+Larry Posted April 23, 2022 Share Posted April 23, 2022 If so, what version of the Happy Enhancement did you receive and install? There are H, L, and X versions, and I need to know what kind they are supplying. Or did you have to call B&C and give them more info about your 810 drive? There is a similar issue with the Rev7 upgrade rom. You need the serial number of the Enhancement of <5000 or >5000 to get the correct rom. Quote Link to comment Share on other sites More sharing options...
+videofx Posted April 23, 2022 Share Posted April 23, 2022 I have and the version you receive is based on your 810. I called B&C to Mae sure I received the correct version. 1 Quote Link to comment Share on other sites More sharing options...
+Larry Posted April 23, 2022 Author Share Posted April 23, 2022 Outstanding! Thanks. Quote Link to comment Share on other sites More sharing options...
cwilbar Posted April 23, 2022 Share Posted April 23, 2022 3 hours ago, videofx said: I have and the version you receive is based on your 810. I called B&C to Mae sure I received the correct version. Anyone have more info on these different versions ? To my knowledge there are MPI mech 810s, Tandon mech 810s, and early 810s (MPI mech, no analog board, with or w/o data separator). The latter drives (early 810s) should get newer power boards and the analog board. The later MPI and Tandon drives, I though were identical minus front bezel and the mechanism. As far as I know the firmware and electronics are the same ? So why are there different Happy versions ? 810s have been worked on, upgraded, etc over the years, so you could easily have a drive who's internals don't match the serial # on the decal on the case. Quote Link to comment Share on other sites More sharing options...
+Larry Posted April 24, 2022 Author Share Posted April 24, 2022 There is some information about this in the Happy 810 Enhancement Installation Instructions. My recollection from many years ago is that I had to call Happy Computers and give them info about my 810 drive. My original drive required an "H" model. Here are the install instructions: Happy 810 Enhancement Installation Instructions.pdf Quote Link to comment Share on other sites More sharing options...
cwilbar Posted April 25, 2022 Share Posted April 25, 2022 It would appear that at least -H and -L were for different socket types on the sideboard. Atari probably used different socket suppliers, and to get a good fit maybe different size pins were required ? Can anyone confirm if this is the only differences between the -H, -L, and -X Happy 810 enhancement versions ? Quote Link to comment Share on other sites More sharing options...
spicyjack Posted April 23, 2023 Share Posted April 23, 2023 On 4/24/2022 at 9:29 PM, cwilbar said: It would appear that at least -H and -L were for different socket types on the sideboard. Atari probably used different socket suppliers, and to get a good fit maybe different size pins were required ? Can anyone confirm if this is the only differences between the -H, -L, and -X Happy 810 enhancement versions ? As mentioned in... There are 3 versions of the Happy810: HE810S-X - HE810S-H and HE810S-L. Installing the X-version requires a lot of soldering. Small warning in the manual: 'Do not use a soldering gun'. This one was the cheapest version. With the H- and L-version the color of the 40-pin socket (ed. re-atari: I presume the author means a 40-pin socket on the sideboard) is decisive. A black socket requires version L, a blue or brown socket version H." Quote Link to comment Share on other sites More sharing options...
