+SoulBuster Posted June 21, 2021 Author Share Posted June 21, 2021 Asylum - Autoload Cassette, Boot without basic for cassette or disk. Asylum Disk.zip Asylum Cassette.zip Asylum Manual.PDF 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 21, 2021 Author Share Posted June 21, 2021 If you have already picked up the Bruce Lee Cassette image, you may want to go back to that post and get the Disk image, Disk pic and Disk screen shot. I added them to the original post. Bruce Lee Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 21, 2021 Author Share Posted June 21, 2021 Bug Attack - Autoload cassette without basic Bug Attack.zip Bug Attack Manual.PDF 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 21, 2021 Author Share Posted June 21, 2021 Aztec Challenge - Slow Boot Removed. Autoload cassette no basic. Aztec Challenge.zip Aztec Challenge Manual.PDF 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted June 21, 2021 Share Posted June 21, 2021 (edited) Getting command line errors with all the cas files in Altirra, the wav's are fine Just tested other known cas files and they load as expected, seems to be an encoding issue? Edited June 21, 2021 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted June 21, 2021 Share Posted June 21, 2021 (edited) Edit: Asylum DOES work, no errors...I'd missed out on checking it by accident, but the others do fail.. Tried a redownload etc etc.. Also found a little 'oddity', if I drag a large zipped wav file on to Altirra from my opus screen I get a message saying its too large >128mb but if I drag the same file that is unzipped it is ok about it.. Obviously there's a reason for it, just I'd never seen it before.. Edited June 21, 2021 by Mclaneinc Quote Link to comment Share on other sites More sharing options...
+CharlieChaplin Posted June 21, 2021 Share Posted June 21, 2021 2 hours ago, Mclaneinc said: Getting command line errors with all the cas files in Altirra, the wav's are fine Just tested other known cas files and they load as expected, seems to be an encoding issue? CAS versions of "Voodoo Castle" and "The Count" do work fine on my PC with, errmmm, good old Win XP and Altirra 2.90. Did not test the other CAS files yet. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted June 21, 2021 Share Posted June 21, 2021 Well whatever has happened since 2.90 is perhaps more exact and isn't happy with these small set of cas files. I suspect its like the disks that would load on Atariwinplus but not Altirra because Altirra was far more accurate in drive emulation. I'm sure it will all get sorted out.. 2.90 and XP, have you been travelling back in time again Quote Link to comment Share on other sites More sharing options...
firebottle Posted June 22, 2021 Share Posted June 22, 2021 8 hours ago, CharlieChaplin said: good old Win XP and Altirra 2.90 Thumbs up! Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 22, 2021 Author Share Posted June 22, 2021 I have no idea what is going on for you. My Altirra setup for testing them is fairly bland with no additional hardware setups. They all tested fine with the exception of Avoid. I could not get a CAS file made, but the wav works. Altirra 3.90 Hardware type: 65XE/130XE Video Standard: NTSC CPU: 6502/6502C Firmware OS: Atari XL/XE/XEGS OS ver.4 from TO_SEC Basic: Atari Basic Rev C from a page on the internet (forget which) Memory: 128k Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted June 22, 2021 Share Posted June 22, 2021 I'm using beta 4.00 (latest beta) I know there's been quite a few tape changes by Avery, perhaps there's breakage? I'll include him in the conversation to see if he can tell us what is going on.. @phaeron Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted June 22, 2021 Share Posted June 22, 2021 Yep, went back to 3.90 and they all work.. I don't have time to go through all the 4.00 beta's to see which one causes the message and breakage.. Glad they worked.. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 22, 2021 Author Share Posted June 22, 2021 Oh, very cool Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 22, 2021 Author Share Posted June 22, 2021 I was able to make a CAS of Avoid. So if you have already picked up Avoid, you can now go back to the original post and get the CAS. Avoid Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 22, 2021 Author Share Posted June 22, 2021 Caverns of Khafka - Boot without basic for disk or cassette Caverns of Khafka Disk.zip Caverns of Khafka Cassette.zip Caverns of Khafka Manual.PDF 3 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 22, 2021 Author Share Posted June 22, 2021 Crossfire - Autoload Cassette Crossfire Cassette.zip Crossfire Manual.PDF 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 22, 2021 Author Share Posted June 22, 2021 Darts - Autoload cassette without basic. I was not able to make a CAS. Darts Cassette.zip Darts Manual.PDF 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 22, 2021 Author Share Posted June 22, 2021 Dimension X - Autoload cassette. Instructions for other versions say to disable basic, but this will not load with it disabled. Leave basic enabled when autoloading. The following cassette recording of Dimension X is an anomaly. The Cassette player I used, mixed stereo down to mono with both the left and the right side recorded into one track. The anomaly is that it still loads the game, go figure. Dimension X Cassette.zip This is the proper recording of Dimension X with the Audio and data separated. There is also a version that reduces clipping of the music channel and an ever further version that offsets the music so it can finish before the data is loaded, also with reduced clipping. The CAS version does not seem to carry the music channel. Dimension X Proper, Reduced Clipping, Offset Music.zip Dimension X Manual.PDF 1 Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 22, 2021 Author Share Posted June 22, 2021 Galactic Chase - Autoload Cassette without basic Galactic Chase Cas.zip Galactic Chase Manual.PDF 2 Quote Link to comment Share on other sites More sharing options...
firebottle Posted June 22, 2021 Share Posted June 22, 2021 53 minutes ago, SoulBuster said: Dimension X - Autoload cassette. Instructions say to disable basic. but I could only get it to load in Altirra with Basic enabled. Let me know what your experience is. Unable to create CAS. The reason Dimension X doesn't work is you've got the music channel and the data channel mixed together in a wav file. Both channels are mixed hard right. What kind of cassette deck are you using to capture this? Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 22, 2021 Author Share Posted June 22, 2021 5 minutes ago, firebottle said: The reason Dimension X doesn't work is you've got the music channel and the data channel mixed together in a wav file. Both channels are mixed hard right. What kind of cassette deck are you using to capture this? General Electric mini compact. Dimension X does work if I leave basic enabled with autoload. Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 22, 2021 Author Share Posted June 22, 2021 Sunday Golf - Boot into BASIC, CLOAD and RUN. This title has been updated as the preservation site states that it is consistent with a CSAVE. It might very well be. So I took another single pass recording that does turn into a good CAS. All assets are now included in the zip. Sunday Golf Cassette.zip 2 Quote Link to comment Share on other sites More sharing options...
firebottle Posted June 22, 2021 Share Posted June 22, 2021 4 minutes ago, SoulBuster said: General Electric mini compact. Dimension X does work if I leave basic enabled with autoload. Amazing that it does. There's music to listen to while the game is loading in one channel. I'd use a cassette deck that has proper stereo output, or check your connections to your recording device. See this thread: Quote Link to comment Share on other sites More sharing options...
firebottle Posted June 23, 2021 Share Posted June 23, 2021 3 hours ago, firebottle said: There's music to listen to while the game is loading in one channel. That should say... There's music to listen to in one channel (left) while the game is loading in the other channel (right). I guess you can't edit posts after a few hours...? Quote Link to comment Share on other sites More sharing options...
+SoulBuster Posted June 23, 2021 Author Share Posted June 23, 2021 Analogies - This title has been updated. Previously it was recorded by individual lessons. They are still included, but I have made a new recording in one pass so all lessons are on one recording. It made a good CAS also. All assets are now in the zip. Analogies_Cassette.zip 4 Quote Link to comment Share on other sites More sharing options...
