+Vorticon Posted December 17, 2020 Author Share Posted December 17, 2020 16 minutes ago, arcadeshopper said: you could also try matt's tester here: https://github.com/jedimatt42/ti994a-32kmemtest it does sams and tests more extensively than the amstest4 does Do you happen to have a built cart image by any chance? Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4701715 Share on other sites More sharing options...
+arcadeshopper Posted December 17, 2020 Share Posted December 17, 2020 16 minutes ago, Vorticon said: Do you happen to have a built cart image by any chance? https://github.com/jedimatt42/ti994a-32kmemtest/releases 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4701724 Share on other sites More sharing options...
+Ksarul Posted December 17, 2020 Share Posted December 17, 2020 The 612 and the 688 are the two chips that have caused the most problems with the 100 or so boards I've built. BTW, you can use a 25LS2521 in place of the 74LS688, as it is an equivalent replacement (and in my experience, more stable). 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4701737 Share on other sites More sharing options...
+TheBF Posted December 17, 2020 Share Posted December 17, 2020 1 hour ago, Vorticon said: Great program! You've got to love Forth! I am seeing some inconsistencies however: AMSR4 reports only 512K of RAM (after I reflowed the solder joints, the RAM size went from 1024 to 512 irrespective of the position of the SRAM chips), but SAMSTESTER seems to see all of the memory. The REGTEST passes. SAMSTESTER goes only to segment #15. Shouldn't there be a segment #16 to account for 1024K? It starts at segment #1, not #0. AMSR4 is locking up at random memory pages. Not so with SAMSTESTER Thanks. I am happy it is has some use to someone. I call the first 64K segment 0. I only activate segments 1 .. 15 so not to tromp on the running system by accident. So its Option Base 0 thinking. (which can get me into trouble sometimes) Not sure about the lock-up. My method is to fill the entire 64K segment with the pattern byte and also make a reference 4K buffer filled with the same pattern. Then use a Forth word COMPARE ( addr1,len1,addr2,len2) on each 4K chunk of the active segment. I will look and see what could hang it up. Might be hard to find without a broken SAMS board. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4701769 Share on other sites More sharing options...
+Vorticon Posted December 17, 2020 Author Share Posted December 17, 2020 6 hours ago, Ksarul said: The 612 and the 688 are the two chips that have caused the most problems with the 100 or so boards I've built. BTW, you can use a 25LS2521 in place of the 74LS688, as it is an equivalent replacement (and in my experience, more stable). The 688 is one of the chips not in my programmer's library, so I was not able to test it. Best replace it as well I suppose with the 25LS2521. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4702026 Share on other sites More sharing options...
+Vorticon Posted December 17, 2020 Author Share Posted December 17, 2020 5 hours ago, TheBF said: Thanks. I am happy it is has some use to someone. I call the first 64K segment 0. I only activate segments 1 .. 15 so not to tromp on the running system by accident. So its Option Base 0 thinking. (which can get me into trouble sometimes) Not sure about the lock-up. My method is to fill the entire 64K segment with the pattern byte and also make a reference 4K buffer filled with the same pattern. Then use a Forth word COMPARE ( addr1,len1,addr2,len2) on each 4K chunk of the active segment. I will look and see what could hang it up. Might be hard to find without a broken SAMS board. There definitely seems to be an issue with SAMSTESTER when it comes to detecting the size of the RAM on the SAMS card. Both Matt's Expansion Memory Tester and AMSR4 are reporting 512K, whereas SAMSTESTER is seeing 1024K. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4702030 Share on other sites More sharing options...
+TheBF Posted December 18, 2020 Share Posted December 18, 2020 3 hours ago, Vorticon said: There definitely seems to be an issue with SAMSTESTER when it comes to detecting the size of the RAM on the SAMS card. Both Matt's Expansion Memory Tester and AMSR4 are reporting 512K, whereas SAMSTESTER is seeing 1024K. Ok. I was playing with it today and trying to do some more testing by putting bad bytes into SAMS and seeing if they were picked up. It worked at that level. As I write this I have an idea. I need to erase my CPU RAM buffer each time before I page in new SAMS page . Hang on I will get you another version. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4702223 Share on other sites More sharing options...
+TheBF Posted December 18, 2020 Share Posted December 18, 2020 When you turn over rocks you find bugs. I made some progress but not ready for prime time yet. I will keep at it tomorrow as time permits. Fortunately you have something that works better now. Thanks for being the Alpha tester of the tester. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4702295 Share on other sites More sharing options...
+TheBF Posted December 19, 2020 Share Posted December 19, 2020 Well.. . it turns out making a SAMS memory test is trickier than I realized. This version still does not test segment #0 ( the lowest 64K) so it's still not comprehensive but seems show if SAMS if working or not. The method is: Use >3000 as the SAMS window. The default CPU RAM at >3000 is filled with >BF to identify it. Keep a 4K buffer at >2000 filled with >AA as a reference In each 4K page copy the reference buffer into SAMS Compare the SAMS page to the reference buffer, report result. Turn off the SAMS mapper Confirm that the default RAM page is >BF to test that pages are swapping in and out Turn on SAMS and re-write the SAMS memory page with >55 (>AA inverted) Compute a simple checksum on the SAMS memory, report result. I also tested it on real hardware by sending it over RS232 to Camel99 Forth TTY. Seems to work the same. On Classic 99 with SAMS disabled, it aborts on the first test because the memory at >3000 does not change when the mapper is turned off. Might be useful now to someone. It was certainly educational for me. This version is also smaller because I remove the 4K static buffer in the program space and replaced it with a buffer at >2000..2FFF. Spoiler \ test sams card in 64K segments NEEDS DUMP FROM DSK1.TOOLS NEEDS PAGED FROM DSK1.SAMSFTH NEEDS SDUMP FROM DSK1.SAMSDUMP NEEDS COMPARE FROM DSK1.COMPARE NEEDS U.R FROM DSK1.UDOTR MARKER /SAMSTEST \ command to remove everything when you are done. HEX 7FFF CONSTANT 32K FFFF CONSTANT 64K 1000 CONSTANT 4K VARIABLE FATAL VARIABLE PAT \ remember the pattern we are using : ?FATAL ( flag -- ) FATAL @ AND IF CR ." Stopped on failure" ABORT THEN ; : ?BREAK ?TERMINAL ABORT" *HALTED*" ; : ERASE 0 FILL ; 2000 CONSTANT PBUFFER \ reference copy of the pattern we are testing CODE MOVE16 ( addr1 addr2 len -- ) \ fast move 16bit cells C036 , C076 , C104 , 1306 , 0584 , 0244 , FFFE , CC31 , 0644 , 15FD , C136 , NEXT, ENDCODE : BINARY 2 BASE ! ; : .BIN ( c -- ) BASE @ >R BINARY 8 U.R R> BASE ! ; : .HEX ( c -- ) BASE @ >R HEX 4 U.R R> BASE ! ; : .PATTERN ( c -- ) DUP .HEX ." (" .BIN ." )" ; : .ADDR ( addr) HEX 0 <# # # # # [CHAR] > HOLD #> TYPE SPACE ; : .RESULT ( ? ) DUP 0= IF ." PASS" ELSE ." FAIL" THEN ?FATAL ; : FILLREFBUFF PBUFFER 4K PAT @ FILL ; : SETPATTERN ( char -- ) PAT ! CR ." Bit Pattern = " PAT @ .BIN FILLREFBUFF CR ; : FILLTEST ( SAMSaddr -- ?) PAGED ( swap in the SAMS page) 3000 @ BFBF = ABORT" Mapper not working" \ test if CPU RAM is there PBUFFER OVER 4K MOVE16 PBUFFER 4K S= ; : CHKSUM ( addr len -- n) 0 -ROT BOUNDS DO I @ + LOOP ; : ERASETEST ( addr -- ?) PAGED DUP 4K 55 FILL 4K CHKSUM 5000 <> ; : TESTSEG ( seg# -- ) SEGMENT CR ." Pattern= " PAT @ .PATTERN CR ." Address Fill Rewrite " 64K 0 DO CR I .ADDR 5 SPACES I FILLTEST .RESULT 5 SPACES I ERASETEST .RESULT ?BREAK 4K +LOOP ; DECIMAL : SAMSTEST PAGE CR ." SAMS Card memory test" CR ." ---------------------" 16 1 DO CR CR ." *SEGMENT*" DECIMAL I 3 .R CR I TESTSEG LOOP ; ( 58 secs) HEX AA SETPATTERN : REPTEST ( SEG# -- ) SEGMENT BEGIN PAGE ." SAMS 64K Repeat Test" CR ." --------------------" CR ." *SEGMENT*" DECIMAL SEG @ 3 .R 0 2 AT-XY CR SEG @ TESTSEG PAT 1+! FILLREFBUFF ?BREAK AGAIN ; HEX : REGTEST ( -- ) 1E00 'R12 ! \ select SAMS card CRU address SAMS-OFF \ mapper off 0SBO \ turn on register memory 4000 PAD 20 MOVE \ save the registers CR ." Should see FFFF" 4000 20 FF FILL 4000 20 DUMP CR ." Should see AAAA" 4000 20 AA FILL 4000 20 DUMP CR ." Restoring registers" PAD 4000 20 MOVE \ restore registers 0SBZ SAMS-ON ; : HELP PAGE ." * SAMS 1Mb TESTER Help *" CR ." --------------------------" CR ." HEX ( xx) SETPATTERN" CR ." sets bit pattern used" CR CR ." ( seg#) SEGMENT sets segment" CR CR ." ( seg#) REPTEST Test seg# until BREAK" CR CR ." SAMSTEST test all segments" CR CR ." ( addr len) SDUMP dump SAMS memory" CR CR ." FATAL ON breaks on error" CR ." FATAL OFF no break on error" CR CR ." REGTEST " CR ." HELP show this screen" CR ." BYE leave the program" ; : COLD WARM PAGE ." SAMS Tester V1.6 @theBF 2020" CR ." HELP to see commands CR ." Initializing..." HEX AA SETPATTERN SAMS-OFF 3000 4K BF FILL \ fill non-sams page with BF SAMSINI SAMS-ON ABORT ; LOCK INCLUDE DSK1.SAVESYS ' COLD SAVESYS DSK2.SAMSTESTER EDIT: ZIP file removed. See later posts for corrected version SAMSTEST16.ZIP 3 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4702926 Share on other sites More sharing options...
+FALCOR4 Posted December 21, 2020 Share Posted December 21, 2020 One other tid bit of information that may help. The top SRAM on the PCB is the lower half of the total memory and the bottom SRAM IC is the upper half of total memory. If a test program makes it through the first half of memory and then flags errors afterwards then it is usually the bottom memory chip on the PCB. If the software doesn't function at all or errors out somewhere in the lower half of memory then it may be the top SRAM IC. In that case you could swap ICs and try again. 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4704881 Share on other sites More sharing options...
+Vorticon Posted December 21, 2020 Author Share Posted December 21, 2020 36 minutes ago, FALCOR4 said: One other tid bit of information that may help. The top SRAM on the PCB is the lower half of the total memory and the bottom SRAM IC is the upper half of total memory. If a test program makes it through the first half of memory and then flags errors afterwards then it is usually the bottom memory chip on the PCB. If the software doesn't function at all or errors out somewhere in the lower half of memory then it may be the top SRAM IC. In that case you could swap ICs and try again. By top and bottom, do you mean lowest and highest address respectively or the other way around? This is always a source of confusion for me as I don't know what the correct terminology is. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4704904 Share on other sites More sharing options...
+Vorticon Posted December 21, 2020 Author Share Posted December 21, 2020 On 12/18/2020 at 7:11 PM, TheBF said: Well.. . it turns out making a SAMS memory test is trickier than I realized. This version still does not test segment #0 ( the lowest 64K) so it's still not comprehensive but seems show if SAMS if working or not. I tested it out and this time around it does not get past the "Mapper not working?" message. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4704905 Share on other sites More sharing options...
+TheBF Posted December 21, 2020 Share Posted December 21, 2020 So that means your board is not switching pages in and out at least at address >3000 where I placed the SAMS window. The was a double check I put in to prove that the hardware was actually doing something. The test is write AA into a SAMS page. Then turn off the mapper (SBZ 1) and test to see the default >3000 memory page is there. If I don't see >BFBF at >3000 that is the error. So in hardware terms that might point to the 612 chip but I am out on a limb here. I have only skimmed the schematic on that board. 1 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4704930 Share on other sites More sharing options...
atrax27407 Posted December 21, 2020 Share Posted December 21, 2020 V 1.6 crashes immediately after start on real gear. Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4705225 Share on other sites More sharing options...
+TheBF Posted December 21, 2020 Share Posted December 21, 2020 I only loaded it over RS232 Forth. I will transfer it to my floppy drive and give it a run. Thanks for the feedback. 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4705260 Share on other sites More sharing options...
+TheBF Posted December 22, 2020 Share Posted December 22, 2020 I hope the third time is the charm. So I forgot that to initialize a real card you have to init both bytes of the SAMS registers. BUT... if you do that in Classic99 it dies. I believe Classic can use the 2nd byte to compute addresses for bigger cards and so things go wrong. I have done my due diligence and loaded this onto my hardware with 2 floppy drives and 1M Sams card. It seems to work as I expected. There is a lot of re-writing internally to the test programs, factoring out the pieces so I could test them at the real console but the user doesn't see that. Things to know: I have switched up the program to use mapped pages so it is testing pages 16 to 255. That probably makes more sense to people. The SDUMP command is still SEGEMENT based so you set the segment and then you can dump any part of that 64K chunk of SAMS. (Like this: 5 SEGMENT 6FFF 100 SDUMP ) The test program commands return to base 10 when they complete. If you used the HEX command and start a program, then BREAK out of the program, the interpreter will remain in HEX. Change that with the DECIMAL command if you need to. The repeating test program REPTEST now takes a 1st page and a last page as input parameters. Remember they go on the left side of the command. This lets you repeat a test on a section of the board over and over. Example: HEX 40 50 REPTEST SAMSTESTER.ZIP 2 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4705365 Share on other sites More sharing options...
Tursi Posted December 22, 2020 Share Posted December 22, 2020 1 hour ago, TheBF said: BUT... if you do that in Classic99 it dies. I believe Classic can use the 2nd byte to compute addresses for bigger cards and so things go wrong. Apologies, yes, Classic99 has a 32MB AMS card. I know non-standard breaks things, but I always expected one of the two writes in a word to be ignored on real hardware? I don't have a lot of information on the device, is my assumption wrong? 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4705402 Share on other sites More sharing options...
+TheBF Posted December 22, 2020 Share Posted December 22, 2020 From what I can see yes. I init the registers with a single byte and all is good on classic99. But it doesn't work on a real 1M card. 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4705416 Share on other sites More sharing options...
GDMike Posted December 22, 2020 Share Posted December 22, 2020 (edited) I ran this and got hung up at>005E., But I rebooted and it was fine afterwards. Edited December 22, 2020 by GDMike Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4705694 Share on other sites More sharing options...
+TheBF Posted December 22, 2020 Share Posted December 22, 2020 3 hours ago, GDMike said: I ran this and got hung up at>005E., But I rebooted and it was fine afterwards. Did it actually stop or did it just report a failure? 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4705815 Share on other sites More sharing options...
GDMike Posted December 22, 2020 Share Posted December 22, 2020 Nahh,no error reported, it hung froze. I didn't shut down the SAMs card though beforeI restarted the program. And after Sam's tester started up, it hit me like my ex wife in a dream, dang I should of shut down the PEB! But was too late the dream was over. And it ran the whole test out just fine. 1 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4705825 Share on other sites More sharing options...
+jedimatt42 Posted December 23, 2020 Share Posted December 23, 2020 Maybe interestingly... My SAMS decided to hate me yesterday, for cheating on it with my sideport 32k... Now it just won't stay off the databus... However, if I pull the '688 chip out, the mapper can't be activated, and it behaves like a healthy 32K card. I think, this indicates the '688 is faulty. That or the recipient of the comparator output. 1 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4706164 Share on other sites More sharing options...
+Vorticon Posted December 23, 2020 Author Share Posted December 23, 2020 10 hours ago, jedimatt42 said: Maybe interestingly... My SAMS decided to hate me yesterday, for cheating on it with my sideport 32k... Now it just won't stay off the databus... However, if I pull the '688 chip out, the mapper can't be activated, and it behaves like a healthy 32K card. I think, this indicates the '688 is faulty. That or the recipient of the comparator output. Is your card a Fetzner one or the old generation? I was chatting with Richard Bell about this and he had never seen an old generation card fail, until mine did after 25 years of nearly daily use... 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4706480 Share on other sites More sharing options...
+Ksarul Posted December 23, 2020 Share Posted December 23, 2020 I haven't had any boards of the new generation fail (yet). But I have had to carefully test each one I build to make sure the 688 and the 612 were working as designed, as both of those chips seem to have higher initial failure rates than the other LS chips on the board. As already noted, I started using 25LS2521s in place of the 74LS688s early on, and I've had no problems with them at all (while about a quarter of the 688s I bought at the beginning failed immediately or during the burn-in). 2 1 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4706587 Share on other sites More sharing options...
+FALCOR4 Posted December 23, 2020 Share Posted December 23, 2020 On 12/21/2020 at 9:22 PM, Tursi said: Apologies, yes, Classic99 has a 32MB AMS card. I know non-standard breaks things, but I always expected one of the two writes in a word to be ignored on real hardware? I don't have a lot of information on the device, is my assumption wrong? On the 256k and 1M cards you only need to send one byte in the MSByte of a WORD. In the 4M and above cards you need to send two bytes in a word; the 1M bank number in the LSByte and the page number in the MSByte. The LS612 always overwrites the LSByte write with the MSByte write. On the 4M and above cards the LSByte is latched and presented to the LS612 on the MSByte write cycle. And on the larger cards, you only get the page number, duplicated in the MSByte and LSByte, when you read back a register. The latch containing the bank number does not read back on the data bus. SAMS registers explained_Srt_AP edits.rtf 3 Quote Link to comment https://forums.atariage.com/topic/314575-sams-card-troubles/page/2/#findComment-4706597 Share on other sites More sharing options...
