For the code
    flags= make static binary! sizepl
    flags-ptr: flags
    for-all flags-ptr
;        change flags-ptr 1 ; "change" has no value
        poke flags-ptr 0 1
I receive
** Script error: "for-all" does not work on types combination:
Parameter types:
1: static-binary! [flags-ptr
2: expressions list block! [
        poke f...
At: [
    for-all flags-ptr
        poke flags-ptr 0 1
In: [
    count: 0
    i: 0
    flags= make static binary! si...
Near: [
    while iter <= 10
        count: 0
        i: ...
4 minutes ago, Kaj de Vos said:
Thanks, made another fix.
now the compilations is getting error later on pick:
** Script error: cannot use pick on none! value
** Where: has-arguments any do if case either compile-expression foreach unless either compile-expression foreach unless either compile-expression foreach emit-C-program either do either either either -apply-
** Near: has-arguments third arguments-of code all [
    constant: se...
the code:
natural! [count i]
while iter <= 10
    count: 0
    i: 0
    flags-ptr: flags
    for-all flags-ptr
        poke flags-ptr 0 1
    i: 0
    while i <= size
        p: pick flags i
        if p = 1
            prime: ( i * 2 ) + 3
            k: prime + i
            while k <= size
                poke flags k 0
                k: k + prime
            count: count + 1
        i: i + 1
    iter: iter + 1
24 minutes ago, Kaj de Vos said:
Should be fixed now.
Compiling file sieve.meta
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  1248  100   344  100   904    246    647  0:00:01  0:00:01 --:--:--   895
** Script error: insert does not allow none! for its series argument
** Where: either do if case either compile-expression foreach unless either compile-expression foreach unless either compile-expression foreach emit-C-program either do either either either -apply-
** Near: either any [
    not has-arguments second arguments-of code
16 hours ago, ilmenit said:
if you see there any places to improve the code, would be great to get your hints here.
Here goes.
iter: 1
iter is inferred as integer!. You could optimise it like this:
byte! iter
It wouldn't matter much for speed here, but it would make the executable a bit smaller. But you don't need iter, because you can just do:
repeat 10 [
unsafe!!! constant reference volatile byte! [     ; OS     RTCLOK2= ~13     RTCLOK3= ~14 ]
Address assignments increment automatically, so you can write:
    ; OS
    RTCLOK2= ~13
    RTCLOK3
RTCLOK2: 0 RTCLOK3: 0
RTCLOK3: RTCLOK2: 0
is shorter, in source and possibly also in binary code, depending on the back-end.
The first
i: 0
is superfluous.
You can fill the array with
change/repeat flags 1 sizepl
The second
i: 0
is off by one.
while i <= size
for starts with one by default to match series indexes. Just do
for i size [
p: pick flags i         if p = 1
p is inferred as integer!. This is inefficient. But you don't need p:
if (pick flags i) = 1
Experienced REBOL programmers like to simplify this:
if 1 = pick flags i [
Unlike REBOL, Meta supports the C style of treating 0 as an option value, so you can just do
if pick flags i [
( i * 2 ) + 3
This can be optimised as
i << 1 + 3
But watch out that you need to adjust for 1-indexing.
Whether this produces better code depends on the back-end.
count: count + 1
The remaining increment can be optimised as
increment count
** Script error: "change/repeat" does not work on types combination:
Parameter types:
1: static-binary! [flags 1 sizepl
    fo...
2: byte! [1 sizepl
    for i si...
3: natural16! [sizepl
    for i size...
At: [
    for i size
In: [
    count: 0
Near: [
    repeat 10
        count: 0
        flags= mak...
Quote
Your indexing is off by one. Indexing in REBOL and Meta is 1-based. In the future, this will produce a bounds error.
It's a topic for a flame war, but are you sure it's good idea to follow 1-based indexing of Rebol? You are dropping compatbility with Rebol anyway.
Many algorithms working on arrays (esp. of more than 1 dimension) are much simpler with 0-based indexing (and if you are targeting 8bit machines then you will work with them primarily). Modern languages that primarily 1-based have ability to set arbitrary indices (Julia, Pascal). Also nowadays "a must" are bindings to different libraries... and most of them are done in 0-based languages.
Quote
i << 1 + 3
This one of examples why 1-based indexing is not that great idea.
Made a partial fix.
Out of time for today.
Yes, and yes, it's more human-friendly. We have plenty of unfriendly languages already.
Doesn't matter, you just compensate.
It's still math. Surely, a mathematically inclined person can easily adapt.
23 minutes ago, Kaj de Vos said:
That's a comparison, you should not have a " = " in there.
No.
  RTCLOK=  ~14
  P0PF=    ~2C0
  HPOSM0=  ~D004
  GRAFM=   ~D011
  COLPM0
  COLPM1
  COLBK=   ~D01A
  RANDOM=  ~D20A
  WSYNC=   ~D40A
  VCOUNT
this don't work, last assignment must have explicit address.
Why not give the programmer the option to set the base like some languages already do
Best of both worlds
Atari ST BASIC uses OPTION BASE  which can be 0 or 1
Edited by TGB1718
Update
