walter_J64bit Posted September 3, 2020 Share Posted September 3, 2020 What size is the USB port on the Skunkboard? The port that's used to flash the Skunkboard. I think, I need a new cable. Quote Link to comment Share on other sites More sharing options...
+cubanismo Posted September 3, 2020 Share Posted September 3, 2020 It's a mini USB connector, *not* the same as a micro USB connector that most phones used prior to USB-c. It's slightly thicker. Here's the exact part I used on my build: https://www.digikey.com/product-detail/en/molex/0548190572/WM17116CT-ND/773804 This cable should work: https://www.amazon.com/dp/B00NH11N5A 1 Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted September 3, 2020 Author Share Posted September 3, 2020 9 hours ago, cubanismo said: It's a mini USB connector, *not* the same as a micro USB connector that most phones used prior to USB-c. It's slightly thicker. Here's the exact part I used on my build: https://www.digikey.com/product-detail/en/molex/0548190572/WM17116CT-ND/773804 This cable should work: https://www.amazon.com/dp/B00NH11N5A Thanks! Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted September 4, 2020 Author Share Posted September 4, 2020 (edited) Ok I haven't got a new cable yet but this what I'm getting "Can't open EZ-HOST" can anyone help? skun_cant_open.bmp Edited September 4, 2020 by walter_J64bit Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted September 4, 2020 Share Posted September 4, 2020 I recall having trouble with the GUI thing, although possible not that and gave up as I found the command line more reliable. One problem the Skunboard has under Windows 10 is a missing USB driver, which may be related to your problem. If you are using windows 10 and have not already done so use Zadig and install the libusb-win32 (v1.2.6.0) to get the Skunkboard talking to your PC and see if that helps. You might have to restart after installing for it to work. Quote Link to comment Share on other sites More sharing options...
walter_J64bit Posted September 4, 2020 Author Share Posted September 4, 2020 I'm in Windows XP. Quote Link to comment Share on other sites More sharing options...
