NUC+ FujiNet Firmware update
3 minutes ago, massiverobot said:
I don't need to update my FN in my NUC+, but I want to flash it just to make sure this cable I purchased works and document it for my NUC Guide....
Any reason @mytek that I can't use the current FN firmware that posted on fujinet.online, with the PC flasher?
thanks,
-andy
Other then the NUC FujiNet being a unique version of the FN hardware, it is totally firmware compatible. So flash away :)
Opps one thing I forgot to mention, is that the NUC FN will not automatically put itself in program mode like the one for the stock A8.
To Enter Program Mode:
Power down the FujiNet, then press & hold Butn 'A', then power the FujiNet back up. Hint: This can be done most easily by using the toggle switch in the back to cycle power to the FujiNet while leaving the power pack connected to the NUC -or- it can get it's power via the serial cable connected to the PC.
When the FN has entered program mode you'll see all 3 LEDs dimly light up, that'll let you know you can now proceed with the firmware re-flash via the standard FujiNet Flasher Program.
  • Like 6
  • 1 month later...
  • 3 months later...
41 minutes ago, Marek said:
Thank you!. Went step further and now this....
It seem to communicate with the ESP module. Must be something else.
334797152_Screenshot2021-12-24at18_18_14.thumb.png.c33cbe5471b8f3c2f6d8caec648388c1.png
Do you have an SD card inserted in the FujiNet?  Due to a design change, with my particular hardware I cannot run the updates without an SD card inserted.  Give that a try.
I've posted already in the NUC thread, but what helped was to connect the cable and fujinet, click the flash button and immediatelly, press the A button and hold it, until the "erasing flash" message appeared.
It did work correctly after this.
Not sure how much impact it had, but my sd card was IN.
  • 3 months later...
