glurk Posted May 6, 2021 Share Posted May 6, 2021 So, I was going through my old Atari disks, and came across a 1-sector program named CARTDUMP. I just manually disassembled it: * = 0600 0600 A9 01 LDA #$01 ; select 0602 8D 01 03 STA DUNIT ; disk 1 0605 A9 57 LDA #$57 0607 8D 02 03 STA DCOMND ; write/verify command 060A A9 00 LDA #$00 060C 8D 04 03 STA DBUFLO ; zeroes 060F 8D 0B 03 STA DAUX2 ; 0612 A9 80 LDA #$80 0614 8D 05 03 STA DBUFHI ; $80xx (slot B) 0617 A9 01 LDA #$01 0619 8D 0A 03 STA DAUX1 ; sector 1 061C AD 00 D3 LDA PORTA 061F C9 FF CMP #$FF 0621 F0 F9 BEQ $061C ; wait for insertion 0623 A9 80 LDA #$80 0625 8D FF 06 STA $06FF 0628 20 53 E4 JSR DSKINV ; write the sectors 062B EE 0A 03 INC DAUX1 062E D0 03 BNE $0633 0630 EE 0B 03 INC DAUX2 0633 AD 04 03 LDA DBUFLO 0636 18 CLC 0637 69 80 ADC #$80 0639 8D 04 03 STA DBUFLO 063C D0 03 BNE $0641 063E EE 05 03 INC DBUFHI 0641 CE FF 06 DEC $06FF 0644 D0 E2 BNE $0628 ; go till done 0646 4C 46 06 JMP $0646 ; total halt 0649 00 BRK 064A .END And this was my old-time way of dumping cartridges on my 800. What I would do is boot up to DOS with the cartridge door open by disabling the interlock switch, load and run this CARTDUMP program, switch to a blank disk, and insert the cartridge in the "B" slot (with the system ON), and this little program immediately writes it out to disk starting at sector 1. Probably NOT a recommended procedure, but that's what I used to do. It actually did work. I figured some of the old-timers here might find it amusing. 1 3 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted May 6, 2021 Share Posted May 6, 2021 Doesn't explain how control (Program Counter) is being transferred to $600? Quote Link to comment Share on other sites More sharing options...
glurk Posted May 6, 2021 Author Share Posted May 6, 2021 5 minutes ago, Wrathchild said: Doesn't explain how control (Program Counter) is being transferred to $600? The actual file had a header on it, which I didn't include here. From DOS, L->Binary Load, M->Run at address, enter 0600. That's all. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted May 6, 2021 Share Posted May 6, 2021 OK, so rather than 'load and run' you would load the CARTDUMP program but then launch it after the cart had been inserted, makes sense now. Quote Link to comment Share on other sites More sharing options...
glurk Posted May 6, 2021 Author Share Posted May 6, 2021 Actually, there is a loop in there that's supposed to wait for a port 1 joystick to be moved before it starts writing, but in practice it would start as soon as the cartridge was inserted. I don't know why that happens, it was just a happy accident. I tested it again just to check. I guess the PORTA value glitches briefly when a cartridge is inserted into a live machine... It wasn't intended. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted May 7, 2021 Share Posted May 7, 2021 Maybe try to wait for button instead? WFB: LDA TRIG0 AND #1 BNE WFB Quote Link to comment Share on other sites More sharing options...
glurk Posted May 7, 2021 Author Share Posted May 7, 2021 Yeah, the trigger button code works. Just tried it. If I wanted to go "all-out" - and it wouldn't really be very hard to code - I could make the little program also write out a boot sector, some loading code, and a jump to the cart INIT address, and it would just immediately dump a cart out to a bootable disk. It would only work for carts that don't try to overwrite themselves, but otherwise should work fine. I never bothered to go that far with it, and it would be kinda pointless with everything now dumped already, but maybe useful for some people. I'm just playing around with this stuff anyways, just for fun. 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 7, 2021 Share Posted May 7, 2021 9 minutes ago, glurk said: ...it would be kinda pointless with everything now dumped already, but maybe useful for some people. New, undumped carts turn up every year (one currently being discussed on the forums is Cheez-Wiz -- newly discovered Roklan proto cart); and guess what, a lot of the people that have the artifacts post on here asking, "what do I use to dump this cart?". 2 Quote Link to comment Share on other sites More sharing options...
glurk Posted May 7, 2021 Author Share Posted May 7, 2021 Well, the code above works, and I used to use it. But I don't think it's a good method to insert a cart into a live powered-on system. It always kinda scared me, but that was what I figured out I could do way back around 1984 or so, LOL. It also just dumps it straight out onto disk sectors, which is pretty darn easy to do on the Atari... And it doesn't even TRY to handle bank-switching, etc... And, this has probably been done before, I'd bet. I just got my old Atari from storage a few weeks ago, and I'm still going through my 40 year old floppy disks just to see what all I have, just for fun. 2 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 7, 2021 Share Posted May 7, 2021 (edited) I'm pretty sure some of the commercial dumping tools required hot-plugging the cart being dumped. Jindroush (of cartridge dumping fame) developed a disk-based tool and an SDX-cart-based (piggyback) tool for dumping carts, which I think a lot of people use. Jindroush Cart Tools.zip There's also the AtariMax USB Cartridge Programmer, which can dump about anything, and is really easy to use (has PC software that goes with it). I used to own one, and they work great. Edited May 7, 2021 by MrFish 2 Quote Link to comment Share on other sites More sharing options...
ClausB Posted May 7, 2021 Share Posted May 7, 2021 BITD I built this cart extender with a switch to disable the ROM so that hot-plugging isn't needed: 5 Quote Link to comment Share on other sites More sharing options...
glurk Posted May 7, 2021 Author Share Posted May 7, 2021 (edited) I looked at that Jindroush tool (not the SDX ones) and it looks like a much more advanced version of the same idea. It has a display, selections for 8K, 16K, and XEGS bank switching. And I think it handles the actual filesystem, and writes out a .rom file. I don't know exactly how it's used. Much more ambitious than my simple little approach. I looked a bit for some documentation on it, and didn't find any. And for me, too much work to disassemble it all. I'm sure it works well, though, it looks fully fleshed-out. EDIT TO ADD: Yeah, that cart extender is almost certainly a better way to go! Edited May 7, 2021 by glurk Quote Link to comment Share on other sites More sharing options...
+David_P Posted May 8, 2021 Share Posted May 8, 2021 13 hours ago, ClausB said: BITD I built this cart extender with a switch to disable the ROM so that hot-plugging isn't needed: You terrible, terrible hacker. Quote Link to comment Share on other sites More sharing options...
+Nezgar Posted May 8, 2021 Share Posted May 8, 2021 On 5/7/2021 at 2:32 AM, MrFish said: Jindroush (of cartridge dumping fame) developed a disk-based tool and an SDX-cart-based (piggyback) tool for dumping carts, which I think a lot of people use. Jindroush Cart Tools.zip 129.29 kB · 5 downloads While I have successfully run this tool using a replacement EPROM in my SDX cart to dump a cart to disk, the reciprocal program to actually read the data back off the disk into a usable rom dump file or executable was never released. Here is an excerpt from the readme.txt from "cartsave.zip" on PIGWA: http://ftp.pigwa.net/stuff/mirror/jindroush.atari.org/DATA/ACARTS/ Cartridge Dumper 2.06 --------------------- (c) 2001 Jindroush ... The resulting diskimage must be extracted by hand by person which knows the format (only me :-) It appears to write a linear chunk of data to the disk so it could be reverse engineered, but the dumper does support manually setting $D0x banking bits, so would require some trial and error. Dumping an 8K cart and snooping with RespeQt I saw it wrote 65 sectors from 17-79.. so possibly a header sector + 64x128=8KB of data. Quote Link to comment Share on other sites More sharing options...
ClausB Posted May 8, 2021 Share Posted May 8, 2021 My dumper relocated the top 1K of the cart binary so that loading the file wouldn't overwrite the screen. The loader would then re-init the screen below the cart space, copy that 1K back up, and init the cart. Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 8, 2021 Share Posted May 8, 2021 PORTA doesn't glitch when a cart is inserted. TRIG3 on XL/XE reflects the cartridge state though a program like this won't work there since there's a watch on the state during VBlank which will lock up or restart the machine if the cart state changes. To do cart copies there you need to set the CRITIC flag so that Stage 2 VBlank is skipped. My method generally was to just copy the 16K cart space to RAM then write to disk later. In theory you could do a checksum of part of cartridge memory and use a change to detect insertion though on some machines don't we get some floating values in empty memory? Quote Link to comment Share on other sites More sharing options...
+MrFish Posted May 8, 2021 Share Posted May 8, 2021 18 hours ago, Nezgar said: While I have successfully run this tool using a replacement EPROM in my SDX cart to dump a cart to disk, the reciprocal program to actually read the data back off the disk into a usable rom dump file or executable was never released. Here is an excerpt from the readme.txt from "cartsave.zip" on PIGWA: http://ftp.pigwa.net/stuff/mirror/jindroush.atari.org/DATA/ACARTS/ Cartridge Dumper 2.06 --------------------- (c) 2001 Jindroush ... The resulting diskimage must be extracted by hand by person which knows the format (only me :-) It appears to write a linear chunk of data to the disk so it could be reverse engineered, but the dumper does support manually setting $D0x banking bits, so would require some trial and error. Dumping an 8K cart and snooping with RespeQt I saw it wrote 65 sectors from 17-79.. so possibly a header sector + 64x128=8KB of data. Somehow it doesn't surprise me. I know this guy had some snide comments on his site about not posting "ROMz" for "Cool Doodz" to download. I never actually used it myself (already had an Atarimax Cart Programmer when I started needing to dump carts). Quote Link to comment Share on other sites More sharing options...
glurk Posted May 9, 2021 Author Share Posted May 9, 2021 I've looked (quickly) at the actual Jindroush cartdump disassembly in Omnivore, and it's not really that big. I'm not volunteering myself, but if someone wanted to properly disassemble and comment the whole thing, it could be figured out. I won't be doing it, though! ? Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted November 3, 2021 Share Posted November 3, 2021 bump Quote Link to comment Share on other sites More sharing options...
Mrshoujo Posted December 2, 2021 Share Posted December 2, 2021 On 5/6/2021 at 5:50 AM, glurk said: So, I was going through my old Atari disks, and came across a 1-sector program named CARTDUMP. I just manually disassembled it: [·snip·] And this was my old-time way of dumping cartridges on my 800. Probably NOT a recommended procedure, but that's what I used to do. It actually did work. I figured some of the old-timers here might find it amusing. I used probably a similar cart dumping program on my 800XL. Does it load up and buzz the speaker with a prompt to insert cartridge and press START? I took it to be using a tight loop to keep the system occupied while inserting the cartridge then if it still buzzed after the cart was seated, it worked. Except my version saved a binary load file. I backed up a number of cartridges that way. Hopefully I'll get to checking to see if I still have those floppies. I have a touch tablet and Atari Artist was supposed to be with it. I had a Chalkboard Powerpad with a version of Micro Illustrator for it, too. Sadly I don't have the Powerpad anymore... (Grrrrrrmble..) Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 30, 2021 Share Posted December 30, 2021 On 5/8/2021 at 11:52 PM, MrFish said: Somehow it doesn't surprise me. I know this guy had some snide comments on his site about not posting "ROMz" for "Cool Doodz" to download. I never actually used it myself (already had an Atarimax Cart Programmer when I started needing to dump carts). I remember offering and sending him all the cart files I had, when I asked him if he would share any dumps he made he said "I don't share stuff" 1 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted December 30, 2021 Share Posted December 30, 2021 2 hours ago, Mclaneinc said: I remember offering and sending him all the cart files I had, when I asked him if he would share any dumps he made he said "I don't share stuff" Maybe if you said "pretty please"... Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted December 30, 2021 Share Posted December 30, 2021 (edited) Ha ha...It was just one of those "oh..Like that is it" moments. It didn't bother me to be honest, just made me think about how his head worked. Edited December 30, 2021 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted December 30, 2021 Share Posted December 30, 2021 Yes it was all about him... he took and did not return or share... Quote Link to comment Share on other sites More sharing options...
