+RXB Posted January 27 Share Posted January 27 6 hours ago, Shift838 said: You have the peb board wrong. the RJ45 ports need to go where the cutout for the PC ports are. rotate it right.. Hmmm that works great! If I never need a Power supply installed in the PC Case. Guess I can just lay the Power Supply on the floor next to the PC Case! That would look great huh? My girlfriend and I sent the VSK3000 PC Case back to Amazon and tried for the 4th time to get the VSK4000 from Amazon. But thanks for the help it looks like there is a real issue with what ATX PC Case you can use for the 838-PEB board. Quote Link to comment Share on other sites More sharing options...
+RXB Posted February 10 Share Posted February 10 So got the same PC case that Shift838 has in photos. Got PEB board installed and the guides installed. But with a 400W power supply no cards led light up? Quote Link to comment Share on other sites More sharing options...
+9640News Posted February 10 Share Posted February 10 Is there a power switch mod needed? Quote Link to comment Share on other sites More sharing options...
+9640News Posted February 10 Share Posted February 10 If the fan(s) are not blowing, then you need the mod as there was something peculiar about the type of switch used on all the cases. 1 Quote Link to comment Share on other sites More sharing options...
+RXB Posted February 10 Share Posted February 10 1 hour ago, 9640News said: If the fan(s) are not blowing, then you need the mod as there was something peculiar about the type of switch used on all the cases. No the power supply lights up but the cards do not and I am perplexed as to why? Ok the 838 flex card does light up. And after I installed it the 32K card does flash on when power is turned on but goes out, guess that means it works. 1 Quote Link to comment Share on other sites More sharing options...
Shift838 Posted February 19 Author Share Posted February 19 On 2/10/2023 at 5:53 PM, RXB said: No the power supply lights up but the cards do not and I am perplexed as to why? Ok the 838 flex card does light up. And after I installed it the 32K card does flash on when power is turned on but goes out, guess that means it works. That is the expected behavior. 1 Quote Link to comment Share on other sites More sharing options...
