+Andrew Davie Posted September 11, 2020 Share Posted September 11, 2020 The reason some that 3E+ chess versions do not work on PlusCart/UnoCart is apparently because the 3E+ driver limits RAM 32 banks. If so, this is incorrect. 3E+ handles up to 64 RAM banks (32KiB total). Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 11, 2020 Share Posted September 11, 2020 5 hours ago, Andrew Davie said: The reason some that 3E+ chess versions do not work on PlusCart/UnoCart is apparently because the 3E+ driver limits RAM 32 banks. If so, this is incorrect. 3E+ handles up to 64 RAM banks (32KiB total). the code don't lie: https://gitlab.com/firmaplus/atari-2600-pluscart/-/blob/master/source/STM32firmware/PlusCart/Src/cartridge_emulation.c#L591 https://github.com/DirtyHairy/UnoCart-2600/blob/master/source/STM32firmware/Atari2600Cart/src/cartridge_3ep.c#L20 I'll fix that for the PlusCart in the next release(s) 1 Link to comment Share on other sites More sharing options...
Thomas Jentzsch Posted September 12, 2020 Share Posted September 12, 2020 That one is much more obvious than the bug we had in Stella. I wonder were the 32 bank limit originally came from. Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 12, 2020 Share Posted September 12, 2020 should be "fixed" in the new release: Link to comment Share on other sites More sharing options...
+Andrew Davie Posted September 12, 2020 Author Share Posted September 12, 2020 4 hours ago, Thomas Jentzsch said: That one is much more obvious than the bug we had in Stella. I wonder were the 32 bank limit originally came from. It's because we're used to thinking in 1K chunks, not 512 byte chunks. So when 64K banks was "converted" to 32K actual RAM, at some point we/someone was still thinking 32 chunks of 1K to make 32K And thus, when setting the number of banks, it was set to 32. Pretty straightforward and easy to make error, I think. Link to comment Share on other sites More sharing options...
+Andrew Davie Posted September 12, 2020 Author Share Posted September 12, 2020 Have tested, and appears to be working well - thank you. Link to comment Share on other sites More sharing options...
