Daniel Santos Posted April 12, 2022 Share Posted April 12, 2022 Hello, I have an Atari 520 STFM in perfect working condition with a CosmoX connected to the floppy interface, and want to mount a windows directory as a Hard disk in order to transfer files from the hard disk to the floppy images. Then I take the floppy images and load them through the network to the CosmoX and they appear in TOS with the files in them. Problem : I haven't figured out how to map the directory. I have tried ACSI, SCSI and IDE. when I reboot the emulator it complains of not knowing the size of the directory where the emulator is, although I had configured a different directory. Can anyone help me ? Thanks, Regards Quote Link to comment Share on other sites More sharing options...
zzip Posted April 13, 2022 Share Posted April 13, 2022 What you want is "GEMDOS drive", it should be the 4th option in the hard disk menu after ACSI, SCSI, and IDE. It's pretty simple to set up, just pick the Windows directory to map to, and it will become your C drive. You might need to reboot your emulator and add a C drive icon to the desktop if it doesn't automatically appear. The other options ACSI/SCSI/IDE require a hard disk image which is harder to set up since you will need to install the hard disk drivers on them. The GEMDOS option doesn't need drivers and is pretty straightforward. Quote Link to comment Share on other sites More sharing options...
Daniel Santos Posted April 13, 2022 Author Share Posted April 13, 2022 Tried the GEMDOS drive and it works like a charm. Thanks for the info. I am still a noob on Atari. Only thing I know is that I wanted one when I was a kid but didn't have the money for it. HAHA 1 Quote Link to comment Share on other sites More sharing options...
