SINGLE TOOTH Posted December 25, 2021 Share Posted December 25, 2021 (edited) I spent money I shouldn't have and time I could have used better on something else to do this. Used a harbor freight case and put a shoddy metal tape stripe on it to house my PRO SYSTEM. I figure I can still fit the AC adapter in the empty cutout and put the NES style controllers on top of the system when in transport/storage. There is a cutout where the concerto cart is stored. I'd put an Atari sticker on it but I don't have any or a way to make some. It's kind of a stupid idea but if it's a "Pro" system, it needs to be stored as such. This was the smaller 3800 model of case and didn't feel like spending $60 for the bigger 4800 model. Edited December 25, 2021 by SINGLE TOOTH Need 3 Quote Link to comment Share on other sites More sharing options...
john_q_atari Posted December 25, 2021 Share Posted December 25, 2021 Well as they say, it's your money... 1 Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted December 25, 2021 Author Share Posted December 25, 2021 I may have to keep my 7800 I'm the attic or garage due to space constraints so this case may actually help keep it from getting nasty. Quote Link to comment Share on other sites More sharing options...
john_q_atari Posted December 25, 2021 Share Posted December 25, 2021 Makes sense. Well that case will certainly keep the bugs and animal waste products out. Quote Link to comment Share on other sites More sharing options...
Jinks Posted December 26, 2021 Share Posted December 26, 2021 10 hours ago, SINGLE TOOTH said: I may have to keep my 7800 I'm the attic or garage due to space constraints so this case may actually help keep it from getting nasty. The circuit board from the constant temp changes will corrode and the 7800 will be junk. Bad ideas. Sell it or find a place in a temperature controlled environment. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted December 26, 2021 Share Posted December 26, 2021 (edited) Found this. Mercari This looks good too. https://www.harborfreight.com/18-in-x-6-in-x-13-in-black-aluminum-case-69318.html https://www.harborfreight.com/18-in-x-6-in-x-13-in-silver-aluminum-case-69315.html Amazon Etsy Edited December 26, 2021 by 0078265317 Quote Link to comment Share on other sites More sharing options...
SINGLE TOOTH Posted December 26, 2021 Author Share Posted December 26, 2021 14 hours ago, 0078265317 said: Found this. Mercari This looks good too. https://www.harborfreight.com/18-in-x-6-in-x-13-in-black-aluminum-case-69318.html https://www.harborfreight.com/18-in-x-6-in-x-13-in-silver-aluminum-case-69315.html Amazon Etsy That first Atari case is awesome. That's kind of the spirit I was trying to capture. I did order that dust cover. Had my eye on that for a while. Quote Link to comment Share on other sites More sharing options...
+Stephen Moss Posted December 30, 2021 Share Posted December 30, 2021 On 12/25/2021 at 4:22 PM, SINGLE TOOTH said: I may have to keep my 7800 I'm the attic or garage due to space constraints so this case may actually help keep it from getting nasty. Depeding on where you live if the year round temperature does not vary much then either location would be OK, it it varies a lot, particualry between winter and summer temperatures and you have to store it in one of those locations use the one where the teperature has the least fluctuation as the thermal expansion/contraction caused by wildly differing temperature could eventually result in bad solder joints. Also, there is likely to be more moisture in the air in those locations so you may want to consider throwing a couple of silica gel packs in to the case to absorb any moisture that does get in. 1 Quote Link to comment Share on other sites More sharing options...
