Jetboard Joust - retro-inspired indie game (in VCS store)
marss
10 hours ago, Atari_JaguarVCS said:
Nice, time to boot my VCS back out of Windows 10 and get this game updated!. I recently picked this game up for Switch to since I’ve been enjoying it so much, great game.
Thanks everyone for your support - glad you're enjoying the game, buying it on Switch as well is real commitment!
The game does get tough on later stages, I've found balancing the difficulty one of the hardest things with some people complaining it's too easy and others that it's ridiculously hard! The last build is actually a bit tougher as I've nerfed a couple of weapons that were a bit OP and closed some loopholes where too many health/joust pickups were getting given out. I still sweat trying to complete it, especially in a single run, and I've put some ridiculous amount of hours into it.
Has anyone who couldn't use a controller wirelessly before found that it's now OK with the latest update?
  • 5 months later...
Hello All,
Just to let you know that I've just submitted a maintenance update for Jetboard Joust to Atari. This one contains an important fix for a crash that could occur if the player spawned directly on top of a weapon crate. It also includes numerous smaller bug fixes and improvements and brings everything in line with the upcoming Xbox and PS4 releases. Happy Jousting!
james@bitbull
  • Like 4
  • Thanks 2
On 5/27/2021 at 12:15 PM, Mockduck said:
For me, I can play the game with both VCS controllers, but the Classic has to be wired in order to be recognized.
Strangely I just started having this issue in Thrustlander. My classic controller used to work fine wirelessly but then stopped working. Just in Thrustlander. Plugged in it works fine.
Sorry, I am not trying to hijack the thread but found it interesting that I have seen this behavior in a single game as well.
I just verified that I still have the issue in Thrustlander. The only thing I can do is exit out to the Dashboard with the classic controller through Bluetooth.
Edited by stirrell
It is probably the same issue. The Atari controllers have this weird quirk where different firmware actually registers them as a different hardware ID. Atari have made their own edits to the SDL source to ignore the part of the ID that the firmware changes, but if the game build includes a 'bundled' SDL (as most platforms will do) this one is used instead which means firmware updates can break the controller connection. I have to explicitly remove the bundled SDL lib from my builds before packaging up for the VCS.
Sometime controllers can BT sync up with a new name that messes up using them wirelessly.  I would go to the BT section in the VCS forget the classic controller (or anything you don't recognize) and BT pair the Classic Controller again.  Then see if it works wirelessly.  There are still some BT bugs in the VCS that can mess up a paired controller.  Just forget it and re-pair it.
  • Thanks 2
This worked for me. Thanks!
17 hours ago, SabertoothRetro said:
I was thinking about my personal GOTY as I was driving into work today. Jetboard Joust is at the top of the list for pure fun factor.
Thanks! Really glad you're enjoying it!
As well as bugfixes the new update has better difficulty balancing in the later levels and an improved algorithm for generating player loadouts if you start the game via a teleport, now you get a smaller number of higher-level weapons rather than a ton a lower-level weapons. Generally the game is rather more forgiving towards the end than it was.
  • Thanks 2
  • 1 month later...
38 minutes ago, markofwolves said:
Hello. With the classic controller, how i can change the weapon? I don't have the button.
Hi,
Sadly, you can't. There just aren't enough buttons. I tried other methods like using the rotation of the stick, long-presses etc, but none of them worked to my satisfaction, either triggering too often by accident or getting confused with other actions. It plays better with the modern controller due to the analogue response as well.
Thanks for playing and I hope it doesn't prevent you enjoying the game!
On 1/1/2022 at 2:15 PM, BitBull said:
Hi,
In the end I decided that I will keep it that way, waiting for a fix to play it with the classic controller. Asking for a refund would be incorrect. It is also right to support and reward a job like yours.
I think the only solution is to use the arrow button for weapon change. Controller in hand should work well.
Hope to hear good news soon. I love your game.
Edited by markofwolves
Thanks for the support, I appreciate it!
I intend to look into this tomorrow. Will update when I have more info.
2 hours ago, BitBull said:
Hi There,
I have just emailed Atari with an updated build. In this one I have mapped the 'back' button on the classic controller to work the same as 'x' on the modern controller. This means you can assign it to 'switch weapon' (or 'fire' or 'joust') via 'controls' on the main menu. It also means you can access weapon info from the 'upgrades' screen. Thanks for this suggestion, I don't know why I didn't think of this before, sometimes it becomes difficult to see the wood for the trees in gamedev! Hopefully Atari won't take issue with this, I don't see why they should.
I've also improved playability with the classic controller a bit as I discovered you couldn't move down and left/right at the same time using it (!)
The build number is 1.1.04m. I'm not sure when Atari will get round to putting this live, sometimes they are quick but sometimes they are very slow!
Thanks again for playing and for the feedback.
James at BitBull
Thanks again ?
  • 2 weeks later...
On 1/4/2022 at 7:04 PM, BitBull said:
Hi There,
James at BitBull
Hello Bit. Yesterday last check, no update :(
