+mytek Posted July 16, 2020 Author Share Posted July 16, 2020 On 7/15/2020 at 4:15 AM, HiassofT said: I had a quick go at it and added options to only verify and fix 16k XL/XE OS ROM checksums to my patchrom tool. I've attached a win32 console executable. Thanks Hias . The new version of your patchrom program did the trick for me. Here's a stock XEGS ROM that has had the Self Test routines replaced with the 1200XL RAINBOW screen, has HiSpeed OS routines incorporated, and has an updated checksum. XEGS_RAINBOW_HiPatch.rom This is still a 32Kbyte ROM image, so will work in a stock XEGS system. 4 2 Quote Link to comment Share on other sites More sharing options...
+mytek Posted July 17, 2020 Author Share Posted July 17, 2020 I used option -k to leave out the keyboard IRQ routines in that XEGS ROM image I just posted. Was wondering what impact it would have if I had let them get patched? Do you lose compatibility with any applications by doing so? Quote Link to comment Share on other sites More sharing options...
HiassofT Posted July 17, 2020 Share Posted July 17, 2020 -k disables hotkey support - I usually have that enabled. Especially SHIFT+CONTROL+S is quite handy if some program trampled over the stack area or if you later power up/enable another drive. So far no one reported compatibility issues with hotkey support enabled. * hotkeys: The keyboard IRQ routine of the OS is patched and you can control the SIO patch using various keystrokes: SHIFT+CONTROL+S Clear SIO speed table and enable highspeed SIO SHIFT+CONTROL+N Disable highspeed SIO (normal speed) SHIFT+CONTROL+H Enable highspeed SIO SHIFT+CONTROL+DEL Coldstart Atari so long, Hias 3 1 Quote Link to comment Share on other sites More sharing options...
