+DrVenkman Posted July 15, 2021 Share Posted July 15, 2021 7 minutes ago, hueyjones70 said: Is there a thread that discusses the FN's capabilities and operation. There's an entire FujiNet sub-forum pinned at the top of the A8 section here on AtariAge. Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted July 15, 2021 Share Posted July 15, 2021 Thanks Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted July 24, 2021 Share Posted July 24, 2021 I was happy to get a little soldering done today 10 Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted July 28, 2021 Share Posted July 28, 2021 Interesting logo! https://www.amazon.com/dp/B06XNTCLV5/ref=cm_sw_em_r_mt_dp_4WT029CDDTR6PNHNCFBG 1 5 Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted August 6, 2021 Share Posted August 6, 2021 When I finally get round to building an NTSC NUC+ it will be in this case Needs the details to be painted before I'm calling it done. 10 Quote Link to comment Share on other sites More sharing options...
Bee Posted August 8, 2021 Share Posted August 8, 2021 (edited) Question - There was a earlier part of the thread where the power supply was discussed. I have a battery with a built in solar charger, just needs to get plugged into a panel when charging is needed. It has a 60w USB C output port and I have a cable that will provide 20v to the correct plug type. Would that get regulated down to 5 & 12v? Is it really able to take up to 24v? Thank you Edited August 8, 2021 by Bee Quote Link to comment Share on other sites More sharing options...
+mytek Posted August 8, 2021 Author Share Posted August 8, 2021 16 minutes ago, Bee said: Question - There was a earlier part of the thread where the power supply was discussed. I have a battery with a built in solar charger, just needs to get plugged into a panel when charging is needed. It has a 60w USB C output port and I have a cable that will provide 20v to the correct plug type. Would that get regulated down to 5 & 12v? Well almost correct. Yes there is a 5V regulator for the main logic supply, and a 10V zener for the color adjust circuit. 16 minutes ago, Bee said: Is it really able to take up to 24v? It should. The switching regulator is rated for an input of 28V, and the 10V zener has a 1K current limiting resistor feeding it which should protect it from the extra voltage. EDIT: At a higher input voltage it might require a heat sink for the switching regulator (I'm not sure, but it should be taken under consideration). 1 Quote Link to comment Share on other sites More sharing options...
Bee Posted August 8, 2021 Share Posted August 8, 2021 I will hold off on that test until my 2nd DIY build then. I have a 5 pack of 12v 5A USB C power boards coming with a pocket sized USB C power bank I think will output the 12v. If not I can use it with the larger battery that is fully USB C capable. I'm curious what will show up on the 12v line of the DB port if it's feed 20v at the DC jack. The boards I'm getting could be put in place of the DC jack and fully deliver the 12v 3A of the supply that came with my Brewing Academy unit. Thank you Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted August 11, 2021 Share Posted August 11, 2021 PAL NUC+ finished, NTSC one (the deep purple one above) still to do. 14 Quote Link to comment Share on other sites More sharing options...
+selgus Posted August 11, 2021 Share Posted August 11, 2021 That came out amazing! Fantastic work again! Quote Link to comment Share on other sites More sharing options...
Dinadan67 Posted August 12, 2021 Share Posted August 12, 2021 I like that matte black finish ? Quote Link to comment Share on other sites More sharing options...
Peruchi Posted August 12, 2021 Share Posted August 12, 2021 You're such an artist, Mr. Boswell !! Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted August 12, 2021 Share Posted August 12, 2021 On 8/6/2021 at 12:11 PM, Mr Robot said: When I finally get round to building an NTSC NUC+ it will be in this case Needs the details to be painted before I'm calling it done. You can't have purple Quote Link to comment Share on other sites More sharing options...
ivop Posted August 12, 2021 Share Posted August 12, 2021 (edited) 1 hour ago, orpheuswaking said: You can't have purple Yes you can. Purple, and peach and black Edited August 12, 2021 by ivop 1 1 Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted August 12, 2021 Share Posted August 12, 2021 If I can't keep black for myself, all colours are allowed This one is deep purple, it is going to have a gold atari and embossing with a red/orange/yelow/green/blue diagonal detail at the front next to my white/blue avatar (to reflect my website) 1 Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted August 12, 2021 Share Posted August 12, 2021 27 minutes ago, Mr Robot said: If I can't keep black for myself, all colours are allowed This one is deep purple, it is going to have a gold atari and embossing with a red/orange/yelow/green/blue diagonal detail at the front next to my white/blue avatar (to reflect my website) That sounds really cool. My painting skills suck so I have a feeling mine are all going to be monochrome. I really like that purple though. I may have to have you print me some random other cases in that filament. Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted August 12, 2021 Share Posted August 12, 2021 I rely on the steady hands of my wife to do things like that, I'm far too impatient to do it myself. 2 Quote Link to comment Share on other sites More sharing options...
Frankie Posted August 13, 2021 Share Posted August 13, 2021 I have a NUC and case, can I just get a new top? Quote Link to comment Share on other sites More sharing options...
+orpheuswaking Posted August 13, 2021 Share Posted August 13, 2021 16 hours ago, Frankie said: I have a NUC and case, can I just get a new top? If you are looking for cart functionality then you will need a new fujinet also. TBA will have them available at some point in the future and I believe there is talk of a trade in program for the case tops. Quote Link to comment Share on other sites More sharing options...
+mytek Posted August 13, 2021 Author Share Posted August 13, 2021 13 minutes ago, orpheuswaking said: If you are looking for cart functionality then you will need a new fujinet also. TBA will have them available at some point in the future and I believe there is talk of a trade in program for the case tops. To elaborate on this... you will need a new combo FujiNet/Cart Daughter Board that replaces the FujiNet only version, and a new top lid for the case. As @orpheuswaking pointed out, it's my understanding that when the time comes, @MacRorie of The Brewing Academy will be doing trade-ins for anyone having the FujiNet only boards. Keep in mind that unless you need the cartridge aspect, your existing FujiNet board is perfectly good to stay with, and is pretty much an exact match with the FN circuitry on the new combo board. 1 Quote Link to comment Share on other sites More sharing options...
rsh Posted September 7, 2021 Share Posted September 7, 2021 Any news on when this the CART version will be available??? Quote Link to comment Share on other sites More sharing options...
Mr Robot Posted September 7, 2021 Share Posted September 7, 2021 Supplies of ESP32 modules are very scarce right now, boards are with testers but they need to build them and without the parts its kinda tough. Quote Link to comment Share on other sites More sharing options...
Bee Posted September 11, 2021 Share Posted September 11, 2021 would these 78 help? https://www.adafruit.com/product/4919?gclid=CjwKCAjwp_GJBhBmEiwALWBQkyzxzbFcyir3A8RCyWNjIV7luRGz5lrCdiDZNHxskJ1LbJTcejLN2xoCM80QAvD_BwE Thank you Quote Link to comment Share on other sites More sharing options...
+mytek Posted September 11, 2021 Author Share Posted September 11, 2021 (edited) 4 hours ago, Bee said: would these 78 help? https://www.adafruit.com/product/4919?gclid=CjwKCAjwp_GJBhBmEiwALWBQkyzxzbFcyir3A8RCyWNjIV7luRGz5lrCdiDZNHxskJ1LbJTcejLN2xoCM80QAvD_BwE Those modules do not have any PSRAM. The FujiNets require 16MB of PSRAM, unless I'm mistaken. Correction: FujiNet requires the 16MB Flash/8MB RAM WROVER module - ESP32-WROVER-E (16MB). The link posted above is for the 4MB flash WROOM module which is not interchangeable for the FN application. Edited September 11, 2021 by mytek 1 Quote Link to comment Share on other sites More sharing options...
Bee Posted September 11, 2021 Share Posted September 11, 2021 (edited) @mytek Thank you for the clarification. I found a listing for some here: https://www.aliexpress.com/item/4001264962468.html?src=google&aff_fcid=dea7ee114e80466ab8ea56009167c01c-1631377319505-03202-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=dea7ee114e80466ab8ea56009167c01c-1631377319505-03202-UneMJZVf&terminal_id=7c1f0e89bd364779b7c43de98d9d741c says shipping could be here by 9/22 @Mr Robot How many are you in the market for right now for testing? I'd like to help out if that would move things forward. Thank you Edited September 11, 2021 by Bee 2 Quote Link to comment Share on other sites More sharing options...
