tebe Posted February 10, 2022 Share Posted February 10, 2022 https://github.com/tildearrow/furnace ... ... Atari 2600 (TIA) - yes AtarI 7800 (TIA) - yes Atari 800 (POKEY) - for whats ? no one uses this 6 2 Quote Link to comment Share on other sites More sharing options...
tebe Posted February 10, 2022 Author Share Posted February 10, 2022 Planned for 0.6 release, we'll see 2 Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted February 10, 2022 Share Posted February 10, 2022 @tebe Perhaps a niave question on my part () but can I ask... what is it? 1 Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted February 11, 2022 Share Posted February 11, 2022 Just a music authoring system, be creative with your fave machine as long as you are musical .. Count's me out. Also not 8 bit Atari computer (as yet?) 1 1 Quote Link to comment Share on other sites More sharing options...
pseudografx Posted February 11, 2022 Share Posted February 11, 2022 Nice but so far kind of useless for Atari development as it cannot output an Atari executable. Perhaps some time in the future. 2 Quote Link to comment Share on other sites More sharing options...
zbyti Posted February 11, 2022 Share Posted February 11, 2022 On 2/10/2022 at 12:47 PM, tebe said: Atari 800 (POKEY) - for whats ? no one uses this https://kometbomb.github.io/klystrack/ https://github.com/kometbomb/klystrack/ 1 Quote Link to comment Share on other sites More sharing options...
emkay Posted February 12, 2022 Share Posted February 12, 2022 For me a notation transfer from the "Furnace Tracker" to RMT would be sufficient enough to produce executables 1 Quote Link to comment Share on other sites More sharing options...
miker Posted March 13, 2022 Share Posted March 13, 2022 On 2/10/2022 at 2:16 PM, tebe said: Planned for 0.6 release, we'll see Atari Lynx support... yes. Look for examples @ Atari Lynx forum section. 1 Quote Link to comment Share on other sites More sharing options...
+karri Posted April 23, 2022 Share Posted April 23, 2022 This could turn out to be a good thing for my Wizzy music! Quote Link to comment Share on other sites More sharing options...
miker Posted December 25, 2022 Share Posted December 25, 2022 POKEY support from Furnace v0.6pre2 (beta) on https://github.com/tildearrow/furnace/releases smus-pokey.ogg smus.fur 11 Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 23, 2023 Share Posted October 23, 2023 The full release of v0.6 was done 3 weeks ago. Quote Link to comment Share on other sites More sharing options...
rdefabri Posted October 23, 2023 Share Posted October 23, 2023 Love the idea of a multiplatform tracker, but have some concerns about how well the POKEY support is. Outside of working on a real machine, which isn't logistically easy, I'd prefer to stick with RMT, years of development behind it. 1 Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted October 23, 2023 Share Posted October 23, 2023 27 minutes ago, rdefabri said: I'd prefer to stick with RMT, years of development behind it. RMT uses DLLs to provide the 6502 and Pokey implementation and they, for example, use the code from Atari800 or Altirra and so worrying about Pokey support isn't overly a concern. One would hope the tracker involved is doing something similar. 1 Quote Link to comment Share on other sites More sharing options...
rdefabri Posted October 23, 2023 Share Posted October 23, 2023 19 minutes ago, Wrathchild said: RMT uses DLLs to provide the 6502 and Pokey implementation and they, for example, use the code from Atari800 or Altirra and so worrying about Pokey support isn't overly a concern. One would hope the tracker involved is doing something similar. Fair enough and understood. I'm willing to give it a try as I'm looking to expand to other platforms (such as C64). I did launch Furnace Tracker, it had a slick opening screen Quote Link to comment Share on other sites More sharing options...
+MrFish Posted October 23, 2023 Share Posted October 23, 2023 3 hours ago, Wrathchild said: One would hope the tracker involved is doing something similar. From the documentation: POKEY core: - Atari800 (mzpokeysnd): does not emulate two-tone mode. - ASAP (C++ port): default core. the sound core used in the ASAP player. most accurate option Effects: - 10xx: set waveform. - 0: harsh noise (poly5+17) - 1: square buzz (poly5) - 2: weird noise (poly4+5) - 3: square buzz (poly5) - 4: soft noise (poly17) - 5: square - 6: bass (poly4) - 7: buzz (poly4) - 11xx: set AUDCTL. xx is a bitmask. - bit 7: 9-bit poly mode. shortens noise. - bit 6: high channel 1 clock (-1.79MHz on NTSC). - overrides 15KHz mode. - bit 5: high channel 3 clock (-1.79MHz on NTSC). - overrides 15KHz mode. - bit 4: join channels 1 and 2 for a wide period range. - use in conjunction with bit 6. - channel 2 becomes inaccessible when this is on. - bit 3: join channels 3 and 4 for a wide period range. - use in conjunction with bit 5. - channel 4 becomes inaccessible when this is on. - bit 2: high-pass filter (channels 1 and 3). - filtered output on channel (I suggest you to set channel 3 volume to 0). - use for PWM effects (not automatic!). - bit 1: high-pass filter (channels 2 and 4). - filtered output on channel (I suggest you to set channel 4 volume to 0). - use for PWM effects (not automatic!). - bit 0: 15KHz mode. - 12xx: toggle two-tone mode. - when enabled, channel 2 modulates channel 1. I don't know how, but it does. - only on ASAP core. POKEY Instrument Editor Macros: - Volume: volume sequence. - Arpeggio: pitch sequence. - AUDCTL: audio control register sequence: - poly9: reduces size of LFSR. only on noise waveforms! - high1: runs channel 1 at 1.79MHz. - high3: runs channel 3 at 1.79MHz. - 16-bit 1+2: enables 16-bit frequency mode by combining channels 1 and 2. - 16-bit 3+4: enables 16-bit frequency mode by combining channels 3 and 4. - filter 1+3: applies a high-pass "filter" by combining channels 1 and 3. - filter 2+4: applies a high-pass "filter" by combining channels 2 and 4. - 15KHz: runs channels at 15KHz. - Waveform: wave selection sequence: - 0: harsh noise (poly5+17) - 1: square buzz (poly5) - 2: weird noise (poly4+5) - 3: square buzz (poly5) - 4: soft noise (poly17) - 5: square - 6: bass (poly4) - 7: buzz (poly4) - Pitch: fine pitch. [Edit] Improved formatting of the lists and added missing text that didn't get copied from the PDF. Quote Link to comment Share on other sites More sharing options...
SlidellMan Posted October 24, 2023 Share Posted October 24, 2023 I like Furnace Tracker, but there seems to be a limit when it comes to using samples. (I. E. Certain ones will stop getting higher after a certain note.) It is great for Lynx, FM, MSM, and PSG sounds. Quote Link to comment Share on other sites More sharing options...
