Wilheim Posted June 1, 2021 Share Posted June 1, 2021 Hi, all! I want to make my own Fujinet Driver in order to make some enhancements on software I'm doing. Specially, creating updates and publish them into a TNFS server so Fujinet connects into it and mount the updater. So far, I was able to: - Getting SSID info stored into Fujinet (SIO command $FE) - Scanning Wifi Networks number (SIO command $FD) - Scanning Wifi Network names (SIO command $FC) So far, so good. Then I try to get the SSID info from Fujinet (SSID and password) and then connect directly to my cell phone (sharing Internet enabled), but for some reason it doesn't get an IP address. I'm doing it this way to connect first just to test it and get an IP address. After that, I will make a GUI to select a network, getting a password and connect. Does anyone know what am I missing? I'm attaching the Test program, as well as the driver I'm writing so far. It creates an ATR image to boot directly into any SDRIVE, sio2pc or similar. Any suggestions are welcome! FujinetDriver.asm Test.asm Test.atr 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted June 1, 2021 Share Posted June 1, 2021 It is absolutely critical that you run the fujinet-flasher to run a fujinet monitor so you can see the commands go across to see what might be going wrong. -Thom 1 Quote Link to comment Share on other sites More sharing options...
Wilheim Posted June 1, 2021 Author Share Posted June 1, 2021 Thank you! Very useful tool! Solved. It was a stupid bug from not getting Adapter config (command $e8) properly. Cheers! 4 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted June 9, 2021 Share Posted June 9, 2021 On 6/1/2021 at 2:45 PM, Wilheim said: Thank you! Very useful tool! Solved. It was a stupid bug from not getting Adapter config (command $e8) properly. Cheers! will you be posting and or sharing your labors? Quote Link to comment Share on other sites More sharing options...
Wilheim Posted June 9, 2021 Author Share Posted June 9, 2021 21 hours ago, _The Doctor__ said: will you be posting and or sharing your labors? Sure. Here's what I have so far. It's still a WIP. FujiNET Driver alpha version.zip 2 Quote Link to comment Share on other sites More sharing options...
