Movie Cart
rbairos
1 minute ago, Thomas Jentzsch said:
So the playfield gets a fixed pattern? Colors seems to be updated for BK every line, for PF per frame. Correct?
The PF pattern is fixed.
Colours for PF and BK are set every alternate scanline. For the duration of a scanline, one of the colours will be black and the other will be another colour (possibly black).
That means all 4 colors are in use. If none of them is set to permanent black, you cannot hide the background color changes. That leaves VBLANK (two extra TIA writes) or changing the BK (or PF) color twice per line (one extra TIA write).
I would agree with that.
This is done to create a checkerboard which is inverse to the sprite checkerboard, right? So the background of each sprite is always black. Or is it vice versa?
Edited by Thomas Jentzsch
That's not my understanding. The playfield/background will show through the gaps in the sprite, giving more colour resolution to the movie per scanline (six colours per scanline by my counting).
So vice versa. :) One color (PF or BK) being fixed for the whole line, the other 5 are per sprite.
Anyway, that means either PF or BK color is black for a whole line. And one would "only" have to hide the other one.
Hm.. We might be able to use the missiles (at 8 pixel width). They would be positioned right of the movie area and then move in sync with the spites. Then, every line where the PF is colored, we need two extra black color writes (P1 and P0). That's only extra 6 cycles, because we only have to load black once for P0, P1 and PF colors.
I am not sure if the first write can happen early enough. Also, while this may work on the right side, it may not work on the left one.
See next post.
7 hours ago, Thomas Jentzsch said:
A much simpler approach would be to change the timing for PF and BK color changes. Changing to color should be done as late a possible, changing back to 0 as soon as possible (directly after the last color write). Timing doesn't look bad.
Here is my simple kernel demo from above modified. No extra cycles and no flicker left or right anymore.
movie_kernel_v2.bin
  • Like 8
Sorry I missed a bunch!
Yes your assumptions above are correct.
The current kernel does in fact maintain a background checkerboard pattern that is in sync with the sprite data. (directly behind it)
This is accomplished with a fixed PF pattern, where each scanline, I either color the background, and black the PF (and vice versa on the next line).
Your attached kernel is able to defer/advance that coloring enough to keep the sides blank?
If so: Holy moly.
PS. Do you have the asm file to make porting easier?
Edited by rbairos
5 hours ago, Thomas Jentzsch said:
A quick idea: How about updating audio 0 and 1 on alternating lines?
I think this might allow for some nice stereo effects. And I think for mono they should sound identical when combined.
Interesting.
Would also be backward compatible. One byte change.
But is stereo expressed anywhere in the atari h/w or emulation world?
The changes are quite simple, just move the COLUPF/BK writes.
My kernel is skipping the audio writes, because of the much slower branching. But in your code, you just have to move the existing stuff around a bit. I didn't bother with that. :). Here is some adapted code, as you can see, there are more than enough cycles for reenabling audio and timing it well. UNTESTED!
  MAC LEFT_KERNEL ; {graphics index}, {shading value}, {background}
    SLEEP   2               ; 2
    lda     #GRP1a_L{1}     ; 2
    sta     HMOVE           ; 3     @73     -8 pixel
    sta     GRP1            ; 3             VDELed
; 0a - 1a - 0b - 1b - 0c -
    lda     #COL1a_L - {2}  ; 2
    sta     COLUP1          ; 3
    lda     #0              ; 2             undefined
    sta     AUDV0           ; 3     @10
    ldx     #GRP0c_L{1}     ; 2
    ldy     #COL0c_L - {2}  ; 2
    lda     #GRP0a_L{1}     ; 2
    sta     GRP0            ; 3
    lda     #COL0a_L - {2}  ; 2
    sta     COLUP0          ; 3
    lda     #GRP1b_L{1}     ; 2
    sta     GRP1            ; 3             VDELed
    lda     #{3}            ; 2
    sta     COLUPF          ; 3
    lda     #COL0b_L - {2}  ; 2
    sta     COLUP0          ; 3     @39!    end of GRP0a display
    lda     #GRP0b_L{1}     ; 2
    sta     GRP0            ; 3     @44!    end of GRP1a display
    lda     #COL1b_L - {2}  ; 2
    sta     COLUP1          ; 3     @49
    stx     GRP0            ; 3     @52
    sty     COLUP0          ; 3     @55     <=@57
    lda     #0              ; 2
    sta     COLUPF          ; 3     @60
    lda     #$80            ; 2
    sta     HMP0            ; 3
    sta     HMP1            ; 3     @68
  ENDM
  MAC RIGHT_KERNEL ; {graphics index}, {shading value}, {background}
    SLEEP   3               ; 3
    lda     #GRP1a_R{1}     ; 2
    sta     GRP1            ; 3             VDELed   @76
; - 0a - 1a - 0b - 1b - 0c
    sta     HMOVE           ; 3     @03     +8 pixel
    ldx     #GRP0c_R{1}     ; 2
    sta     AUDV0           ; 3     @10
    ldy     #COL0c_R - {2}  ; 2
    lda     #COL1a_R - {2}  ; 2
    sta     COLUP1          ; 3
    lda     #GRP0a_R{1}     ; 2
    sta     GRP0            ; 3
    lda     #COL0a_R - {2}  ; 2
    sta     COLUP0          ; 3
    lda     #GRP1b_R{1}     ; 2
    sta     GRP1            ; 3             VDELed
    lda     #{3}            ; 2
    sta     COLUBK          ; 3
    lda     #COL0b_R - {2}  ; 2
    sta     COLUP0          ; 3     @42!    end of GRP0a display
    lda     #GRP0b_R{1}     ; 2
    sta     GRP0            ; 3     @47!    end of GRP1a display
    lda     #COL1b_R - {2}  ; 2
    sta     COLUP1          ; 3     @52
    stx     GRP0            ; 3     @55
    sty     COLUP0          ; 3     @58     <=@60
    lda     #$0             ; 2
    sta     COLUBK          ; 3     @63
    sta     HMCLR           ; 3     @66
  ENDM
1 hour ago, ZeroPage Homebrew said:
Stella supports stereo and here's a thread with a list of classic and homebrew games designed for stereo.
- James
The settings also exists per ROM. And besides the games mentioned already, Stay Frosty also has this option set.
Thats good Thomas! I hadn't seen the actual kernel until now, and yes the solution is quite obvious.
BTW, if the spare cycles are not used then 5 more bytes could be saved between the two kernels. Just set the stack pointer to 0 and use TSX, with STX COLUPF or STX COLUBK. With X=0, the sleeps can be eliminated to make use STA ZP,X taking 4 cycles.
; set SP to 0 instead of $FF
; enter the kernels with X=0
;     SLEEP   2               ; 2
;     lda     #GRP1a_L{1}     ; 2
;     sta     HMOVE           ; 3     @73     -8 pixel
    lda     #GRP1a_L{1}     ; 2     @69
    sta     HMOVE,X         ; 4     @73     -8 pixel
    sta     GRP1            ; 3             VDELed
    sta     COLUP1          ; 3
    sta     AUDV0           ; 3     @10
    ldx     #GRP0c_L{1}     ; 2
    lda     #GRP0a_L{1}     ; 2
    sta     GRP0            ; 3
    sta     COLUP0          ; 3
    lda     #GRP1b_L{1}     ; 2
    sta     GRP1            ; 3             VDELed
    lda     #{3}            ; 2
    sta     COLUPF          ; 3
    lda     #GRP0b_L{1}     ; 2
    sta     COLUP1          ; 3     @49
    stx     GRP0            ; 3     @52
;     lda     #0              ; 2
;     sta     COLUPF          ; 3     @60
    tsx                     ; 2     X=0
    stx     COLUPF          ; 3     @60
    lda     #$80            ; 2
;     sta     HMP0            ; 3
;     sta     HMP1            ; 3     @68
    sta     HMP0,X          ; 4
    sta     HMP1,X          ; 4     @70
  ENDM
;     SLEEP   3               ; 3
;     lda     #GRP1a_R{1}     ; 2
;     sta     GRP1            ; 3             VDELed   @76
    lda     #GRP1a_R{1}     ; 2    @72
    sta     GRP1,X          ; 4    @76       VDELed   @76,  X=0 and write takes 4 cycles not 3
    ldx     #GRP0c_R{1}     ; 2
    sta     AUDV0           ; 3     @10
    sta     COLUP1          ; 3
    lda     #GRP0a_R{1}     ; 2
    sta     GRP0            ; 3
    sta     COLUP0          ; 3
    lda     #GRP1b_R{1}     ; 2
    sta     GRP1            ; 3             VDELed
    lda     #{3}            ; 2
    sta     COLUBK          ; 3
    lda     #GRP0b_R{1}     ; 2
    sta     COLUP1          ; 3     @52
    stx     GRP0            ; 3     @55
;     lda     #$0             ; 2
;     sta     COLUBK          ; 3     @63
    tsx                     ; 2     X=0
    stx     COLUBK          ; 3     @60
;     sta     HMCLR           ; 3     @66
    sta     HMCLR,X         ; 4     @67
  ENDM
I could very well be doing something wrong, but it's *almost*  there.
See image below.  I think the background is being turned back on, one pixel too late?
Here's my port. Please excuse the sloppy style:
        ;; right hand
    ; enter at pixel pos 151 / color clock 219
    ; left_line/right_line kernel adapted by Thomas Jentzsch
right_line
set_gdata6
    lda     #GDATA6     ; 2
    sta     GRP1        ; 3     VDELed
set_aud_right
    lda     #AUD_DATA    ; 2
set_gdata9
    ldx     #GDATA9     ; 2
    sta     AUDV0       ; 3     @10
set_gcol9
    ldy     #GCOL9       ; 2
set_gcol6
    lda     #GCOL6       ; 2
    sta     COLUP1      ; 3
set_gdata5
    lda     #GDATA5     ; 2
    sta     GRP0        ; 3
set_gcol5
    lda     #GCOL5       ; 2
    sta     COLUP0      ; 3
set_gdata8
    lda     #GDATA8     ; 2
    sta     GRP1        ; 3     VDELed
set_colubk_r
    lda        #$00        ; 2     background color
    sta        COLUBK        ; 3  background color
set_gcol7
    lda     #GCOL7       ; 2
set_gdata7
    lda     #GDATA7     ; 2
set_gcol8
    lda     #GCOL8       ; 2
    sta     COLUP1      ; 3     @52
    stx     GRP0        ; 3     @55
    lda        #$00        ; 2  turn off background color
    sta     HMCLR       ; 3
;;;;;;;;;;;;;;;;;;; page 3 - left
    org $F980
left_line
        ;; left hand
;EnterLeftKernel
set_gdata1
    lda     #GDATA1     ; 2
    ;back 8, late hmove ;needs to be on cycle 71
    sta        HMOVE
    sta     GRP1        ; 3     VDELed
set_gcol1
    lda     #GCOL1       ; 2
    sta     COLUP1      ; 3
set_aud_left
    lda     #AUD_DATA    ; 2
    sta     AUDV0       ; 3     @10
set_gdata4
    ldx     #GDATA4     ; 2
set_gcol4
    ldy     #GCOL4       ; 2
set_gdata0
    lda     #GDATA0     ; 2
    sta     GRP0        ; 3
set_gcol0
    lda     #GCOL0       ; 2
    sta     COLUP0      ; 3
set_gdata3
    lda     #GDATA3     ; 2
    sta     GRP1        ; 3     VDELed
set_colupf_l
    lda        #$00        ; 2  playfield color
    sta        COLUPF        ; 3     playfield color
set_gcol2
    lda     #GCOL2       ; 2
set_gdata2
    lda     #GDATA2     ; 2
set_gcol3
    lda     #GCOL3       ; 2
    sta     COLUP1      ; 3     @49
    stx     GRP0        ; 3     @52
    lda        #$00        ; 2        turn off playfield
    sta        COLUPF        ; 3
    lda     #$80        ; 2
    sta     HMP0        ; 3
    sta     HMP1        ; 3     @63
    lda        #00            ; 2     dummy
    ; have to re-enter at correct cycle
pick_continue
    jmp        right_line
Edited by rbairos
@rbairos determine which kernel is the problem (left or right). It can be fixed by swapping the early loads of X or Y. For example if the right hand kernel is the issue than try this:
    SLEEP   3               ; 3
    lda     #GRP1a_R{1}     ; 2
;     ldx     #GRP0c_R{1}     ; 2
    ldx     #{3}            ; 2      CHANGED
    sta     AUDV0           ; 3     @10
    sta     COLUP1          ; 3
    lda     #GRP0a_R{1}     ; 2
    sta     GRP0            ; 3
    sta     COLUP0          ; 3
    lda     #GRP1b_R{1}     ; 2
    sta     GRP1            ; 3             VDELed
;     lda     #{3}            ; 2
;     sta     COLUBK          ; 3
    stx     COLUBK          ; 3      CHANGED
    ldx     #GRP0c_R{1}     ; 2      CHANGED
    lda     #GRP0b_R{1}     ; 2
    sta     COLUP1          ; 3     @52
    stx     GRP0            ; 3     @55
    lda     #$0             ; 2
    sta     COLUBK          ; 3     @63
    sta     HMCLR           ; 3     @66
  ENDM
One reason could be, that your timing is off by one cycle (too late).
BTW: Can you share a new test ROM with the Stella team?
Looking at the circle above, I wonder about some colors, which seem to be mixed for antialiasing. Here is an example from the left side:
Why are some pixel in the left column in light blue?
E.g. I suppose the top two light blue lines should indicate that the white of the circle extends a bit (less than one whole pixel) further to the left. But then the coloring of the right part is wrong.
  • Either the right part should stay white and the left, green part slightly lighter (which seems to be the case already). (2nd row)
  • Or the right part should be extended one pixel bit to the left. Then the left part should not be lightened and the right part would be a mix of (mostly) white and green. (1st row)
The all blue line seems even worse. Is that a bug or will that be corrected by the 2nd frame which we cannot see here?
Sorry, very early for me, but wanted to dump some more info:
I've committed the stella changes to the github:
https://github.com/lodefmode/stella
The asm changes are listed here:
https://github.com/lodefmode/moviecart/tree/main/asm
This screenshot shows before and after:
Looks like player graphics data is correct.
Also its correct because previous tests with all black background still work properly.
Also included screenshot of just the background colors, and the circle graphics data minus background:image.thumb.png.56c6d9f347d1100bc54b13ff1b180b18.png
It seems to definitely be in right kernel.
I swapped the assignment of the color background a little earlier, and it filled that black line
as well introduced several pixels of artifacts on the left side.
I haven't tried Omegamatrix change yet, but looks promising.
Finally attaching the mvc file which produces the circle (with 30 seconds of audio).
Thanks everyone!
output_circle.zip
@rbairos Yup, you are wasting 2 cycles between left and right kernel, so the right kernel executes 2 cycles too late.
The 2 cycles should be wasted between right and left kernel instead.
BTW: Why do you have ORGs all over your code? The video kernel has no branches, so it doesn't need any alignment. And generally e.g. ALIGN $100 is the better choice.
Okay, I'll shift that dummy line.
Reason I have org's everywhere is the hardware version of this was implemented with a 1K dual-port ram.
It monitored line A7 to determine which of the eight 128-byte regions it was in, to know what to update.
The emulator also monitors A7 for the same reason.
Didn't know about the ALIGN macro, though I still have to be very specific where everything lives.
Stay tuned..
Edited by rbairos
Here's another test ROM that's much larger... (Kong vs Dinosaurs)
https://www.dropbox.com/s/1x4xte4056ulrtb/kong.mvc?dl=0
Edit: and another (Knock on Wood - Amii Stewart)
https://www.dropbox.com/s/na24ontc5pfp4mr/knockonwood.mvc?dl=0
Edited by Andrew Davie
