+Andrew Davie Posted September 8, 2020 Share Posted September 8, 2020 @Thomas Jentzsch has just corrected a bug in Stella which prevented the attached binary from running properly. The strange thing is; PlusCart also won't run this binary properly. It's to do with RAM bank usage - this binary is kicking a particular bank over the 16k boundary, and when that happens it crashes. I suspect there is also a similar bug in the 3E+ implementation of PlusCart chess.bin.zip Versions of Chess which use less search depth (i.e, most of the versions posted so far) will run OK. Link to comment Share on other sites More sharing options...
