rossum Posted May 17, 2020 Share Posted May 17, 2020 (edited) You might find this tool useful. It does BAS and XEX disassembly in a browser and can produce nice printable Basic listings in the classic font. Handy for quickly pulling apart a ATR or just spelunking through its contents. Disassembler is primitive but at least it has symbols. Atari Basic decompiler works with files that have missing variable name tables. lmk if it is useful or if you have any feature requests. cheers https://github.com/rossumur/esp_8_bit/blob/master/atr_image_explorer.htm atr_image_explorer.htm Edited May 17, 2020 by rossum 25 7 Quote Link to comment Share on other sites More sharing options...
FULS Posted May 17, 2020 Share Posted May 17, 2020 57 minutes ago, rossum said: lmk if it is useful or if you have any feature requests. cheers WOW!!! Great tool! I will be using this a lot. This tool is awesome as is, but I'm sure we will take you up on feature requests. Leaving for vacation at Clearwater Beach, Florida, but will be using this tool when I get back. Thank You very much, Doug Quote Link to comment Share on other sites More sharing options...
+Philsan Posted May 17, 2020 Share Posted May 17, 2020 Very useful, thanks! Could you please set the Basic listing border to 0 or let the user choose between standard and 0? Turbo-Basic XL compatibility would be nice too. 2 Quote Link to comment Share on other sites More sharing options...
marcokitt2000 Posted May 17, 2020 Share Posted May 17, 2020 Greate tool thnxxx Quote Link to comment Share on other sites More sharing options...
xxl Posted May 17, 2020 Share Posted May 17, 2020 great tool. you could add undocumented 6502C codes also. https://xxl.atari.pl/sally-6502c/ 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted May 17, 2020 Share Posted May 17, 2020 Just had a quick try with something I wrote, very nice output, this tool goes straight into my Utils folder, will be using this quite a bit, well done? Quote Link to comment Share on other sites More sharing options...
vitoco Posted May 17, 2020 Share Posted May 17, 2020 It's amazing! These are my comments/requests (some of them were already mentioned): Extend BASIC detokenizer (disassembler) to TurboBasic XL. One fits both interpreters. Allow many widths in ATASCII listings, including an option to remove left margin for full 40 columns mode. Do not add top and bottom empty lines in ATASCII listings. It is possible to add many file by dropping them in the left panel, but there is no way to remove any from the list. Could you add an (X) button to discard unwanted ones? Estimated filesize (in 125 bytes blocks) is appended to filenames when you drop a single file (not ATR). Add a space between them. In dropping mode (to add files), existing elements in the left panel are highlighted when the pointer goes over them, which it makes me doubt what is going on. Could just the full panel (or nothing) be highlighted? Most of the TXT files inside ATRs are ATASCII text files, so it would be great to display them as LST listing files instead of DAT (hex dump) files. Both "Download" and "Save as LST" buttons are cool... Thanks again for this great tool!!! 2 Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted May 17, 2020 Share Posted May 17, 2020 2 hours ago, vitoco said: It is possible to add many file by dropping them in the left panel, but there is no way to remove any from the list. Could you add an (X) button to discard unwanted ones? to get rid of (remove) files from list refresh window F5 or click the refresh icon in title. 2 Quote Link to comment Share on other sites More sharing options...
rossum Posted May 17, 2020 Author Share Posted May 17, 2020 Small update: Added a close box 40 col:80 col:Wide (unwrapped) layouts Added "TXT" extension Cleaned up drag/drop ui Thx for the suggestions cheers https://github.com/rossumur/esp_8_bit/blob/master/atr_image_explorer.htm atr_image_explorer.htm 3 3 Quote Link to comment Share on other sites More sharing options...
+gnusto Posted May 17, 2020 Share Posted May 17, 2020 This is quite fantastic, thank you. I like that you even put in UX handling on opening multiple files and switching between them. Not sure if you knew but it does not seem to work with opening files in modern Firefox; I just fired up Chromium instead so no problem. The various browsers are quite different how they treat drag and drop file operations so I wasn't surprised, just wanted to make sure you knew. Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 17, 2020 Share Posted May 17, 2020 Tried Safari, Firefox and Opera. Doesn't seem to work. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 17, 2020 Share Posted May 17, 2020 Neat browser app, and useful. Thanks for sharing. One suggestion would be to add support for some other known filetypes, like: fnt/set, mic, etc. If you do that, I would still leave the option to visualize the data as hex, and/or maybe some other useful formats (like data statements, for instance) too. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 17, 2020 Share Posted May 17, 2020 2 minutes ago, Mathy said: Tried Safari, Firefox and Opera. Doesn't seem to work. Works in Opera here (Version: 68.0.3618.104), on Windows 7 - 64-bit... Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 17, 2020 Share Posted May 17, 2020 (edited) 49 minutes ago, Mathy said: Tried Safari, Firefox and Opera. Doesn't seem to work. Works in Firefox here (Version: 76.0.1) too, on Windows 7 - 64-bit... Although some parts show up a little different in Firefox than Opera. For instance, the directory text has double line breaks in between each directory entry from an ATR. The text is also smaller sized for every view (including the ATR directory listing) using the Atari font, whereas only the "Wide" format shows up smaller (as expected) in Opera. Edited May 17, 2020 by MrFish 1 Quote Link to comment Share on other sites More sharing options...
Mathy Posted May 17, 2020 Share Posted May 17, 2020 Hello MrFish, guys 8 minutes ago, MrFish said: Works in Opera here (Version: 68.0.3618.104), on Windows 7 - 64-bit... I tried one ATR with Safari, Firefox and the Opera version you mention, but for MacOS. Guess what. If I try a different ATR or an XEX, it works. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
JimF Posted May 17, 2020 Share Posted May 17, 2020 Just tested this a bit, it's brilliant - thanks so much! Works well for me with various atrs on Safari (Catalina) and Google Chrome, on Firefox I need to zoom in the display a bit for better readability. Quote Link to comment Share on other sites More sharing options...
JimF Posted May 17, 2020 Share Posted May 17, 2020 Also works on Raspberry Pi (Pixel) with Chromium browser, though the disk-specific close-x does not seem to appear. Quote Link to comment Share on other sites More sharing options...
rossum Posted May 18, 2020 Author Share Posted May 18, 2020 Thanks all for the feedback. Fixed most of the ugly Firefox/Safari CSS issues. https://github.com/rossumur/esp_8_bit/blob/master/atr_image_explorer.htm atr_image_explorer.htm 2 2 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 18, 2020 Share Posted May 18, 2020 21 minutes ago, rossum said: Thanks all for the feedback. Fixed most of the ugly Firefox/Safari CSS issues. https://github.com/rossumur/esp_8_bit/blob/master/atr_image_explorer.htm atr_image_explorer.htm 62.41 kB · 1 download Thanks, fixed the issues I posted about for Firefox. 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 18, 2020 Share Posted May 18, 2020 2 hours ago, Mathy said: I tried one ATR with Safari, Firefox and the Opera version you mention, but for MacOS. Guess what. If I try a different ATR or an XEX, it works. Hi Mathy, Why don't you post the ATR image you're having trouble with? Then maybe @rossum can figure out what the issue is. Regards, MF Quote Link to comment Share on other sites More sharing options...
leech Posted May 18, 2020 Share Posted May 18, 2020 22 minutes ago, MrFish said: Hi Mathy, Why don't you post the ATR image you're having trouble with? Then maybe @rossum can figure out what the issue is. Regards, MF Ha, I tried it with the program disk of one of the Ultima IV sets I have, and unfortunately it just showed some non-latin characters. Quote Link to comment Share on other sites More sharing options...
rossum Posted May 18, 2020 Author Share Posted May 18, 2020 3 hours ago, MrFish said: Neat browser app, and useful. Thanks for sharing. One suggestion would be to add support for some other known filetypes, like: fnt/set, mic, etc. If you do that, I would still leave the option to visualize the data as hex, and/or maybe some other useful formats (like data statements, for instance) too. Added FNT visualization. Any .mic files lying about? atr_image_explorer.htm 3 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 18, 2020 Share Posted May 18, 2020 18 minutes ago, rossum said: Added FNT visualization. Any .mic files lying about? That was fast! BTW, ".fnt" and ".set" (as in character set) are the same thing. Here are some ".mic" files -- from the Graph2Font program examples folder. mic.zip Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 18, 2020 Share Posted May 18, 2020 21 minutes ago, rossum said: Added FNT visualization. Also, if you want to extend the visualization, it should include Antic 4 -- at least. It was one of the prime targets for redefined character sets. 1 Quote Link to comment Share on other sites More sharing options...
xxl Posted May 18, 2020 Share Posted May 18, 2020 additionally show dir sectors in raw format - maybe there are files deleted or with an unusual status byte 1 Quote Link to comment Share on other sites More sharing options...
