Which example is more readable and "human-friendly"?
Meta [
	Title:   {FizzBuzz math "game"}
	Author:  "Kaj de Vos"
	Rights:  "Copyright (c) 2021 Kaj de Vos"
	License: {
		PD/CC0
		http://creativecommons.org/publicdomain/zero/1.0/
	Notes: {
		https://wiki.c2.com/?FizzBuzzTest
		https://www.rosettacode.org/wiki/FizzBuzz
For counter 100 [
	Third?: unless modulo counter 3 [write "Fizz"]
	Any [
		unless modulo counter 5 [write "Buzz"]
		third?
		write counter
	Write " "
Write new-line
or
For number 100 [
  p: 0
  unless modulo number 3 [p: 1 write "Fizz"]
  unless modulo number 5 [p: 1 write "Buzz"]
  if p = 0 [write number]
  Write " "
Write new-line
1, 2 or none? ;)
maybe this one?
For number 100 [
  p: 0
  unless p [write number]
  Write " "
Write new-line
Edited by zbyti
I think Zbyti's version follows the Principle of Least Surprise. I optimise my programs heavily with REBOL constructs that are elegant and that I know to generate efficient code, but not all of them are available in other languages. I want the examples to show off Meta's strengths, but in beginners' guides I will start with simpler constructs.
Many REBOL examples are different because they disregard efficiency. I think they make too much use of the dynamic features of the language. I inherited that attitude from Atari.
Many programmers like to feel smart by writing very dense code and like in their eyes "elegant solutions". In many software houses such approach is considered a "bad habit" leading to "write-only code". Such code is hard to read for the ones who didn't write it, require compilation of the code in the head, is hard to modify and makes life harder for new programmers. While languages nowadays are very powerful and flexible it also takes experience not to use all the fancy features the language provides.
I think my last example shows a problem in trying to talk to the computer with too many words:
[unless modulo number "works" do something] in other words: do something if something happens.
unless p I'm reading - do something if something didn't happen.
Edited by zbyti
I think what we are missing is comments !!!
yes, that age old thing that many programmers just don't do.
As this is a new language, adding a comment alongside each line of code will help explain not
just what the program is doing, but also give insights on how the language works
In the end, these problems are caused because our brains are limited. A language that can express more concepts in the same space is said to be more expressive. Thus, bigger challenges fit in your head when the programs are smaller.
It seems to be a problem of communication between human and machine, but the machine actually concurs. It, too, is limited, and smaller programs perform better.
This example is ten lines and is compared with equivalent versions in hundreds of other languages. That should be enough for such an example.
As I said, in beginners' guides I will build it up as simple as possible, keeping the feedback here in mind.
Meta is not APL:
https://www.rosettacode.org/wiki/FizzBuzz#APL
or K:
https://www.rosettacode.org/wiki/FizzBuzz#K
Meta is deliberately designed to be more verbose, literally. That's why I claim it to be closer to natural language. It is designed to work at a similar verbosity as human language.
4 minutes ago, zbyti said:
I think that symbolic languages are more exact and does not get the brain involved in understanding words but only problems.
Meta is just as exact. It's Lisp with types added. But it tries to use real English words instead of weird abbreviations, and only the math symbols that many people are familiar with.
If I'm correct, adults usually do not read single letters in words but read familiar words as a symbols, leading to these tasks like "count the Fs" or https://www.lookhuman.com/design/58406-if-you-can-read-this-you-are-smart/tshirt (while in case of children just learning it's an issue).
I read the biography of Stanisław Ulam and there was a discussion about what language is better and mor suitable for certain things. The gentlemen knew 3 languages then, maybe four (Latin?).
If I'm not mistaken they found German more suitable for mathematics than Polish, I don't remember what they said about the French language ;)
yes, I think this only happens if the words are relatively small in number and are used frequently - such as key words in programming languages.
