Sophia 2 preorder thread
Simius
4 hours ago, MrFish said:
Any information/pictures on how this installs in an Atari machine?
I'm sure this has been covered ad infinitum for Sophia 1; but I'm trying to bypass digging through threads to find out about it.
Thanks.
The tl;dr for the prior version: you remove the existing GTIA, install a socket if necessary, install the SOPHIA into the socket, then run a ribbon cable from the SOPHIA to a new connector (either DVI or RGB). You typically have to cut the case to accommodate your new connector, unless you’re installing in something like a 1088XEL or 1088XEL which have DIN13 connectors already and in the case of my 1088XEL, a cutout in the backplate for a DVI connector as well.
