Brentarian Posted May 30, 2020 Share Posted May 30, 2020 One for me, please. Thanks! Quote Link to comment Share on other sites More sharing options...
patjomki Posted May 30, 2020 Share Posted May 30, 2020 Two for me, please. Quote Link to comment Share on other sites More sharing options...
Tillek Posted May 30, 2020 Share Posted May 30, 2020 Guess I'll go with two. Quote Link to comment Share on other sites More sharing options...
Faicuai Posted May 30, 2020 Share Posted May 30, 2020 (edited) On 5/29/2020 at 12:18 AM, Gunstar said: I read it. I thought he meant assembly was different to the original Sophia, so that it would fit the 800 also, and not have to cut the shielding as those who installed the original Sophia had, since original Sophia installation in an 800 had been discussed right before his reply. You may well be right, actually. In any case, there is still (key) installation specs. missing. The tolerances are tight inside the shielded CPU-slot, on the 800. Sophia goes upside-down, directly on existing socket (?) but that leaves the video-ribbon header (female) also facing down... I can't tell how much room is left between that plastic header and the back aluminum-wall of the shield-cage, and which exit-direction should the header take (straight right-side ?, or if we could fold ribbon 45-degrees to go down from socket, and then in-and-up (into expansion bay) between Slot-3 edge-connector, for instance. We definitely need more specs. for a clean, quality install. Edited May 30, 2020 by Faicuai 1 Quote Link to comment Share on other sites More sharing options...
sargie Posted May 31, 2020 Share Posted May 31, 2020 I would like at least one - and possibly two please. Thanks for making this! Quote Link to comment Share on other sites More sharing options...
Awch Posted May 31, 2020 Share Posted May 31, 2020 One please Quote Link to comment Share on other sites More sharing options...
MARIO130XE Posted May 31, 2020 Share Posted May 31, 2020 One for me, please. Quote Link to comment Share on other sites More sharing options...
fandenivoldsk Posted May 31, 2020 Share Posted May 31, 2020 Two please Quote Link to comment Share on other sites More sharing options...
enito Posted May 31, 2020 Share Posted May 31, 2020 Two for me thxEnviado desde mi MI 8 mediante Tapatalk Quote Link to comment Share on other sites More sharing options...
Jason1024 Posted May 31, 2020 Share Posted May 31, 2020 Two please. Quote Link to comment Share on other sites More sharing options...
+skr Posted June 7, 2020 Share Posted June 7, 2020 I´m in for two. Quote Link to comment Share on other sites More sharing options...
commander Posted June 11, 2020 Share Posted June 11, 2020 please 2x sophia2 for me ? Quote Link to comment Share on other sites More sharing options...
+MrFish Posted June 11, 2020 Share Posted June 11, 2020 On 5/30/2020 at 8:33 AM, DrVenkman said: The tl;dr for the prior version: you remove the existing GTIA, install a socket if necessary, install the SOPHIA into the socket, then run a ribbon cable from the SOPHIA to a new connector (either DVI or RGB). You typically have to cut the case to accommodate your new connector, unless you’re installing in something like a 1088XEL or 1088XEL which have DIN13 connectors already and in the case of my 1088XEL, a cutout in the backplate for a DVI connector as well. Thanks, I did already have the general procedure for installation; I was more interested in pictures and maybe some info on what extra parts are included or not included. I did come across an installation video, since I posted my question. So, I was able to see what I wanted. Quote Link to comment Share on other sites More sharing options...
pjbramley Posted June 11, 2020 Share Posted June 11, 2020 2 please for me Quote Link to comment Share on other sites More sharing options...
+mytek Posted June 12, 2020 Share Posted June 12, 2020 (edited) 2 1 for me please . I plan on implementing them both as VGA. Edited June 13, 2020 by mytek Changed order quantity Quote Link to comment Share on other sites More sharing options...
MrFSL Posted June 13, 2020 Share Posted June 13, 2020 one for me please. Quote Link to comment Share on other sites More sharing options...
jowi Posted June 13, 2020 Share Posted June 13, 2020 1 for me please (600XL) ? Quote Link to comment Share on other sites More sharing options...
Koa Zo Posted June 16, 2020 Share Posted June 16, 2020 One for me. Thank you! Quote Link to comment Share on other sites More sharing options...
Sleepy Posted June 17, 2020 Share Posted June 17, 2020 One for my 1088XEL, please! :-) Sleepy Quote Link to comment Share on other sites More sharing options...
Vyper68 Posted June 17, 2020 Share Posted June 17, 2020 I would like to put my name down for 1 please. Quote Link to comment Share on other sites More sharing options...
svhovater Posted June 18, 2020 Share Posted June 18, 2020 one for me, too, please! Quote Link to comment Share on other sites More sharing options...
TXG/MNX Posted June 19, 2020 Share Posted June 19, 2020 I want also two ... Quote Link to comment Share on other sites More sharing options...
BigBen Posted June 20, 2020 Share Posted June 20, 2020 Two for me. Quote Link to comment Share on other sites More sharing options...
codeX Posted June 20, 2020 Share Posted June 20, 2020 I would like one please! Quote Link to comment Share on other sites More sharing options...
Marsupilami Posted June 20, 2020 Share Posted June 20, 2020 (edited) 3 for me please Thanks Edited June 20, 2020 by Marsupilami Quote Link to comment Share on other sites More sharing options...
