Inty Clock?
Hi -
Was wondering how on earth I could go about running a minute and second clock in game. Unlike a sports game where the clock ticks down from 20 minutes, for example, I want it to start at 00:00:00 and go up. I'd probably cap it at, say, a 5 hour mark (ie, 04.59.59) .   It would be nice to be able to pause it with the push of a button, too.
How is this done?
Just a hint.....don't have to give it all away...I need to do some of the actual work myself or I will never learn :)
thanks in advance to all you really smart people out there
I believe that IntyBASIC normalizes the frame rate to 50 Hz, skipping every sixth ISR when in NTSC, so that should simplify things a bit.
Here is another hint:
5 hours is actually 18,000 seconds (5 hours x 60 minutes x 60 seconds); but 900,000 frames (18,000 seconds x 50 frames per second).  That means that a single 16-bit counter will not be able to count that high. ;)
     dZ.
     dZ.
thanks for the quick replies.  I will see what I can do, I was definitely worried about hitting a limit.  So that means the clock is sort of internal based on frame rate
I actually wrote up a design document for this game, so I am trying to do it for real this time. I am going to tackle one small piece at a time and them move onto the next. The clock mechanism is a critical element to the gameplay itself, so I may have to come up with a trick to count higher, like if it hits a limit I push a counter to 2 and start over or something.  Maybe I don't need to simulate a 'real time' running clock and can base my calculation on a fake sense of time for the purpose of gameplay.   Actually, as I typed this I just came up with a method....I will just count up each chunk of time needed and then reset to 0 and start over.  This way, I will only need to count up to about 10-15 minutes max.  If this doesn't pan out, then no point in going further so I am tackling this part first.  Since I didn't initially play to display the running clock (it would have been a nice to have), it won't be a loss...
I'll admit, still not sure I am up to the task of programming a full game, but it will be fun trying and I know I can soundboard my dumb ideas here  :)
Edited by Mik's Arcade
     dZ.
Only for the music.
The FRAME variable keeps counting with frame rate. The variable NTSC is non-zero if there are 60 frames per second, or zero if there are 50 frames per second.
54 minutes ago, nanochess said:
Only for the music.
Aha!  Well, it shows you were my focus of IntyBASIC has been; mostly in trying to integrate the Intellivision Music Tracker.
Thanks for the correction. :)
Quote
And the same ISR is called on every tick (PRNG, collisions, STIC shadow, etc.), irrespective of TV signal, and only the music player is affected?  So, time-sensitive mechanisms in games have to account for this themselves, correct?
    dZ.
Edited by DZ-Jay
    dZ.
That's right! ?
