JJB Posted October 5, 2022 Author Share Posted October 5, 2022 ... and updating the AVR the normal way now works fine? Quote Link to comment Share on other sites More sharing options...
mvancopp Posted November 1, 2022 Share Posted November 1, 2022 I thought I'd report an update. I picked up a QI machine and finally had time to repair it (a bad OS ROM, MSByte). This machine does not have the 2.2 version, just the standard version in the black and silver (b/s) consoles. The 1.Q update is working well. I tested about 15 cartridges and all worked perfectly, and all operations have been stable. The intermittent issue that the SD card in not selected at power-up is the same as I experience on the b/s consoles; on certain SD cards/finalgrom combinations you must press the FinalGrom reset to get the menu to show up after the power is turned on. Thanks @JJB for the effort to produce 1.Q. It is much appreciated. Thanks, Mark 1 1 Quote Link to comment Share on other sites More sharing options...
eightbit Posted November 25, 2023 Share Posted November 25, 2023 On 11/1/2022 at 12:12 AM, mvancopp said: on certain SD cards/finalgrom combinations you must press the FinalGrom reset to get the menu to show up after the power is turned on. Indeed. I have dozens of SD cards here from 2GB to 32GB, from Sandisk to Toshiba to Kingston to Apacer...to..you get it. And they ALL require the reset as you describe, all but one. One Adata crappy 2GB card does not. Any idea why this is? Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted November 25, 2023 Share Posted November 25, 2023 6 hours ago, eightbit said: Indeed. I have dozens of SD cards here from 2GB to 32GB, from Sandisk to Toshiba to Kingston to Apacer...to..you get it. And they ALL require the reset as you describe, all but one. One Adata crappy 2GB card does not. Any idea why this is? I have numerous 256MB SanDisks, and a 1GB SanDisk, which do not perform this way. I do, however, have a 2GB and an 8GB SanDisk which both behave in this manner. Conclude what you will. Quote Link to comment Share on other sites More sharing options...
eightbit Posted November 26, 2023 Share Posted November 26, 2023 12 hours ago, OLD CS1 said: I have numerous 256MB SanDisks, and a 1GB SanDisk, which do not perform this way. I do, however, have a 2GB and an 8GB SanDisk which both behave in this manner. Conclude what you will. Thanks for the heads up! I have to dig around for some smaller cards. I usually find them in old cameras at Goodwill 1 Quote Link to comment Share on other sites More sharing options...
