE2 LDA MINUTES ADC #16 STA 40217 INC MINUTES LDX #0 STX TENSEC JMP CONT SETZ LDX MINUTES CPX #9 BEQ MINUTEC CONTR LDX #1 ;reset seconds counter STX SECONDS LDX #0 ; SLOPPY CODE ADJUSTMENT STX TENSEC LDX #16 STX 40220 ; put zeroes on screen STX 40219 INC MINUTES CLC LDA MINUTES ADC #16 STA 40217 ; put minutes on screen JMP START MINUTEC LDX #16 STX 40217 INC TENMIN CLC LDA TENMIN ADC #15 STA 40216 ; put tenminutes on screen LDX #0 STX MINUTES DEC MINUTES ; decrease one for sloppy coding JMP CONTR ; The Display list for GR.0 *=36864 Mylist .Byte 112,112,112 ; three blank lines .byte 66,64,156 ; first is lms command two other is for screen adress (Adress off display list) high byte,lowbyte = low byte,highbyte = 39936 .byte 2,2,2,2,2,2,2,2,2,2,2,2 .byte 2,2,2,2,2,2,2,2,2,2,2 ; 23 times antic mode 2 lines = Basic mode 0 .byte 65,144,0 ; first is jump on vertical blank instructions,2 other is the adress low byte first. the adress for the display list itself Edited March 9, 2020 by Grevle 2 Quote Link to comment Share on other sites More sharing options...
