Stack disruption - Intybasic
cmadruga
Quick question... having a GOTO jump to a label outside a procedure creates a stack disruption error on Intybasic.
What is the best way to avoid this situation if the jump is really needed?
I tend to use variables that get flagged inside the procedure... so once I'm back to the main loop the variable will trigger the GOTO I need.
Are there better ways to deal with this? I'm sure there are. Please enlighten me.
Flag variable? Ok I guess I’m already doing that, thanks for confirming.
To Artrag’s comments, yes sometimes it is better not to use subroutines... but I have this impulse to leave the main loop as clean as possible... don’t know where that comes from, probably the way I was taught structured/procedural programming decades ago.
Edited by cmadruga
Some Structured Programmers would say GOTOs are forbidden, I rarely use them in IntyBasic but I use a lot of GOSUBs (which made me chuckle way too much while I was writing the SuperPro Gosub game )
Your "yes sometimes it is better not to use subroutines" doesn't make sense to me as it isn't the subroutines that are the issue, it is you GOTOing into one instead of GOSUBing. If your subroutine has a lot of labels that you are jumping to, then make the parts of the subroutine small PROCEDUREs and GOSUB to them, a RETURN (or END of the PROCEDURE) will clear the stack properly on exit from the PROCEDURE
I use variations of this:
WhichCritter=0
MainLoop:
	MovePlayer
	MoveCritters
	WhichCritter=WhichCritter+1:If WhichCritter>2 then WhichCritter=0
Goto MainLoop
MoveCritters: Procedure
On WhichCritter Gosub MoveSnake,MovePig,MoveBird
End
MoveSnake:Procedure
Rem Do something
End
MovePig:Procedure
Rem Do something
End
MoveBird:Procedure
Rem Do something
End
Alternate with GOTO inside the Procedure instead of Gosubs
	On WhichCritter Goto MoveSnake,MovePig,MoveBird
MoveSnake:
	rem do something
Return
MovePig:
	rem do something
Return
MoveBird:
	rem do something
Return
End
I think my comment was misunderstood.
I don't use a lot of GOTOs and I'm not generally replacing GOSUBs by them.
The type of situation I'm talking about is this... how would you trigger a new level to be restarted?
Suppose any "dead" condition should decrement LIFE immediately and restart the level.
Start_level:
CLS
<initialize variables, etc>
main_loop:
      <do a lot of stuff>
      IF (FRAME AND 3)=0 THEN GOSUB check_sprite_and_tile_collision
      <do more stuff>
      IF (FRAME AND 7)=0 THEN GOSUB check_for_other_death_situations
      <do a lot more stuff>
GOTO main_loop
Check_sprite_and_tile_collision: PROCEDURE
   <if sprite touched a particular tile: dead>
END
Check_for_other_death_situations: PROCEDURE
    <if condition: dead>
END
Edited by cmadruga
For Coleco stuff, I use while(game==1){} Then event to occur below it
if(game==2){...;} or/and while(game==2){} if I need an animation to play like death animation.
additional cases like if(game==3){if you won etc.}  So I use goto to send the pointer up to resetgame or resetlevel labels.
I probably should do the same with my Inty stuff.  I use goto and use flags if I'm using subroutines in Mad Bomer.  I used to do the same with my older Coleco project before I figured out how to use arguments properly.
Mad Bomber exempt:
gameloop1:
gosub dropbombs
if droptimer=0 then droptimer=bombrate:gosub spawnbombs
if bomberbombs=0 and game=1 then game=0:bomberpause=100
if hitflflag=1 then goto bombhitfloor
goto gameloop1
dropbombs:procedure
for i=0 to 4
if bomba(i)=1 then
if dropspeed<>0 then
if bomby(i)>100 then hitflflag=1
if bomby(i)<5 then bomby(i)=6
next i
return
end
At late development point, Mad Bomber was going to have stack overflow if I haven't noticed that I was jumping out of the lives procedure into the game over sequence.
Start_level:
CLS
main_loop:
      <do a lot of stuff>
      <do more stuff>
GOTO main_loop
END
END
I actually do something more like below
You could also use the DO WHILE PlayerDead=0 construct instead of a Main_Loop:
CartLoop:
	Gosub MainMenu
	Gosub MainGame
Goto CartLoop
MainGame:
Start_level:
CLS
Restart_Level:
	Gosub DrawLevelScreen
	PlayerDead=0
main_loop:
      <do a lot of stuff>
      <do more stuff>
If Lives<=0 then Gosub GameOverScreen:Return Rem Exits MainGame Procedure gracefully back to cartloop
If PlayerDead=1 then GOTO RestartLevel
GOTO main_loop
End Rem End of MainGame Procedures
   <if sprite touched a particular tile then PlayerDead=1:Lives=Lives-1>
END
Edited by Tarzilla
Fixed Lives <=0
CartLoop:
	Gosub MainMenu
	Gosub MainGame
Goto CartLoop
MainGame:
Start_level:
CLS
Restart_Level:
	PlayerDead=0
main_loop:
      <do a lot of stuff>
      <do more stuff>
GOTO main_loop
END
Yep, that's what I do too. Like I said on my first post:
"I tend to use variables that get flagged inside the procedure... so once I'm back to the main loop the variable will trigger the GOTO I need."
And like nanochess said:
"The easiest way is to use a flag variable."
... Which you did as well with the variable PlayerDead.
Thanks for confirming... was just trying to see if there were other ways to deal with it.  ?
Mad Bomber exempt:
gameloop1:
gosub dropbombs
goto gameloop1
dropbombs:procedure
for i=0 to 4
if bomba(i)=1 then
next i
return
end
Yep, similar to Tarzilla, you are using a flag variable ("hitflflag") to do the GOTO from the main loop versus inside the procedure ("dropbombs").
(I didn't quite get the use of "game=1" and "game=0", but probably because I would need to read a little more of your code.)
Thanks guys!
