Simius Posted August 22, 2023 Author Share Posted August 22, 2023 Hopefully 2023. Although there are not many waiting. 4 2 Quote Link to comment Share on other sites More sharing options...
Droid420 Posted September 9, 2023 Share Posted September 9, 2023 I would like to be added to the pre-order as well. Do I need to do anything else besides state so on this thread? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 9, 2023 Share Posted September 9, 2023 (edited) 27 minutes ago, Droid420 said: I would like to be added to the pre-order as well. Do I need to do anything else besides state so on this thread? Nope. Just wait for the word as and when, Hopefully 2023. Afaik in the States the Brewing academy will likely be the reseller (as they have done before). Over here in Europe you buy from Simius directly, (payment via PayPal). Basically for now watch this space. Where are you based btw? Edited September 9, 2023 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
Droid420 Posted September 9, 2023 Share Posted September 9, 2023 8 hours ago, Beeblebrox said: Nope. Just wait for the word as and when, Hopefully 2023. Afaik in the States the Brewing academy will likely be the reseller (as they have done before). Over here in Europe you buy from Simius directly, (payment via PayPal). Basically for now watch this space. Where are you based btw? I just found the brewing academy site yesterday looking for a 5200 AV mod which then led me to this forum. I will probably pick up their AV mod until I get get my hands on a Sophia 2. I am located in a Dallas Texas suburb. Quote Link to comment Share on other sites More sharing options...
+nasty niff Posted September 9, 2023 Share Posted September 9, 2023 Quick question, have two Sophia 2, one works perfectly, the other seems to only work @ 576p, changed cables including ribbon and tried in different xls, just gives black like it's trying to sync.... Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted September 9, 2023 Share Posted September 9, 2023 2 hours ago, nasty niff said: Quick question, have two Sophia 2, one works perfectly, the other seems to only work @ 576p, changed cables including ribbon and tried in different xls, just gives black like it's trying to sync.... Maybe the signal may be out of spec slightly with the second one. Did you try changing resolution with the configuration utility to get a screen that may work? Quote Link to comment Share on other sites More sharing options...
+nasty niff Posted September 9, 2023 Share Posted September 9, 2023 Changed using the configurator and fjc (u1mb) plugin, makes no difference, only stable at 576p.other resolutions are unstable,not syncing. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 9, 2023 Share Posted September 9, 2023 My LG flatron monitor doesn't like all resolutions put out by my sophia 2. Quote Link to comment Share on other sites More sharing options...
+nasty niff Posted September 9, 2023 Share Posted September 9, 2023 One Sophia 2 works fine, the other only @576p, strange.... Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted September 9, 2023 Share Posted September 9, 2023 20 minutes ago, nasty niff said: One Sophia 2 works fine, the other only @576p, strange.... there were different Sophia firmwares, check some of the forum threads to see if they are there or required a pm / dm to get the other versions. 1 Quote Link to comment Share on other sites More sharing options...
wildstar87 Posted September 10, 2023 Share Posted September 10, 2023 Trying to setup Sophia to output RGB 15Khz, running Sconf.exe I don't see a way to change the special features, cursor only rotates through resolutions. I'm missing something.. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 10, 2023 Share Posted September 10, 2023 (edited) @wildstar87 I don't have my Sophia 2 enabled machine in front of me but I believe TAB alternates between the config groups. Edited September 10, 2023 by Beeblebrox Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted September 10, 2023 Share Posted September 10, 2023 (edited) Looking at the screenshot that @Beeblebrox provided, I would look at the sync modes that the utility shows. I do not remember if the U1MB plug in shows that option. I will check later when I have time to set up the computer. Edited September 10, 2023 by scorpio_ny Quote Link to comment Share on other sites More sharing options...
+nasty niff Posted September 10, 2023 Share Posted September 10, 2023 Tried all combinations and resolutions. Think there's a problem with this sophia2. PXL_20230910_173256519.mp4 Quote Link to comment Share on other sites More sharing options...
wildstar87 Posted September 10, 2023 Share Posted September 10, 2023 3 hours ago, Beeblebrox said: @wildstar87 I don't have my Sophia 2 enabled machine in front of me but I believe TAB alternates between the config groups. Thanks, that was it. 1 Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted September 10, 2023 Share Posted September 10, 2023 3 hours ago, nasty niff said: Tried all combinations and resolutions. Think there's a problem with this sophia2. PXL_20230910_173256519.mp4 406.73 MB · 0 downloads You did try the different sync modes? Here is a Hail Mary.... can you try another input on the TV. I once had worked with a TV and discovered later that that one of the inputs was not functional with a certain device even though it worked with another. Quote Link to comment Share on other sites More sharing options...
+joeatari Posted September 11, 2023 Share Posted September 11, 2023 This is great! I must have at least three of these (I hope!) Quote Link to comment Share on other sites More sharing options...
+nasty niff Posted September 11, 2023 Share Posted September 11, 2023 Tried all inputs on the monitor plus a large TV, same problem. Even all the sync modes via configurator and u1mb, no change. Quote Link to comment Share on other sites More sharing options...
wildstar87 Posted September 11, 2023 Share Posted September 11, 2023 Tried different settings to get 15Khz RGB working. Trying to verify 2 different monitors for RGB. I have an Amiga 1080 CRT monitor, and a Dell U2410. I'm not getting any response out of either monitor with Sophia. U2410 seems to sort of work with VBXE (though having other issues), I am getting an image though. The 1080, I have switched over to RGB Analog, on the back, and RGB on the front. I'm not getting any picture at all. Tried settings in Sophia, to RGB, and both norm or interlaced settings, though I was able to get VGA out. Any ideas? Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted September 11, 2023 Share Posted September 11, 2023 1 hour ago, wildstar87 said: Tried different settings to get 15Khz RGB working. Trying to verify 2 different monitors for RGB. I have an Amiga 1080 CRT monitor, and a Dell U2410. I'm not getting any response out of either monitor with Sophia. U2410 seems to sort of work with VBXE (though having other issues), I am getting an image though. The 1080, I have switched over to RGB Analog, on the back, and RGB on the front. I'm not getting any picture at all. Tried settings in Sophia, to RGB, and both norm or interlaced settings, though I was able to get VGA out. Any ideas? Which DVI cables adapter are you using? Not all of them support analog output. Are you using the one with the analog pins? 1 Quote Link to comment Share on other sites More sharing options...
wildstar87 Posted September 11, 2023 Share Posted September 11, 2023 (edited) Yeah I'm using an DVI to VGA adapter that I had, I have a few others I can try, but I don't think this is the problem. It works in VGA mode, just not 15Khz RGB. It has the 5 pins for the analog section. Edited September 11, 2023 by wildstar87 Quote Link to comment Share on other sites More sharing options...
Stokestack Posted September 11, 2023 Share Posted September 11, 2023 +1 customer for the next batch of boards Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted September 12, 2023 Share Posted September 12, 2023 (edited) 10 hours ago, wildstar87 said: Yeah I'm using an DVI to VGA adapter that I had, I have a few others I can try, but I don't think this is the problem. It works in VGA mode, just not 15Khz RGB. It has the 5 pins for the analog section. From the documentation, it seems that it doesn't support 15Khz RGB, only standard VGA. Edited September 12, 2023 by scorpio_ny Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted September 12, 2023 Share Posted September 12, 2023 On 9/10/2023 at 10:50 PM, nasty niff said: Tried all inputs on the monitor plus a large TV, same problem. Even all the sync modes via configurator and u1mb, no change. Very strange. Hopefully @Simius can provide insight what to do next. Quote Link to comment Share on other sites More sharing options...
+nasty niff Posted September 12, 2023 Share Posted September 12, 2023 sent my sophia2 back to simius, he said hell take a look and repair, great guy 2 Quote Link to comment Share on other sites More sharing options...
