New versions available
F.G. Kaal
Fred, I use your program, DM2K whenever I reach for a DM. Question, does it format floppies? Just wondering. And also, I have used it on the Geneve to view a directory, but is there a version just for geneve, outside GPL or TI mode?
Thanks so much for your work in this program. I love it
Edited by GDMike
it does, have you hit h for help? or looked at the website at all?
the geneve version hasn't been updated in a while.. gdm2k  and doesn't support cru run the TI version in GPL/rompage
Hi GDMike, Dm2k can format floppies, just press ctrl-f.
A special (new/updated) version for the Geneve is coming soon, there was a slight delay of 12 years ... I don't know what happened ;-)
Edited by F.G. Kaal
  • Like 6
Ahhh...I was blinded by the light, I guess I just never saw that in the help. Duh... sorry bout that.
Thx for clarifying.
5 hours ago, Schmitzi said:
Hi,
I made a .DSK from the new version, and printed the help pages into a PDF, as I always pinup that to the wall  :)
DM2K_v3.2.dsk (Editor/Assembler -> Option #5 -> DSK1.DM2K )
And the song....42 docs printed on the wall, 42 docs printed..pass it around, tadada
Edited by GDMike
  • Haha 2
6 hours ago, 9640News said:
Well, I went to grab the zip file, and the zip file was not found.  Looks like he has the webpage up, but I guess the program is not ready for release yet.
Beery
Which link did you use ?
This one ? Works.
https://www.ti99-geek.nl/Projects/dm2k/Files/dm2k_v32.zip
  • Confused 1
For all Geneve owners ... there is a Gdm2k available at www.ti99-geek.nl in the projects section. This is a native MDOS version of DM2k but with two file lists. This program is finally finished after a pause of 12 years. Don't ask me what happened ... I guess there was to much fun TI stuff to do ;-)
Edited by F.G. Kaal
  • Like 9
  • Thanks 4
I love this update.  Presently using it to do a complete backup of my HFDC drive to a TIPI path.  It removes my need to use DM2K for the TI-99/4A and the special DSK0 usage.
I'm copying right now my hard drive on one system.  With my other system, I went and tested how many files it would catalog in a TIPI directory with 2800+ files.  It only got 241.  Realistically though, I would manage a directory like that from a Windows share.
I like the way you can tab from the left to the right window.  If you can implement the <PG UP> <PG DN> keys at some point in the future, that would be nice.
Do you mean the <ctrl-x>, <ctrl-e> keys (which is allready there) or do you mean the real <PG UP> and <PG DN> keys for that functionality?
btw, just noticed that <PG UP> equals fctn-6 and <PG DN> equals some other fctn-? (4 maybe). May I must get rid of that command (fctn-6) mode and use page-up/page-dn keys for what it says it is.
This version has a 4Kb circulair buffer for storing directory names while copying/moving/deleting files. Let me know if it is enough for letting Gdm2k handle your directory structure ! ... ow ... you allready did I see in the above message. Thanks for montioning it.
Fred ?
Edited by F.G. Kaal
On 3/6/2021 at 11:53 PM, InsaneMultitasker said:
Maybe add a warning if GDM2K encounters a folder which exceeds the typical TI file/folder limit?
Looking forward to trying this on my Geneve :)
I'm complying to the TI maximum of 127 files and 114 sub directories. Must add extra bells and whistles for that. (not impossible though, I add this to the list).
Fred ?
Yes, your circular buffer seems to be working well.  The <PG UP> and <PG DN> addition would be nice.  Just more natural that way than the CTRL E and CTRL X combo.
Fred,
Gotta say I am loving DM2K for the Geneve even more.  I figured out earlier today, that if I hit <ENTER> where it asks for a default path, it will default to the current path.  Then, I thought wouldn't it be nice if I just entered something like:
DM2K E: J:
And sure enough, you had entered the ability to pass dual paths.  That may be mentioned somewhere, but it's not something I have come across myself.  Anyways, great job on the update!!!!!
Beery
  • Like 7
Fred, discovered in the docs the command line passing as I showed above was indeed there.
I did see something I could not find in the Help key press.  I did not see the command to create a directory though I did see it on your website for GDM2K.  I will have to also go back and compare to see if some of the other function key presses are listed as I did not recall seeing the F6 keypress for eXecute File command.  Not quite sure if that launches the current program the cursor is on or it asks for a file until I try it.  Either way, it was not something I recall seeing in the help menu.
Beery
The new DM2K works in the BATcomputer, (NanoPEB, F18A, USB keyboard).
Pleased to report that TI-Dir v8.2a works well in my Win98 system.  Much appreciate being able to run it there.
Only problem is that copying "file.s" to "FILE;S", the computer fills-in FILE but leaves-off the ";S" part.  In my WinXP system it fills-in "FILE;S", so it may be a Win98 thing.  I can live with it!
A more serious problem is that when I copied a blank 400K "floppy" image from a CF to a .dsk file, the resulting image file showed up as a 720 sector image.  This in a Win2000 system; haven't yet set up the Win98 to read CF boards.
K-R.
Edited by Kchula-Rrit
Forgot to add Win2K for reading disk image.
April fool releases:
New version of DM2K v3.3 available
and
New version of GDM2K v3.2 available
also added this version to the Editor/Assembler module EA5 r9
and added this version to the Flashrom/FinalGrom module download.
Added page up/page down keys to Gdm2k. Removed the F6 command mode (clashes with page-up)
Made the functioning of the commands C(opy) / M(ove) / D(elete) in Dm2k simulair to Gdm2k:
Using these functions when no files are selected (with the insert / fctn-2 key) then only to file/directory where the cursor points to is handled.
If one or more files/directories are selected (marked with a + character) then only these files/directories are handled.
The previous version of Dm2k also included the file at the cursor location and I think that this was very confusing.
See www.ti99-geek.nl
enjoy,
Fred ;-)
  • Like 4
  • Thanks 3
Fred, we have a weird issue with DU2K or the DSR when running in MAME. Maybe this is also the case on real iron.
@9640News tried to connect two IDE drives and to set up four partitions on each drive. However, DU2K never shows 8 partitions; the 8th one is not accessible. When you remove a partition from drive one, the 4th partition of the second drive is accessible again. When you add a fourth partition to drive 1, the fourth partition of drive 2 disappears again.
  • Sad 1
I will check this on the real iron ;-)
After a long and thorough investigation of Du2k of about 5 minutes a came to the conclusion that there is nothing wrong wint Du2k.
So guess what !
