ClausB Posted June 24, 2020 Share Posted June 24, 2020 The 2-bit Gray code is also called "quadrature" encoding, because the two bits are 90° out of phase. The two bits are often called A and B. One trick is to wire A to an edge-triggered interrupt. The interrupt routine would simply INC position if B is high or DEC position if B is low. Simple, but you get less position resolution that way. 1 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted June 24, 2020 Share Posted June 24, 2020 If you (or @tschak909) want to get into the guts of Trak-Ball stuff, Dan Kramer is very active on Facebook and one of the Admins of Trak-Ball fan group as well. For those who don’t know, Dan was the designer of the CX-22 (and the CX-53 Trak-Ball for the 5200) as well. When my 5200 Trak-Ball arrived from eBay DOA, Dan walked me through the schematics and his first suggestion brought it back to life with a single 45 cent IC. 3 Quote Link to comment Share on other sites More sharing options...
manterola Posted September 13, 2021 Share Posted September 13, 2021 On 6/24/2020 at 7:04 AM, ClausB said: One trick is to wire A to an edge-triggered interrupt. The interrupt routine would simply INC position if B is high or DEC position if B is low. Simple, but you get less position resolution that way. I was trying to understand the Missile Command code that manages the Trackball/St Mouse, as it compatible with both true TB mouse and Atari ST. The code is very simple and it is similar to what @ClausB has written: detecting the edges and decide direction using only one bit: LDA $D300 ;PORTA TAX ;SAVE for later EOR TBOLD ;DETECT RISING... AND TBOLD ;...EDGES OF PORTA STX TBOLD ;SAVE FOR NEXT PASS LSR LSR BCC MOUSE.NOMOVE ;NO RISING EDGE BIT1 SO EXIT TXA ;SO BIT1 MOVED FROM 0->1... LSR ;.. REPEAT AND CHECK BIT0 BCC MOUSE.MINUS ;NO RISING EDGE BIT0 SO MOVE RIGHT MOUSE.PLUS ;do something....mouse/tb one direction MOUSE.NOMOVE ;do your pla, rti, etc MOUSE.MINUS ;do something....mouse/tb the other direction The interesting thing about this code is that it is super short and also compatible with both devices as I already said. In missile command is used every 3 or so DLIs with excellent results. In my case, I am using it in all DL lines ($84, in every line of Antic 4). The code linked by @Mathy looks to me that works better in terms of not need to be called that frequently (not really sure, yet), and it makes more logical sense but it only works for st mouse. This was my take on that code: ; 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 TABLA.MOUSE .BYTE 0, 255, 1, 0, 1, 0, 0, 255, 255, 0, 0, 1, 0, 1, 255, 0 LDA $D300 ;PORTA AND #$03 ;KEEP LEFT&RIGHT BITS TAY ;save for later ORA TBOLD ;put new and old bits together side by side (32|10 = OLD|NEW) TAX ;This is my index for the table TYA ;back to bits left&right ASL ;move them to the right ASL STA TBOLD ;save them for next pass LDA TABLA.MOUSE,X BMI MOUSE.MINUS ;1st- check if minus BEQ MOUSE.NOMOVE ;2nd- Check if zero ;3rd, it is not zero (nor negative) so MOUSE.PLUS In conclusion, it seems that the code in Missile Command works with ST Mouse by pure luck , but I might be totally wrong... 2 Quote Link to comment Share on other sites More sharing options...
Rybags Posted September 13, 2021 Share Posted September 13, 2021 (edited) Those devices both work the same - 2 bits per axis on the joystick representing each axis with a grey code. The ST mouse and 7800 sticks are only partly compatible though - the second button goes to a paddle input but it doesn't generate a value. I'm fairly sure there's a mod around for one or both that involves a resistor change that makes the button detectable but still remains compatible on it's original machine. The Amiga mouse also works the same but for whatever reason the bit assignment is different so it's not directly compatible. There were aftermarket mice available for Amiga/ST which had a switch so the proper encoding would be sent to the host. I've not dived into the trakball code in these games but it's fairly likely it's only doing one sample per frame. For more precision you'd want multiple samples. IMO probably the best method would be to do the sampling multiple times during the screen draw then combine and process them during VBlank. Edited September 13, 2021 by Rybags Quote Link to comment Share on other sites More sharing options...
Mathy Posted September 13, 2021 Share Posted September 13, 2021 Hello Rybags, guys The difference between Amiga and ST Mouse is that one direction (IIRC up and down) is reversed. The mod for the ST mouse that let's one read the right button is here on my Special Stuff Page. Sincerely Mathy Quote Link to comment Share on other sites More sharing options...
manterola Posted September 13, 2021 Share Posted September 13, 2021 (edited) Yep, bit 0 and 3 reversed. So interchanging pin 1 and 4 transform an Amiga mouse to Atari. However, I was trying to point out how the routine used in Missile Command works with TBs and mice, two different devices, essentially the same, but with differences in the Atari implementation. Trak-ball and ST mouse are similar but they don't work exactly the same. Trak-ball add some flip flops, while ST mouse does not. The second code posted does not work with CX-22 nor with CX-80. I will keep doing experiments. I am trying to add TB/mouse/driving controller support to and old pong/breakout clone. Edit: BTW, thanks Mathy for the code in your webpage. It was very very good information, and I also allowed me to discover Mega Magazine... nice set of articles... Edited September 13, 2021 by manterola Quote Link to comment Share on other sites More sharing options...
