PlusROM High Score Club
Al_Nafuur
If enough users (PlusCart or emulator) want to, we could also play an HSC season or individual challenges.
We would only have to discuss how these events should look like and find someone that wants to moderate it.
I can add a section for these events to the HSC homepage and the database.
Everything would run more or less automatically, so it should be little administrative work for the moderator. Except, of course, for the hassle with users whose scores have not been sent, and of course the inevitable discussion about whether the scores someone has sent are really legit, or whether he has cheated.
@Octavio Pinho Bokel has allowed Hellway to be added to the PlusROM High Score Club.
Octavio did a wonderful job making this game, and It's a lot of fun to play!
Hellway has 256 game variations and is now the game with the most variations in the HSC, ahead of Asteroids with only 99 variations.
The source code with the PlusROM functions for the HSC backend and PAL60 colors added can be found in my fork here:
https://github.com/Al-Nafuur/hellway
As always, PlusCart user/tester can find the PAL60, and NTSC versions in the PlusStore directory "Public ROMs\PlusROMs\High Score Club"
The NTSC version can be played online in javatari.js. The ROM-file can also be played with Gopher2600.
The "PlusCart High Score Club" page for Hellway:
https://highscore.firmaplus.de/?game_id=35
  • Thanks 2
3 hours ago, devwebcl said:
Certainly a game I must play, anyway I've been playing Amoeba Jump, trying to get your 50k high score
You should register at the PlusStore and connect your PlusCart to your account, so your PlusStore username appears in the HSC tables and not "unknown PlusCart user 168"
"Smurf: Rescue in Gargamel's Castle" has been modified for the PlusCart High Score Club. Thank you @DEBRO for the perfectly labeled and commented disassembly.
The source code with the PlusROM functions for the HSC backend added can be found at the new PlusROM example/hacks github repository here:
https://github.com/Al-Nafuur/PlusROM-Hacks/tree/main/High Score Club hacks/Smurf HSC
As always, PlusCart user/tester can find the PAL, PAL60, and NTSC versions in the PlusStore directory "Public ROMs\PlusROMs\High Score Club"
The "PlusCart High Score Club" page for "Smurf: Rescue in Gargamel's Castle":
https://highscore.firmaplus.de/?game_id=44
  • Thanks 2
Congratulations on the first place at Amoeba Jump:
If you have a screenshot, you can PM it to me if you want to add it to your score.
I am looking for PlusCart users with a Track & Field controller, that like to test the "Missile Command Arcade hack" - HSC hack.
It looks like the non Track & Field version of @Nukey Shay's "Missile Command Arcade hack" doesn't work correctly. I can't fire from the right base (tested on stella and on my 2600 PAL hardware with PlusCart)
14 minutes ago, sramirez2008 said:
My mistake.
Not a mistake, I hadn't shared the ROM with you before.
Your Score had been reported, but the BCD values where in the wrong order.
I uploaded a new version to the shared folder and fixed the score in the Database.
The Missile Command Arcade hack (Track & Field version) by @Nukey Shay has been modified for the PlusROM High Score Club.
Sadly, Nukey Shay (Kurt Howe) passed away last year. As I discovered, just a month after I added his Pac-Man 8K hack to the PlusROM HSC. RIP Nukey Shay, and thank you for all the awesome hacks and publishing your source code, so that noobs like me can learn from it.
The source code with the PlusROM functions for the HSC backend added can be found at the PlusROM example/hacks github repository:
https://github.com/Al-Nafuur/PlusROM-Hacks/tree/main/High Score Club hacks/Missile Command Arcade HSC
PlusCart user/tester can find the combined version (PAL60 and NTSC can be switched with the Color/BW switch) in the PlusStore directory "Public ROMs\PlusROMs\High Score Club"
The combined version can be played online in javatari.js. The ROM-file can also be played with Gopher2600.
The "PlusCart High Score Club" page for Missile Command Arcade:
https://highscore.firmaplus.de/?game_id=45
  • Like 5
  • 2 weeks later...
23 hours ago, devwebcl said:
Cherity is quite good
I didn't know that @cd-w has released the source code. ?
If it is okay for him, it could be modified for the PlusROM HSC.
There is enough free ROM space to add the code. But the PlusROM hotspots have to be cleared in some banks. Chetiry has a build in high score table, so it could be the first HSC PlusROM that shows the online table from the backend response..
  • 2 weeks later...
Chris Walton (@cd-w) has allowed Cetiry to be added to the PlusROM High Score Club.
Chetiry is an awesome game and it is the first game in the PlusROM High Score Club that also displays the current online HS tables (only the first 3 characters of the username are shown).
The source code with the PlusROM functions for the HSC backend can be found in my fork here:
https://github.com/Al-Nafuur/PlusROM-Hacks/tree/main/High Score Club hacks/Chetiry
As always, PlusCart user can find the PAL, and NTSC versions in the PlusStore directory "Public ROMs\PlusROMs\High Score Club"
The NTSC version can be played online in javatari.js. The ROM-file can also be played with Gopher2600 or Stella (since version 6.6).
The "PlusCart High Score Club" page for Chetiry:
https://highscore.firmaplus.de/?game_id=47
  • Like 4
I wonder why this version does not have a piece preview.
I have a rom with this feature.
