+TheBF Posted March 27, 2022 Share Posted March 27, 2022 56 minutes ago, Lee Stewart said: The screen timeout timer reset has little to do with interrupts. I say, “little”, because it is the console ISR that increments the timer, which is effectively reset when it rolls over to 0. It does not ever, however, explicitly reset the timer. In non-Basic environments, the screen timeout timer is explicitly reset only by KSCAN. Every call to KSCAN that detects a key-press resets the timer. The only key-press that does not require KSCAN is <quit>, which is the only key checked for by the console ISR. This is done without explicitly resetting the timer. It does, of course, execute a console reset. ...lee "Minor nit" There is one other key. Sub-routine >0020 for the break key. I just tested it and it doesn't reset the screen timeout timer. 2 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted March 27, 2022 Share Posted March 27, 2022 3 hours ago, TheBF said: I will never stop being amazed at the concept of "polled" interrupts. What a weird machine we have. Yes, it has its quirks. But blocking interrupts now and then is a common technique, when your code can't handle interrupts in all cases. The p-system does the same thing. It allows interrupts between the more complex p-codes, but not between the more simple ones. 3 Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 27, 2022 Author Share Posted March 27, 2022 I've always, like @wilsy said, do a limi 2,0 after each kscan. BUT, there was an area that I used kscan, limi 0, because I didn't want an inadvertent quit press (not knowing a way around), but watching the debugger, I noticed that the address >83D4 - >83D6 stopped counting, I mean like very soon in the program, rt after setting my registers for the F18A. is there anything in the F18A that would cause this? I'll do a dump of code later on when I get to work. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 27, 2022 Share Posted March 27, 2022 5 hours ago, TheBF said: "Minor nit" There is one other key. Sub-routine >0020 for the break key. I just tested it and it doesn't reset the screen timeout timer. Yup. Forgot about that one, but that is an explicit check for <break> that does not (as you said) reset the screen timeout timer—only KSCAN does that after a key-press is detected. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 27, 2022 Share Posted March 27, 2022 5 hours ago, apersson850 said: Yes, it has its quirks. But blocking interrupts now and then is a common technique, when your code can't handle interrupts in all cases. The p-system does the same thing. It allows interrupts between the more complex p-codes, but not between the more simple ones. Yes there are always some times when you don't want another interrupt to mess things up. Typically while you are in the bowels of the interrupt handler. TI-99 turns things upside down so that the interrupts are almost like a cooperative tasker where you give them permission to "interrupt", which I find amusing. It's just me. 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 27, 2022 Share Posted March 27, 2022 1 hour ago, GDMike said: I've always, like @wilsy said, do a limi 2,0 after each kscan. BUT, there was an area that I used kscan, limi 0, because I didn't want an inadvertent quit press (not knowing a way around), but watching the debugger, I noticed that the address >83D4 - >83D6 stopped counting, I mean like very soon in the program, rt after setting my registers for the F18A. is there anything in the F18A that would cause this? I'll do a dump of code later on when I get to work. You can control which interrupts will respond using the byte at address >83C2 83C2 CONSTANT AMSQ \ interrupt DISABLE bits \ AMSQ bit meaning: \ 80 all interrupts disabled \ 40 motion disabled \ 20 Sound disabled \ 10 quit key disabled Here is some Forth code that controls if QUIT key is active or not for example \ QUIT key enable/disable HEX : QUIT-OFF ( -- ) 83C2 DUP C@ 70 AND 10 OR SWAP C! ; : QUIT-ON ( -- ) 83C2 DUP C@ 60 AND SWAP C! ; 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 2 hours ago, TheBF said: You can control which interrupts will respond using the byte at address >83C2 83C2 CONSTANT AMSQ \ interrupt DISABLE bits \ AMSQ bit meaning: \ 80 all interrupts disabled \ 40 motion disabled \ 20 Sound disabled \ 10 quit key disabled Here is some Forth code that controls if QUIT key is active or not for example \ QUIT key enable/disable HEX : QUIT-OFF ( -- ) 83C2 DUP C@ 70 AND 10 OR SWAP C! ; : QUIT-ON ( -- ) 83C2 DUP C@ 60 AND SWAP C! ; Right. Good deal Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 (edited) Note.. my video didn't upload... Video 1. Showing >83D6 in fact incrementing as normal. After adding in my limi 2,0. But I'm not sure if it was my routine that blanked the screen or not, so I'm running another test without my routine in Play this time. Ok, Why does this happen???? Grrrrrr After removing my routine to count and blank the screen, the built in timer/ blanker now works again as normal. I don't know why it didn't work last night after I tried this Same test but today it is in fact working, just like it's supposed to and it's just like I had it working before I removed the limi 2, last month,which, I should not have done.. But I tested , I know for a fact I tested this yesterday with the limi 2,0 in tact. With no screen blanker happening, that's why I added my own routine. AND I closed classic 99 several times and reopened, BUT never did I shut the machine down, that's the difference here today. Ok...my bad... nothing to see here...it in fact works like it's supposed to.. sorry for the uproar about interrupts. I did another time test, and the internal blanker kicks in at 9:07 while my blanker was kicking in at 10.0. and what was happening was that the internal blanker was kicking in and making mine look like it was coming on prematurely. Bwhhaha.... Edited March 28, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 (edited) I just added a toggle, (ctrl S), that simply let's the timer run (enable screen saver), OR during cursor blink (clears >83D6) disabling the screensaver from kicking in. I don't like Messing with the interrupts. (Had to adjust my delay a bit, slow fingers cause multiple S/S activation, deactivations)...lol VID_20220327_225430764.mp4 Edited March 28, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 (edited) Ok.ill upload a new copy of SNP(80). Now that all the bugs, that I can find, are out. And I'll spend the rest of the night doing documentation... Edited March 28, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 (edited) Change of plans...on upload.. Seems that reset is still available where I don't want it..... I've got to fix it Edited March 28, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 5 hours ago, TheBF said: You can control which interrupts will respond using the byte at address >83C2 83C2 CONSTANT AMSQ \ interrupt DISABLE bits \ AMSQ bit meaning: \ 80 all interrupts disabled \ 40 motion disabled \ 20 Sound disabled \ 10 quit key disabled Here is some Forth code that controls if QUIT key is active or not for example \ QUIT key enable/disable HEX : QUIT-OFF ( -- ) 83C2 DUP C@ 70 AND 10 OR SWAP C! ; : QUIT-ON ( -- ) 83C2 DUP C@ 60 AND SWAP C! ; I'm trying to figure this one out. I ended up with losing the quit function like I wanted, but also Lost sound. Are you saying, place>7010 into address>83C2? I haven't tried that... but I place >B2 and it got close to the desired fix. Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 (edited) Ahh. I suppose that's it. Because it worked this time. I have my sounds AND stopped the "quit" function. I hope I did this rt Brian, but I'm not seeing any side effects so far.. thanks for that info. Edited March 28, 2022 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 (edited) the latest SNP (80) 2.0 fixed the ctrl X, exit routine SNP Edited March 28, 2022 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 28, 2022 Share Posted March 28, 2022 9 hours ago, GDMike said: during cursor blink (clears >83D6) disabling the screensaver from kicking in Cursor blink should not be clearing the screen timeout timer (STT). Are you doing that explicitly? If you need to disable the STT during cursor blink between keystrokes, just store an odd number at >83D6 when you initialize the blink count. ...lee 1 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted March 28, 2022 Share Posted March 28, 2022 9 hours ago, GDMike said: Are you saying, place>7010 into address>83C2? I haven't tried that... but I place >B2 and it got close to the desired fix. Where did you get 7010 from? B would take out everything except sprite motion. Don't know why you keep that running? And the 2 wasn't even mentioned. What is it you are trying to accomplish? 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted March 28, 2022 Share Posted March 28, 2022 (edited) 15 hours ago, TheBF said: Yes there are always some times when you don't want another interrupt to mess things up. Typically while you are in the bowels of the interrupt handler. Disabling interrupt, at least of equal or less priority, is something the processor will do by itself, usually. That's true for the TMS 9900 as well. If you implement the full interrupt structure you have several prioritized interrupt levels. If you then get an interrupt at level 8, a new interrupt at level 11 will not be serviced. But a new interrupt at level 4 will interrupt the service of the level 8 interrupt. When level 4 has been served, the CPU will return to level 8, and when that has been serviced, it will return to the main level, which immediately will interrupt at level 11, since that has not been serviced yet. In the operating system for the TI 99/4A, they take advantage of the fact that there is a GPL interpreter running. Since the interpreter, just like the CPU itself, can't be interrupted in the middle of an instruction, the GPL interpreter will open for interrupts when it's possible to handle. That is, between instructions or when doing other stuff, which comes back frequently enough to allow service of the interrupt(s) within a reasonable time. As I wrote above, the p-system does something equivalent. Edited March 28, 2022 by apersson850 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 28, 2022 Share Posted March 28, 2022 Just now, apersson850 said: Disabling interrupt, at least of equal or less priority, is something the processor will do by itself, usually. That's true for the TMS 9900 as well. If you implement the full interrupt structure you have several prioritized interrupt levels. If you then get an interrupt at level 8, a new interrupt at level 11 will not be serviced. But a new interrupt at level 4 will interrupt the service of the level 8 interrupt. When level 4 has been served, the CPU will return to level 8, and when that has been serviced, it will return to the main level, which immediately will interrupt at level 11, since that has not been serviced yet. In the operating systems for the TI 99/4A, they take advantage of the fact that there is a GPL interpreter running. Since the interpreter, just like the CPU itself, can't be interrupted in the middle of an instruction, the GPL interpreter will open for interrupts when it's possible to handle. That is, between instructions or when doing other stuff, which comes back frequently enough to allow service of the interrupt(s) within a reasonable time. Yes that multi-level interrupt system on the 9900 system is really nice IMHO. The idea that the interpreter can't be interrupted is foreign to me coming from the Forth world. Interrupts in Forth systems typically are reserved for things that truly must be dealt with in real time and since the context is living on stacks for the most part, changing context is pretty straightforward to handle an interrupt. I have done it on x86 for serial communication and on 68HC11 for a machine that counted baby chicks. In both cases I was interrupting the Forth interpreter all the time and these were purchased Forth systems, not something I wrote. On 9900, where an interrupt can access it's own private register set, interrupting an interpreter should be easy, or am I missing something? 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 28, 2022 Share Posted March 28, 2022 16 hours ago, TheBF said: \ QUIT key enable/disable HEX : QUIT-OFF ( -- ) 83C2 DUP C@ 70 AND 10 OR SWAP C! ; : QUIT-ON ( -- ) 83C2 DUP C@ 60 AND SWAP C! ; 10 hours ago, GDMike said: Ahh. I suppose that's it. Because it worked this time. I have my sounds AND stopped the "quit" function. I hope I did this rt Brian, but I'm not seeing any side effects so far.. thanks for that info. A method to enable/disable <quit> should not disturb the other two toggles, console automotion and console sound processing. If the byte at >83C2 = >80, ANDing the byte with >70 gratuitously re-enables automotion and sound. ANDing the byte with >60 also gratuitously re-enables automotion and sound. I would change QUIT-OFF and QUIT-ON to something like this: \ QUIT key enable/disable HEX : QUIT-OFF ( -- ) 83C2 C@ DUP 80 < IF \ all-toggles-off bit set? 10 OR 83C2 C! \ no..set <quit> off bit ELSE DROP \ yes..nothing to do THEN ; : QUIT-ON ( -- ) 83C2 DUP C@ DUP 80 < IF \ all-toggles-off bit set? 60 AND \ no..clear <quit> off bit ELSE DROP 60 \ yes..set all off bits except <quit> THEN SWAP C! ; ...lee 3 Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 (edited) 3 hours ago, Lee Stewart said: Cursor blink should not be clearing the screen timeout timer (STT). Are you doing that explicitly? If you need to disable the STT during cursor blink between keystrokes, just store an odd number at >83D6 when you initialize the blink count. ...lee Yes, exactly what I'm doing lee.im throwing a 1 at it to basically reset the counter in order to keep the screen FROM blanking during cursor timer routine. I guess I should just go to the kscan routine and throw the odd number at it instead. And save the routine from that area if cursor timing. Initially I did throw an odd number at it and watched the debugger and it just kept counting...I'll go back and try again. Nevermind...it's early for me and I misunderstood your comment...I'll leave everything alone, as I'm already clearing the counter where it needs to happen.. Edited March 28, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 28, 2022 Share Posted March 28, 2022 (edited) 16 hours ago, GDMike said: I'm trying to figure this one out. I ended up with losing the quit function like I wanted, but also Lost sound. Are you saying, place>7010 into address>83C2? I haven't tried that... but I place >B2 and it got close to the desired fix. He was ANDing >70 and ORing >10. Since you are probably doing this in ALC, here it is that way (maybe it will be clearer): * * QUIT key enable/disable * BL @QITOFF or * BL @QUITON * QITOFF MOVB @>83C2,R0 all-toggles-off bit set? JLT QUITEX yes..nothing to do but exit ORI R0,>1000 no..only set <quit> off bit JMP QUIT02 process bits * QUITON MOVB @>83C2,R0 all-toggles-off bit set? JLT QUIT01 yes..manage all toggles ANDI R0,>6000 no..clear only <quit> toggle JMP QUIT02 process bits QUIT01 LI R0,>6000 set all off bits except <quit> QUIT02 MOVB R0,@>83C2 store new settings QUITEX RT ...lee Edited March 28, 2022 by Lee Stewart correction 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 Got it. That's a bit better ? understanding Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 POST #970 adjusted And edited Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 1 hour ago, Lee Stewart said: A method to enable/disable <quit> should not disturb the other two toggles, console automotion and console sound processing. If the byte at >83C2 = >80, ANDing the byte with >70 gratuitously re-enables automotion and sound. ANDing the byte with >60 also gratuitously re-enables automotion and sound. I would change QUIT-OFF and QUIT-ON to something like this: \ QUIT key enable/disable HEX : QUIT-OFF ( -- ) 83C2 C@ DUP 80 < IF \ all-toggles-off bit set? 10 OR 83C2 C! \ no..set <quit> off bit ELSE DROP \ yes..nothing to do THEN ; : QUIT-ON ( -- ) 83C2 DUP C@ DUP 80 < IF \ all-toggles-off bit set? 60 AND \ no..clear <quit> off bit ELSE DROP 60 \ yes..set all off bits except <quit> THEN SWAP C! ; ...lee This is really cool as I never knew there was this type of control and handling available as were discussing. I'd never learn it if I hadn't of screwed it up originally, I think.. bwhhaha.lol Quote Link to comment Share on other sites More sharing options...
GDMike Posted March 28, 2022 Author Share Posted March 28, 2022 If you're interested... You can run the SNP program in classic 99, turn on debugger, set to CPU, watch the addresses >83D4->83D6 and pressing Ctrl S, to reset the screensaver and Ctrl S again to enable it. Quote Link to comment Share on other sites More sharing options...
