wildstar87 Posted September 12 Share Posted September 12 13 hours ago, scorpio_ny said: From the documentation, it seems that it doesn't support 15Khz RGB, only standard VGA. Strange, I thought that was why there was a specific RGB mode with interlace, since there is a specific VGA mode. @Simius can you chime in here? Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 12 Share Posted September 12 22 minutes ago, wildstar87 said: Strange, I thought that was why there was a specific RGB mode with interlace, since there is a specific VGA mode. @Simius can you chime in here? Simius posted an update Sophia 2 manual a few weeks back: The original feature spec is here: Features: - 100% compatible GTIA replacement - PAL/NTSC encoding - Independent RGB/YPbPr/VGA and DVI outputs - eight selectable DVI modes - 15 loadable 18-bit color palettes Quote Link to comment Share on other sites More sharing options...
wildstar87 Posted September 12 Share Posted September 12 (edited) 19 minutes ago, Beeblebrox said: Simius posted an update Sophia 2 manual a few weeks back: The original feature spec is here: Features: - 100% compatible GTIA replacement - PAL/NTSC encoding - Independent RGB/YPbPr/VGA and DVI outputs - eight selectable DVI modes - 15 loadable 18-bit color palettes Unless I'm missing something, I thought RGB specifically referred to RGB 15Khz, otherwise I'm not sure what RGB standard we are talking about, because technically VGA is RGB, just at a specific frequency. YPBPr is component RGB, which again is also RGB (sorta) just based on a different standard from my understanding. https://thecablesland.com/ypbpr-vs-rgb/ If it doesn't support 15Khz RGB, to output to ST color monitors, or Commodore/Amiga monitors RGB, then that's a simple answer, but I just want to make sure that's the case. Edited September 12 by wildstar87 Quote Link to comment Share on other sites More sharing options...
Simius Posted September 13 Author Share Posted September 13 Analog outputs of the Sophia 2 can be configured as 31kHz VGA mode, 15kHz RGB mode or 15kHz YPbPr mode. If you can get an image on your VGA monitor, the analog outputs are working. 4 Quote Link to comment Share on other sites More sharing options...
Dinadan67 Posted September 13 Share Posted September 13 (edited) RGB 15khz works fine, i use a cheap DVI->VGA adapter + Lotharek's VGA->SCART cable to connect a Commodore 1084 monitor: https://forums.atariage.com/topic/98341-whats-the-latest-atari-related-things-youve-bought-on-ebay/page/201/#comment-4897729 Edited September 13 by Dinadan67 2 Quote Link to comment Share on other sites More sharing options...
wildstar87 Posted September 13 Share Posted September 13 17 hours ago, Simius said: Analog outputs of the Sophia 2 can be configured as 31kHz VGA mode, 15kHz RGB mode or 15kHz YPbPr mode. If you can get an image on your VGA monitor, the analog outputs are working. Thanks Simius, what would be the proper settings for 15Khz RGB in the Special features? RGB, Sync mode norm or interlace? and I assume Sync out to Csync? Quote Link to comment Share on other sites More sharing options...
wildstar87 Posted September 15 Share Posted September 15 On 9/13/2023 at 12:27 AM, Dinadan67 said: RGB 15khz works fine, i use a cheap DVI->VGA adapter + Lotharek's VGA->SCART cable to connect a Commodore 1084 monitor: https://forums.atariage.com/topic/98341-whats-the-latest-atari-related-things-youve-bought-on-ebay/page/201/#comment-4897729 Can you tell me what settings you used in the special features? Quote Link to comment Share on other sites More sharing options...
Dinadan67 Posted September 15 Share Posted September 15 I just connected my Commodore 1084 monitor to check the settings: 2 Quote Link to comment Share on other sites More sharing options...
wildstar87 Posted September 15 Share Posted September 15 Thanks much! Quote Link to comment Share on other sites More sharing options...
TheUnseenSquid Posted October 9 Share Posted October 9 I'm also eagerly awaiting the next batch of boards! Got a lonely 5200 here I want to wire up into my setup. I'll bookmark the thread and check back every few weeks. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted October 9 Share Posted October 9 3 hours ago, TheUnseenSquid said: I'm also eagerly awaiting the next batch of boards! Got a lonely 5200 here I want to wire up into my setup. I'll bookmark the thread and check back every few weeks. Register your interest here: Quote Link to comment Share on other sites More sharing options...
TheUnseenSquid Posted October 13 Share Posted October 13 On 10/8/2023 at 10:32 PM, Beeblebrox said: Register your interest here: Done, thanks! Quote Link to comment Share on other sites More sharing options...
