+DjayBee Posted October 18, 2021 Share Posted October 18, 2021 13 minutes ago, Yautja said: Alright. I'm here (see the image, please). What should I do next? Select the command you want to have the shortcut assigned to (left pane). Check if your chosen shortcut is already used by something else (right pane "bound commands") and in case it is already used, decide if you want to replace it. Choose the scope in which you want the shortcut to work (default: Global). Click/select the field behind "Global" and press the keystroke you want to assign. "Add" Quote Link to comment Share on other sites More sharing options...
Yautja Posted October 18, 2021 Share Posted October 18, 2021 1 hour ago, DjayBee said: Select the command you want to have the shortcut assigned to (left pane). Check if your chosen shortcut is already used by something else (right pane "bound commands") and in case it is already used, decide if you want to replace it. Choose the scope in which you want the shortcut to work (default: Global). Click/select the field behind "Global" and press the keystroke you want to assign. "Add" Many thanks! 1 Quote Link to comment Share on other sites More sharing options...
Yautja Posted October 18, 2021 Share Posted October 18, 2021 1 hour ago, DjayBee said: Select the command you want to have the shortcut assigned to (left pane). Check if your chosen shortcut is already used by something else (right pane "bound commands") and in case it is already used, decide if you want to replace it. Choose the scope in which you want the shortcut to work (default: Global). Click/select the field behind "Global" and press the keystroke you want to assign. "Add" Mmm.. despite I could add the key combination, when pressed, nothing happens... where are the save state files supposed to be recorded? Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted October 18, 2021 Share Posted October 18, 2021 (edited) IIRC the quick states are just for that session and are in memory, so if you shut Altirra down they go.. What happens when you click quick load state? Edit: confirmed, quick states are just in mem, ideal if playing a game for testing or anything that is just to be saved until you quit Altirra.. In your case if you do a quick save on the test screen and then press start to enter a test, then pressing quick load should bring you back to the main test screen menu where you were when you saved it. Edited October 18, 2021 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
Yautja Posted October 18, 2021 Share Posted October 18, 2021 (edited) 3 minutes ago, Mclaneinc said: What happens when you click quick load state? Nothing, either. I was expecting a popup window or something. Edited October 18, 2021 by Yautja Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted October 18, 2021 Share Posted October 18, 2021 (edited) no pop up window, just takes you back to when you first did a quick save.. With quick saves there's nothing to browse for as it's just memory, if you do a full save state and then press load state you then get a file browser.. Edited October 18, 2021 by Mclaneinc 1 Quote Link to comment Share on other sites More sharing options...
scotty Posted October 19, 2021 Share Posted October 19, 2021 Just bought a MISTer. It should be here in 2 days. I still do not think it will break my love affair with Altirra . I have a ton of real A8 hardware, including an 800XL on my desk right in front of me, connected to my main PC monitor (PC keyboard on slide out tray under the desk, and I still use Altirra way more than 800XL. I use Altirra daily. Have not turned on the XL in a few months. Even with Ultimate1MB, Fujinet, SIO2PC, S-Drive Max and Sophia, I still love me some Altirra. 1 Quote Link to comment Share on other sites More sharing options...
+gnusto Posted October 20, 2021 Share Posted October 20, 2021 On 10/18/2021 at 8:22 PM, scotty said: Just bought a MISTer. I've owned one for a while, and they are super cool little devices - but it isn't as good at simulating an Atari as Altirra already is. Or at least it wasnt, I haven't checked in a while. Last time I tried to call MiSTer an "emulator" it launched a flamewar, so I won't get into that again. But the simple fact there were plenty of things I could run flawlessly on Altirra that i could not on MiSTer with the atari core at the time - acid800 for instance. At the end of the day, for myself and my preferences, I went back to Altirra most of the time, my 1088XEL for real hardware, and the MiSTer for a bunch of other things in another room (NES etc). 1 Quote Link to comment Share on other sites More sharing options...
Keatah Posted October 20, 2021 Share Posted October 20, 2021 MiSTer is good at the things it does..with select cores. Overall you shouldn't be disappointed. Personally for myself - especially when it comes to the early consoles and 8/16 bit computers, I still prefer emulators like AppleWin, Stella, Altirra, MAME, ColemWin, and others. And here's why: Software Emulation has many added features. On the host side there are things like a full Windows OS, complete with a file system and massive storage. A surefire boon to managing disk/cart/tape files. Things like debugging. Many screen options and effects. And of course the emulated machine is usually highly configurable - sometimes with cool fantasy options. Then there's the concomitant reliability, versatility, consistency, convenience, and even elegance, if you set it up on a classy designer SFF PC. I'm primarily an Apple II & PC guy 1st and then an Atari 8-bit fan 2nd. I keep Apple II hardware around for sentimentality, but I'm always using emulation 95% of the time. I don't have any Atari hardware, that's been gone for decades. Not so sure I want to go through the tediousness associated with curating a physical collection and acquiring parts and accessories and cartridges and aging floppies. Not to mention maintaining it all. Apple II is enough! So I rely 100% on Altirra. I believe MiSTer's strengths are in the 16-bit arena and timing accuracy and low lag. Users seem to love the video output and seem to prefer it as a way to get old consoles working on modern displays. Is MiSTer an emulator? I don't think so. It's more of a simulation. A collection of truth tables. And it is definitely not a 100% recreation of any machine. No FPGA is. IMHO Software Emulation, FPGA simulation, homebrew hardware, and real hardware, are complimentary to each other. Each excels in its own way. Fantastic that we have so many options! Quote Link to comment Share on other sites More sharing options...
Wilheim Posted October 20, 2021 Share Posted October 20, 2021 Not sure if this is the proper thread to ask, but I'm having trouble on executing Corina ROM files. Tried Yie Another Kung Fu on Altirra 3.90 and 4.00 test23 and in both the screen is flashing between a correct and a faulty one. Tried on NTSC and PAL configurations. I don't know if this is a problem from the ROM file dumped or there is an incompatibility on Altirra. Does anyone know what is the issue? Here's the dump I have, as well as the screens I got: Yie Another Kung-Fu.rom Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted October 20, 2021 Share Posted October 20, 2021 From memory, I think Avery said it does weird stuff so not supported, the emulator that does run it, Atari++ was a specially modded version to allow it to work.. The beta version of the game works iirc 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 20, 2021 Share Posted October 20, 2021 2 hours ago, Wilheim said: Not sure if this is the proper thread to ask, but I'm having trouble on executing Corina ROM files. Tried Yie Another Kung Fu on Altirra 3.90 and 4.00 test23 and in both the screen is flashing between a correct and a faulty one. Tried on NTSC and PAL configurations. I don't know if this is a problem from the ROM file dumped or there is an incompatibility on Altirra. Does anyone know what is the issue? Here's the dump I have, as well as the screens I got: I referenced @phaeron's answer to this question in my post in the AVG cart thread: Corina Cart Quote Link to comment Share on other sites More sharing options...
Xuel Posted October 20, 2021 Share Posted October 20, 2021 49 minutes ago, MrFish said: I referenced @phaeron's answer to this question in my post in the AVG cart thread: Corina Cart Here's a six byte patch that at least stops the flicker on the first level: Yie Another Kung-Fu Xuel Patch.rom I just shortened the double-buffered display lists by one line to avoid the hires bug that phaeron identified in the thread you quoted. Not sure how it works on real hardware. 2 2 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 20, 2021 Share Posted October 20, 2021 10 minutes ago, Xuel said: Here's a six byte patch that at least stops the flicker on the first level: I just shortened the double-buffered display lists by one line to avoid the hires bug that phaeron identified in the thread you quoted. Not sure how it works on real hardware. Thanks! Nice work. It seems to be fine now. I've played the first three levels with no problems (still PAL only, of course). Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 20, 2021 Share Posted October 20, 2021 1 hour ago, Xuel said: Here's a six byte patch that at least stops the flicker on the first level: I just shortened the double-buffered display lists by one line to avoid the hires bug that phaeron identified in the thread you quoted. Not sure how it works on real hardware. Obviously a different issue (as noted by @phaeron ), but would it be too difficult to patch the Bomb Jake Corina cartridge? Bomb Jake.rom Quote Link to comment Share on other sites More sharing options...
Xuel Posted October 22, 2021 Share Posted October 22, 2021 (edited) On 10/20/2021 at 2:59 PM, MrFish said: Obviously a different issue (as noted by @phaeron ), but would it be too difficult to patch the Bomb Jake Corina cartridge? Bomb Jake.rom 520 kB · 11 downloads Here's a 21-byte patch: Bomb Jake Xuel Patch.rom This fixes the title and hiscore screens but the game play seems slow on PAL and OK on NTSC. Not sure if this is due to being an older version of the code or maybe something else that's broken. For this I shortened the NMI entry sequence by about 8 cycles which is enough for DLIs to meet the deadlines for writing to WSYNC. To achieve this I changed the way the current bank is saved and restored such that it is never saved, just restored from the game's shadow register. Both this fix and the one that I did for Yie Another Kung-Fu are more about fixing ANTIC timing issues than anything to do with Corina hardware. I don't see how either cartridge would work reliably on real Ataris. The hires issue and the WSYNC deadline issue are both confirmed in hardware AFAIK. Have people actually tested these carts on lots of different machines? I wonder if the devs happened to have Ataris with oddball timings? Or maybe the cartridge itself affects ANTIC timings? Edit: grammar Edited October 22, 2021 by Xuel 1 1 Quote Link to comment Share on other sites More sharing options...
Xuel Posted October 22, 2021 Share Posted October 22, 2021 BTW, many thanks to @tebe for sharing the source code. It made patching Bomb Jake a much more tractable problem. 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 22, 2021 Share Posted October 22, 2021 Thank you for fixes XUEL, it is good to suspect the corina is either effecting timing or man handling the bus to get that issue out of the way. 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 26, 2021 Share Posted October 26, 2021 On 10/22/2021 at 4:58 PM, Xuel said: Here's a 21-byte patch: Bomb Jake Xuel Patch.rom 520 kB · 18 downloads This fixes the title and hiscore screens but the game play seems slow on PAL and OK on NTSC. Not sure if this is due to being an older version of the code or maybe something else that's broken. For this I shortened the NMI entry sequence by about 8 cycles which is enough for DLIs to meet the deadlines for writing to WSYNC. To achieve this I changed the way the current bank is saved and restored such that it is never saved, just restored from the game's shadow register. Thanks for taking the time on it. It does seem to be a bit slower than the XEX version; but at least it's running without glitches. On 10/22/2021 at 4:58 PM, Xuel said: Both this fix and the one that I did for Yie Another Kung-Fu are more about fixing ANTIC timing issues than anything to do with Corina hardware. I don't see how either cartridge would work reliably on real Ataris. The hires issue and the WSYNC deadline issue are both confirmed in hardware AFAIK. Have people actually tested these carts on lots of different machines? I wonder if the devs happened to have Ataris with oddball timings? Or maybe the cartridge itself affects ANTIC timings? Both Bomb Jake and Yie Another Kung Fu were sold on the Corina cart format some years back. I guess less than 100 (maybe even less than 50) people own one (but I'm just guestimating here). I've never heard a single complaint about the product; but it would be nice to hear from owners as to how these games have performed for them on real hardware, given the issues encountered attempting emulation. 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 26, 2021 Share Posted October 26, 2021 On 10/22/2021 at 5:03 PM, Xuel said: BTW, many thanks to @tebe for sharing the source code. It made patching Bomb Jake a much more tractable problem. I'd completely forgotten about the shared source code; and it's sitting right here on my machine. Otherwise, I would have posted it up with the ROM images. Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 26, 2021 Share Posted October 26, 2021 14 hours ago, MrFish said: Thanks for taking the time on it. It does seem to be a bit slower than the XEX version; but at least it's running without glitches. [Edit] Quote Link to comment Share on other sites More sharing options...
rensoup Posted October 27, 2021 Share Posted October 27, 2021 Here's a weird bug I encountered while testing PoP: As you can see the instruction at $8f3a changes between 2 executions despite no instruction modifying that location. I've included a save state which starts just a few seconds before the crash. On a side note, I've also noticed that sometimes reloading a (quick)state doesn't work: a crash usually occurs straight away and the location is typically in the extended RAM region (or was it extended ROM?)... I'm a little hazy but I'm wondering if perhaps something related to bank switching isn't restored properly ? PopAltirraBug.atstate2 Quote Link to comment Share on other sites More sharing options...
dmsc Posted October 27, 2021 Share Posted October 27, 2021 Hi! 1 hour ago, rensoup said: Here's a weird bug I encountered while testing PoP: As you can see the instruction at $8f3a changes between 2 executions despite no instruction modifying that location. IMHO, you are writing to the cartridge control window (D5DD) and probably activating a cartrdige, so the memory at $8000 to $9FFF changes. Have Fun! 2 2 Quote Link to comment Share on other sites More sharing options...
rensoup Posted October 28, 2021 Share Posted October 28, 2021 32 minutes ago, dmsc said: Hi! IMHO, you are writing to the cartridge control window (D5DD) and probably activating a cartrdige, so the memory at $8000 to $9FFF changes. Have Fun! Thanks I totally forgot $d500 was the cart bank switching ? (Even writing to $D6xx is probably completely wrong) Quote Link to comment Share on other sites More sharing options...
VinsCool Posted October 29, 2021 Share Posted October 29, 2021 I just noticed something interesting a bit earlier tonight. On top is a capture from latest Altirra 4.0-test using the WAV recorder feature, and below is the exact same audio recorded from my PAL 800xl Is it possible that Altirra is emulating audio but outputs the waveforms upside down? Or is it my recording setup that fooled me there? Not like this is a major difference, but comparison side by side got me surprised, because I never noticed this was a thing until now since I happened to compare 2 audio recordings for a friend of mine. 1 Quote Link to comment Share on other sites More sharing options...
