tschak909 Posted July 26, 2023 Share Posted July 26, 2023 1 minute ago, FractalCZ said: What a timing I have! Thank you Well, you asked, so we did. -Thom Quote Link to comment Share on other sites More sharing options...
darwinmac Posted July 26, 2023 Share Posted July 26, 2023 2 hours ago, FractalCZ said: What a timing I have! Thank you You may need to run a command in order to exclude it from quarantine. It’s been a while since I set up my TNFS server on my M1 MacBook Air. I don’t think Thom runs macOS so one of us Mac users will need to help out if you can’t find the command by searching Google. That’s what I think I had to do. Bob C Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted July 27, 2023 Share Posted July 27, 2023 10 hours ago, darwinmac said: You may need to run a command in order to exclude it from quarantine. The easy way to do this is to control-click the executable in the Finder, select "Open" from the drop-down, and then "Open" from the security warning dialog. This only needs to be done once per download. (Source: the asterisk at the bottom of this Apple Support page) 1 Quote Link to comment Share on other sites More sharing options...
darwinmac Posted July 27, 2023 Share Posted July 27, 2023 8 hours ago, Eyvind Bernhardsen said: The easy way to do this is to control-click the executable in the Finder, select "Open" from the drop-down, and then "Open" from the security warning dialog. This only needs to be done once per download. (Source: the asterisk at the bottom of this Apple Support page) Unfortunately, I’ve tried that with executables and, unlike application packages, it doesn’t work for me. I usually have to run the “xattr” command to remove the alert that stops the executable from running. For packages, your method has always worked for me. Bob C Quote Link to comment Share on other sites More sharing options...
+Eyvind Bernhardsen Posted July 27, 2023 Share Posted July 27, 2023 5 hours ago, darwinmac said: Unfortunately, I’ve tried that with executables and, unlike application packages, it doesn’t work for me. Oh, that’s interesting. This method works fine for me with both executables and app packages, but if you do need to use the terminal, the command is sudo xattr -d com.apple.quarantine tnfsd 3 Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 19, 2023 Share Posted August 19, 2023 Any news about TNFS for ARM Mac? Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 19, 2023 Share Posted August 19, 2023 8 hours ago, FractalCZ said: Any news about TNFS for ARM Mac? try this and report if it runs or not tnfsd.m1mac 1 Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 19, 2023 Share Posted August 19, 2023 1 hour ago, mozzwald said: try this and report if it runs or not tnfsd.m1mac 72.13 kB · 0 downloads Thank you. Will try it asap (probably tonight). Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 19, 2023 Share Posted August 19, 2023 ...how am I supposed to use this file? Quote Link to comment Share on other sites More sharing options...
+bhall408 Posted August 19, 2023 Share Posted August 19, 2023 10 minutes ago, FractalCZ said: ...how am I supposed to use this file? You run it from the Mac command line (ie, the "Terminal" app in your utilities folder in the apps folder). I don't recall the parameters off the top of my head, but there was documentation somewhere on it. You need to specify what folder to share as the mount point as I recall. I last ran it when I had an intel Mac. I haven't tried the Arm version myself yet. Once running, it stays running in the background until you quit it or restart your Mac. Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 19, 2023 Share Posted August 19, 2023 14 minutes ago, FractalCZ said: ...how am I supposed to use this file? it's a binary program. make it executable and run it Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 19, 2023 Share Posted August 19, 2023 2 minutes ago, bhall408 said: You run it from the Mac command line (ie, the "Terminal" app in your utilities folder in the apps folder). I don't recall the parameters off the top of my head, but there was documentation somewhere on it. You need to specify what folder to share as the mount point as I recall. I last ran it when I had an intel Mac. I haven't tried the Arm version myself yet. Once running, it stays running in the background until you quit it or restart your Mac. I don't see any documentation at all. It's all so sketchy and I don't get it why is such a problem to drop a few lines on how to use it. But thank you anyway for pointing me to the terminal Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 19, 2023 Share Posted August 19, 2023 1 minute ago, mozzwald said: it's a binary program. make it executable and run it How do I make it executable? Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted August 19, 2023 Share Posted August 19, 2023 4 minutes ago, FractalCZ said: How do I make it executable? `chmod +x tnfsd.m1mac' should do it (without the quotes). Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 19, 2023 Share Posted August 19, 2023 1 minute ago, x=usr(1536) said: `chmod +x tnfsd.macos.amd64' should do it (without the quotes). Tried that but nothing happened (error message or "new file") Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted August 19, 2023 Share Posted August 19, 2023 Just now, FractalCZ said: Tried that but nothing happened (error message or "new file") Are you in the same directory as the file? Is the file that you're using the one that was attached above in the thread, or is it one that you downloaded? Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 19, 2023 Share Posted August 19, 2023 1 minute ago, x=usr(1536) said: Are you in the same directory as the file? Is the file that you're using the one that was attached above in the thread, or is it one that you downloaded? Yes, I'm in the Desktop folder. And I've downloaded the m1mac file so I changed the prompt to match. but still nothing Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted August 19, 2023 Share Posted August 19, 2023 Try `chmod +x ./tnfsd.m1mac' (still without the quotes). Note the dot and slash before the filename. If it works, you shouldn't receive any sort of message - you'll just get another prompt. Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 19, 2023 Share Posted August 19, 2023 5 minutes ago, x=usr(1536) said: Try `chmod +x ./tnfsd.m1mac' (still without the quotes). Note the dot and slash before the filename. If it works, you shouldn't receive any sort of message - you'll just get another prompt. Yes, I jut got another prompt and nothing else happened. Quote Link to comment Share on other sites More sharing options...
mozzwald Posted August 19, 2023 Share Posted August 19, 2023 5 minutes ago, FractalCZ said: Yes, I jut got another prompt and nothing else happened. great. now just run the program like so: ./tnfsd.m1mac /path/to/your/atari/files and replace the path with a real path to the files you want available on your tnfs server. Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 19, 2023 Share Posted August 19, 2023 8 minutes ago, mozzwald said: great. now just run the program like so: ./tnfsd.m1mac /path/to/your/atari/files and replace the path with a real path to the files you want available on your tnfs server. Ha! Looks like it works! Starting tnfsd version 20.1115.2 on port 16384 using root directory "blablabla" So it's running until I close the terminal window? Quote Link to comment Share on other sites More sharing options...
+x=usr(1536) Posted August 19, 2023 Share Posted August 19, 2023 43 minutes ago, FractalCZ said: Ha! Looks like it works! Starting tnfsd version 20.1115.2 on port 16384 using root directory "blablabla" Cool 43 minutes ago, FractalCZ said: So it's running until I close the terminal window? Yep! Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 20, 2023 Share Posted August 20, 2023 9 hours ago, mozzwald said: great. now just run the program like so: ./tnfsd.m1mac /path/to/your/atari/files and replace the path with a real path to the files you want available on your tnfs server. Aha! And do I have to run that after every restart? Quote Link to comment Share on other sites More sharing options...
FractalCZ Posted August 20, 2023 Share Posted August 20, 2023 Thank you all sooo much guys! Quote Link to comment Share on other sites More sharing options...
darwinmac Posted August 20, 2023 Share Posted August 20, 2023 45 minutes ago, FractalCZ said: Aha! And do I have to run that after every restart? That’s correct. To have the tnfsd daemon run automatically on restart, I think you’ll need to add it to launchd. I haven’t had the time to make it work yet. Bob C Quote Link to comment Share on other sites More sharing options...
