_The Doctor__ Posted August 31, 2021 Share Posted August 31, 2021 21 minutes ago, Sandor / HARD said: Wow, that's a pretty complex sounding tune for a single Pokey! Keep going Had a feeling we'd see you here! ... pretty inspirational, are you playing with his work yet? 1 1 Quote Link to comment Share on other sites More sharing options...
VinsCool Posted August 31, 2021 Author Share Posted August 31, 2021 (edited) Okay, I found a way to get it work with the trackn_audctl variables, now I can finally change it on the fly! This is based on what Distortion is being used, and at most this will be able to avoid changing the clock when it is unwanted. However, There is yet another problem I need to address now. I can indeed control the AUDCTL being fed into memory to change the clock on the fly for Distortion 2, but my current method basically wipes out anything that may also exist within the trackn_audctl value in memory, so if I tried to use 15khz in 1 instrument, that also used Distortion 2, as soon as the contents being NOT Distortion 2 is detected, it's a full reset of the memory, so now I would be stuck with either, 1.79mhz clock + Distortion 2, or nothing at all, hahaha But hey, this is a bit of progress anyway. I need to go out for a bit, so I'll come back to this later today with maybe a much better approach to it. I honestly did not expect this whole idea to be trickier to execute, but here we are ? Here's the binary I tested in the video above. There was absolutely no instrument with AUDCTL bits, they all were handled by the hijack code, and it's certainly not the ideal way to do it, but it is at least sort of working, for a proof of concept. Distortion 2 TEST2.obx Edited August 31, 2021 by VinsCool I can't English 2 1 Quote Link to comment Share on other sites More sharing options...
ivop Posted August 31, 2021 Share Posted August 31, 2021 18 hours ago, VinsCool said: Just try searching for the Atari executable header in a hex editor, there will be 3 different player binaries in 3 different locations, the MONO and STEREO players are very close to each others, but other than that, there will be a lot of stuff between each one of them. What kind of stuff? Other 6502 assembly or x86 code? If it's the former, there might be possibilties. If it's the latter, we are SOL. 18 hours ago, VinsCool said: if MADS syntax produce code that is easier to read, I will for sure learn how to make use of it sometime. Thanks! 18 hours ago, VinsCool said: IFT... I only assumed this stood for 'if', because that is pretty much how it have behaved for me. IFT -> 'If True'? That seems logical to me, haha My first thought was IF Then 1 Quote Link to comment Share on other sites More sharing options...
emkay Posted August 31, 2021 Share Posted August 31, 2021 46 minutes ago, VinsCool said: Here's the binary I tested in the video above. There was absolutely no instrument with AUDCTL bits, they all were handled by the hijack code, and it's certainly not the ideal way to do it, but it is at least sort of working, for a proof of concept. Distortion 2 TEST2.obx 6.85 kB · 2 downloads Now THAT is SOMETHING This is really is the missing link to a lot tunes that wait for being converted 2 Quote Link to comment Share on other sites More sharing options...
ivop Posted August 31, 2021 Share Posted August 31, 2021 38 minutes ago, ivop said: What kind of stuff? Other 6502 assembly or x86 code? If it's the former, there might be possibilties. If it's the latter, we are SOL. Hmm, I see your player at offset 0x3ee00 up to 0x3f6dd. After that, there's some x86 code and a 16-bit unicode table. So we are so out of luck ? Or maybe not completely. Perhaps you can share the exact blocks you patch, so I might find pointers to it (at runtime, not offsets in the binary). If pointers can be changed, we maybe can use the largest patchable block of consecutive memory that ends up in the 6502 emulation. Now here's another idea. We can compile sa_c6502.dll from scratch, so we can add patches to the 64kB memory array there, too! 1 Quote Link to comment Share on other sites More sharing options...
VinsCool Posted August 31, 2021 Author Share Posted August 31, 2021 1 hour ago, ivop said: What kind of stuff? Other 6502 assembly or x86 code? If it's the former, there might be possibilties. If it's the latter, we are SOL. Yeah, that is pretty much what it looks like to me. 26 minutes ago, ivop said: Hmm, I see your player at offset 0x3ee00 up to 0x3f6dd. After that, there's some x86 code and a 16-bit unicode table. So we are so out of luck ? Ah well... I also pretty much expected something as such. 27 minutes ago, ivop said: Or maybe not completely. Perhaps you can share the exact blocks you patch, so I might find pointers to it (at runtime, not offsets in the binary). If pointers can be changed, we maybe can use the largest patchable block of consecutive memory that ends up in the 6502 emulation. Now here's another idea. We can compile sa_c6502.dll from scratch, so we can add patches to the 64kB memory array there, too! Now that sounds like something interesting... Being able to have both the .exe patched, and the rmtplayr code from a .dll would seriously change a lot of that stuff. I am unfortunately not qualified for that sort of gigantic task, so if you can find an entrypoint, it could flip the table upside down to a brand new surface to work on. Quote Link to comment Share on other sites More sharing options...
VinsCool Posted August 31, 2021 Author Share Posted August 31, 2021 1 hour ago, emkay said: Now THAT is SOMETHING This is really is the missing link to a lot tunes that wait for being converted There is still an important element missing: I must figure out a workaround that would allow this hack to function, AND keep existing AUDCTL combinations in memory without conflicts. Ideally, what would really change the game is an extra effect command in instruments that would set the AUDCTL as an envelope, and I can sort of see a way to attempt this, but I have know how I could even get such a monumental change to work at all. Still, RMT2LZSS is the closest possible option available, with the .erti combinations, it can be done very easily there, but that is quite a pain in the ass to work with, I think I can speak from experience there lol So for now, I'm back home, and this kept my mind busy, so I really want to prove this Distortion 2 thing can work, and I know how stubborn I am sometime, I will find a way lol Quote Link to comment Share on other sites More sharing options...
emkay Posted August 31, 2021 Share Posted August 31, 2021 8 minutes ago, VinsCool said: There is still an important element missing: I must figure out a workaround that would allow this hack to function, AND keep existing AUDCTL combinations in memory without conflicts. Ideally, what would really change the game is an extra effect command in instruments that would set the AUDCTL as an envelope, and I can sort of see a way to attempt this, but I have know how I could even get such a monumental change to work at all. Still, RMT2LZSS is the closest possible option available, with the .erti combinations, it can be done very easily there, but that is quite a pain in the ass to work with, I think I can speak from experience there lol So for now, I'm back home, and this kept my mind busy, so I really want to prove this Distortion 2 thing can work, and I know how stubborn I am sometime, I will find a way lol For me it would be sufficient enough to have it basically working in RMT, and LZSS was adopting it. LZSS would adopt it automatically (I guess) , if the RMT file has the correct AUDCTL value stored. 1 Quote Link to comment Share on other sites More sharing options...
VinsCool Posted August 31, 2021 Author Share Posted August 31, 2021 13 minutes ago, emkay said: For me it would be sufficient enough to have it basically working in RMT, and LZSS was adopting it. LZSS would adopt it automatically (I guess) , if the RMT file has the correct AUDCTL value stored. Let's not get worried for now, I think I have an idea that could work. I'm still learning how to code, but I was using a nice little 6502 emulator with assembler and disassembler, and I have come up with this rudimentary piece of code that seems to perfectly fit my problem LDY #$21 STY $0001 LDA #$20 BIT $0001 BNE good bad: EOR $0001 badloop: LDX #$ff JMP badloop good: EOR $0001 goodloop: LDX #$00 JMP goodloop The situation ending with a 'goodloop' is precisely what I want to get. If I combine a BIT operation, followed by a branch, and a EOR operation, I can safely land on for the value I want to get rid of (here, the 1.79mhz clock value, that is either $20, or $40), and not risk breaking anything else. So as long as I make sure to get the BIT branch correctly, and then EOR the value I tested before branching, I should end with that value removed without affecting everything else, and if it branched at the wrong place, the value would be added, instead. That's worth giving it a shot for sure. 1 Quote Link to comment Share on other sites More sharing options...
ivop Posted August 31, 2021 Share Posted August 31, 2021 (edited) Uploaded the fake and one real RMT standalone libraries to github. https://github.com/ivop/rmt-sa-libs The libraries to use to see how RMT calls its DLLs. real/sa_c6502 is the real deal. The same library that has been distributed with RMT since 2003. But look how compilers have been improved since: 53248 Feb 2 2003 sa_c6502.dll vs 24064 Aug 31 19:16 sa_c6502.dll It's almost 55% smaller now with gcc -O3 Oh, and yes, it works like before. Now we can see if/how RMT changes memory between calls to sa_c6502. Does it? And we could replace the memory with the player we want, no matter how big it is Edited August 31, 2021 by ivop 2 1 Quote Link to comment Share on other sites More sharing options...
VinsCool Posted August 31, 2021 Author Share Posted August 31, 2021 Okay, finally, I figured out a method that is 100% guaranteed to work this time I was an idiot, I started over complicating the process, but I only had to be smarter than the code. So to make a quick summary, here's what I finally stuck to after I realised how much I was on the wrong track: - check for Distortion 2 for the first step - proceed to the hijack like earlier (since that part did work perfectly fine after all) - ORA the new AUDCTL value ($20 or $40) after the checks passed with trackn_audtl,x, then ORA with a new variable called v_dist2flag in the zeropage, then STA that value in v_dist2flag - at the moment all 4 channel's own trackn_audctl are ORA'd together, include the v_dist2flag in the process, making all AUDCTL values written in memory - once the step above is done, LDA #0, and STA into v_dist2flag to reset it for the next time the rmtplayr is called Obviously, Stereo is not yet supported with this method, but that can be worked around very easily, in the same way the other hijacked code blocks duplicates were included when it was necessary. So yay, I could have done this at the very beginning to avoid wasting my time, but now I know how this could work haha Distortion 2 TEST3.obx Distortion 2 TEST3.rmt 5 Quote Link to comment Share on other sites More sharing options...
VinsCool Posted August 31, 2021 Author Share Posted August 31, 2021 Alright, it's done. I've tested it, everything seems to work exactly like it is wanted. Now Distortion 2 will hijack the 1.79mhz clock automatically, there will be virtually no difference other than that This was based directly on the Patch 16 Beta5 code, but I had to comment out the entire 16-bit code because I was not able to fit everything together. So the Distortion A and C 15khz automatic tuning adjustments is still there, and now there's the automatic Distortion 2 1.79mhz clock, just no 16-bit for the time being. A loss for a gain In the .zip I included the .exe, .dlls, ASM code I edited, and prebuilt player binaries. Now @emkay have a treat and show us what you can do! RMT Distortion 2 Hack.zip 3 1 Quote Link to comment Share on other sites More sharing options...
emkay Posted August 31, 2021 Share Posted August 31, 2021 (edited) Now the thing seems to work: here a 1st "quickest" answer.... It's possible to handle gen 2 as a gen A modulation, after all possiblities have been exhausted already The tune in the package... Edited August 31, 2021 by emkay 5 Quote Link to comment Share on other sites More sharing options...
VinsCool Posted August 31, 2021 Author Share Posted August 31, 2021 Oh damn yes, that makes quite a Bell sound there, seemlessly too! And the tuning is also very nice to hear there Quote Link to comment Share on other sites More sharing options...
emkay Posted August 31, 2021 Share Posted August 31, 2021 OK. LZSS is not adopting it... Quote Link to comment Share on other sites More sharing options...
rensoup Posted August 31, 2021 Share Posted August 31, 2021 8 minutes ago, emkay said: OK. LZSS is not adopting it... nope, I'd have to make another patch version to emulate Vinscool's, which will probably change every day for the next year ? 1 Quote Link to comment Share on other sites More sharing options...
emkay Posted August 31, 2021 Share Posted August 31, 2021 2 minutes ago, rensoup said: nope, I'd have to make another patch version to emulate Vinscool's, which will probably change every day for the next year ? This is the most (and problably last really ) relevant version. For sure. Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 31, 2021 Share Posted August 31, 2021 33 minutes ago, emkay said: This is the most (and problably last really ) relevant version. For sure. Nah I wouldn't say that.. as... 1 hour ago, VinsCool said: Alright, it's done. I've tested it, everything seems to work exactly like it is wanted. Now Distortion 2 will hijack the 1.79mhz clock automatically, there will be virtually no difference other than that This was based directly on the Patch 16 Beta5 code, but I had to comment out the entire 16-bit code because I was not able to fit everything together. So the Distortion A and C 15khz automatic tuning adjustments is still there, and now there's the automatic Distortion 2 1.79mhz clock, just no 16-bit for the time being. A loss for a gain In the .zip I included the .exe, .dlls, ASM code I edited, and prebuilt player binaries. Now @emkay have a treat and show us what you can do! RMT Distortion 2 Hack.zip 3.25 MB · 3 downloads I'm sure you'll find a way to make it all fit together and streamline everything, each time you've gone about this, be it hours, a day, a week... you come back with something better and leaner. It'll all fall in place when you see it. 1 1 Quote Link to comment Share on other sites More sharing options...
emkay Posted August 31, 2021 Share Posted August 31, 2021 How about a tune that is based on 4 channels using bell sounds? 3 Quote Link to comment Share on other sites More sharing options...
VinsCool Posted September 1, 2021 Author Share Posted September 1, 2021 1 hour ago, rensoup said: nope, I'd have to make another patch version to emulate Vinscool's, which will probably change every day for the next year ? I've spent enough time beta testing this program I know the .erti features allow all of that very nicely and with incredible precision, assuming the user wants to spend the time and efforts for it, that is, haha 1 Quote Link to comment Share on other sites More sharing options...
VinsCool Posted September 1, 2021 Author Share Posted September 1, 2021 47 minutes ago, emkay said: How about a tune that is based on 4 channels using bell sounds? That sounds very good 1 Quote Link to comment Share on other sites More sharing options...
emkay Posted September 1, 2021 Share Posted September 1, 2021 6 hours ago, VinsCool said: That sounds very good It's just the first or second step to set to gen. 2. The sharpness of the tone adds to the rest of the instrument. Also, as the main voice gets a steel touch , the rest of the sounds get a wooden character. Close your eyes and imagine a group of 4 people playing their instruments 2 Quote Link to comment Share on other sites More sharing options...
Sandor / HARD Posted September 1, 2021 Share Posted September 1, 2021 17 hours ago, _The Doctor__ said: Had a feeling we'd see you here! ... pretty inspirational, are you playing with his work yet? Haha, no I'm just going through threads I find interesting sometimes enjoying other ppl's results BTW I always wanted to hack a HardBASS instrument into RMT, so if I wanted to spend time on that I'd surely check this thread out on how to hack RMT! ...but I don't think I'd have the time and dedication to do that TBH. So just enjoying what I see/hear in this topic as it's really nice. 3 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted September 1, 2021 Share Posted September 1, 2021 14 hours ago, ivop said: The same library that has been distributed with RMT since 2003. Can you delta these with the replacement ones people should be using 1 Quote Link to comment Share on other sites More sharing options...
emkay Posted September 1, 2021 Share Posted September 1, 2021 Normally the deep 15kHz sounds on all channel results in a suffocating mashup. Correct gen 2 handling stabilizes the whole thing . 4 Quote Link to comment Share on other sites More sharing options...
