kaloyanm Posted June 17, 2020 Share Posted June 17, 2020 Hello everyone. I am not sure if here is the right place for my question but something come to my possession and I don't even know if it is a retro game console or other animal. Thank you. Quote Link to comment Share on other sites More sharing options...
DavidD Posted June 18, 2020 Share Posted June 18, 2020 That looks more like an NES/Famicom connector to me... but I could be wrong. What makes you think it's an Atari clone device? Quote Link to comment Share on other sites More sharing options...
kaloyanm Posted June 18, 2020 Author Share Posted June 18, 2020 35 minutes ago, DavidD said: That looks more like an NES/Famicom connector to me... but I could be wrong. What makes you think it's an Atari clone device? since I have little knowledge on this matter I tried to use google pictire search to find similar items but alas, this was close I could come up. Quote Link to comment Share on other sites More sharing options...
emerson Posted June 18, 2020 Share Posted June 18, 2020 The cartridge connector is 60 pins according to my count which makes me believe it's a Famicom clone. There are plenty of "famiclone" keyboards floating around with 3rd party word processor carts. Some of them even have parallel port printer capabilities! What I find interesting are the rounded corners on the cartridge cutout where official famicom cartridges typically have a 45 degree chamfer. As for that blown transistor, I would bet its a 5v regulator. Double check the pcb layout in regards to those diodes and capacitors to be sure. Check to make sure those diodes are still good, or just replace them with something a little beefier to be safe. The joystick ports, are those DB9 connectors like an atari or sega genesis controller? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted June 18, 2020 Share Posted June 18, 2020 Can you turn it on? These famiclones usually have built in games. Some countries had weird rules that would get worked around by including educational software. My famiclone + keyboard uses the typical famiclone DB9 connector. Quote Link to comment Share on other sites More sharing options...
kaloyanm Posted June 18, 2020 Author Share Posted June 18, 2020 3 hours ago, emerson said: The joystick ports, are those DB9 connectors like an atari or sega genesis controller? Hey thank you, I am getting close and closer to this mystery. I am still confused by this windows button on the keyboard. Why the heck on a game console is there such thing? I am uploading picture of the game ports. I have no idea which model they are. Quote Link to comment Share on other sites More sharing options...
kaloyanm Posted June 18, 2020 Author Share Posted June 18, 2020 2 hours ago, Gemintronic said: Can you turn it on? These famiclones usually have built in games. Some countries had weird rules that would get worked around by including educational software. My famiclone + keyboard uses the typical famiclone DB9 connector. Unfortunately there is a blown up transistor as emerson pointed out. I am looking for AC charger currently but it is hard since still didn't figure out the parameters. 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted June 18, 2020 Share Posted June 18, 2020 That 4W and PAL-B on the bottom seem to indicate a UK plug at 4w.. but, who knows with these machines. Maybe there's something like an FCC ID further in on those boards. Quote Link to comment Share on other sites More sharing options...
emerson Posted June 18, 2020 Share Posted June 18, 2020 7 hours ago, kaloyanm said: I am uploading picture of the game ports. I have no idea which model they are. I didn't mean a specific model, just a visual comparison was all. My bad. You may be able to get a part number off that blown transistor if the face isn't completely destroyed. Try using some rubbing alcohol and a cotton swab to wet the face. Difficult to read text seems to pop out when the part is wet. The blown transistor looks to be a TO-92 package, and all of the 7805 voltage regulator datasheets I looked at rate the TO-92 variant at 100mA max current output, which seems low for an application like this. Maybe that's why it blew? This is still assuming it's a voltage regulator of course... Perform the following at your own risk. I can't be held responsible for anything bad that happens. It looks like there are 4 wires in the ribbon cable going from the av board to the cart connector board. If I had to guess, those are power, ground, audio and video. Right below where the ribbon cable attaches to the cart connector pcb is a circle that's half white, this is where a capacitor would go and I think it may be for a filter capacitor on the main power rail. If you were to connect 5V DC there with + on the bare half and - on the white half I think this unit would fire up. Quote Link to comment Share on other sites More sharing options...
Stephen Moss Posted June 19, 2020 Share Posted June 19, 2020 I wonder if someone was confuse by the label saying "AC Adaptor Only" and though that meant connecting an AC supply. I cannot be certain without a schematic but I cannot see anything in those images that looks like a rectifier and so I would presume a DC input is required. Quote Link to comment Share on other sites More sharing options...
emerson Posted June 19, 2020 Share Posted June 19, 2020 1 hour ago, Stephen Moss said: I cannot be certain without a schematic but I cannot see anything in those images that looks like a rectifier and so I would presume a DC input is required. If you look behind the blown transistor in the last photo it looks like there is a silicon diode and resistor. I'm guessing this is a half-wave rectifier circuit. After some thought I think a better place to tap into the power bus would be the power switch. Again, do so at your own risk. Quote Link to comment Share on other sites More sharing options...
