GDMike Posted February 5, 2021 Author Share Posted February 5, 2021 (edited) Ready to load?? Almost.. Edited February 5, 2021 by GDMike Quote Link to comment Share on other sites More sharing options...
apersson850 Posted February 5, 2021 Share Posted February 5, 2021 17 hours ago, Asmusr said: Refactoring assembly code can be almost as difficult as writing it in the first instance. It helps to have good tools, but AFAIK GDMike is working retro style. It can be. Maybe I should have written "redesigning" instead. When you build an application where you have to learn along the way, you tend to end up pretty far from optimal. When you think you're ready is frequently the best time to start over, since then you know what you need to know to do it well. 4 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 5, 2021 Share Posted February 5, 2021 The legendary Fred Brooks put it this way: "In most projects, the first system built is barely usable....Hence plan to throw one away; you will, anyhow." Fred Brooks, The Mythical Man-Month I found this and some other good advice here: https://course.ccs.neu.edu/cs5500f14/Notes/Prototyping1/planToThrowOneAway.html 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 5, 2021 Author Share Posted February 5, 2021 (edited) Change made... were creating 100 files now in order to accommodate the saving of 800 SNP pages. Yeah, my math is always off when I try to guess, but when it comes down to what the program asks for, then the numbers start to get into position.. Edited February 6, 2021 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 9, 2021 Author Share Posted February 9, 2021 Removed some old - non used code today. It was stuff I was planning on doing later, but apparently I don't need. So I freed up 820 bytes. Yay 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted February 9, 2021 Share Posted February 9, 2021 Yes, I imagined that would be possible for you. Way to go. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 9, 2021 Author Share Posted February 9, 2021 I had started a little routine, when I was contemplating how to do a DSR, that kept me busy ....buttttt....I don't need it... I needed more ram for my Load/save routine.. Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 13, 2021 Author Share Posted February 13, 2021 (edited) On 2/9/2021 at 8:46 AM, apersson850 said: Yes, I imagined that would be possible for you. Way to go. Ok, I've finally got 2 full banks to save in 1 file. (I dropped the search routine to give me ram, well it wasn't fully functional because we made that routine prior to SAMs being added in..so, I can add it later maybe.. But the main thing is is I got two Banks per file and now I'm pressing on VID_20210213_123243602.mp4 Edited February 13, 2021 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 15, 2021 Author Share Posted February 15, 2021 (edited) Just taking care of some loose ends and I'll be releasing SNP with File Load/Save capabilities. Just about to wrap that up. Thank you everyone for helping me with the DSRLNK, SAMS and all in between! Edited February 15, 2021 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 15, 2021 Author Share Posted February 15, 2021 I'll do a demo and explain what is and what isn't in the program, what changes were made. Etc. I'll always keep an eye out for bugs... 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 15, 2021 Author Share Posted February 15, 2021 Will be testing for a couple days ☺️ 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 16, 2021 Author Share Posted February 16, 2021 (edited) Ok. I had a problem I was working on for two days trying to figure out why when I saved pages one through 50 in SNP, when I went back and loaded the pagees back, pages 32 through 38 were screwed up. and then things were back to normal again after page 36, so I've been fighting this trying to figure out what the heck is going on. Long story short cuz it took me two days, but it looks like when I did AI R1, >-0100 ( hex negative 0100). Is where my problem came from. After concluding that there's nothing wrong with my code in a particular routine which took me quite a while to narrow down I came upon This command and I said I'm not getting a negative number here or something's going on with this command so I changed the command to look like this AI R1, ->0100 Instead. Wow But the damn thing was working up until pages in the 30ish area... So it was kinda hard to locate. Program is fully saving and loading 800 pages now. Swhoooooo Edited February 16, 2021 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 16, 2021 Author Share Posted February 16, 2021 Supernotes to be released tommorow Featuring file SAVE/LOAD capabilities. I'll release a video explaining what works and what doesn't. The good news is. Features that worked previously, continue to work. 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 16, 2021 Share Posted February 16, 2021 1 hour ago, GDMike said: The good news is. Features that worked previously, continue to work. That's always a good thing. Made me laugh. 1 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 17, 2021 Author Share Posted February 17, 2021 Well, maybe I spoke to soon.. .I've lost my call beep, call honk and call color (), but I still have call char, I don't know why but call char is still alive..lol I'm investigating.... 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 17, 2021 Author Share Posted February 17, 2021 (edited) Ok. I'm just finishing docs and I'll upload the program with the docs. Everything that worked previously has been verified to be continued working. Except word search. It's a super day. Edited February 17, 2021 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 17, 2021 Author Share Posted February 17, 2021 (edited) The latest SNP program with file save/load options. And some help pictures SNP Edited February 17, 2021 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 17, 2021 Author Share Posted February 17, 2021 Quote Link to comment Share on other sites More sharing options...
