[WIP] 8 Tanks (Quadtari)
Fort Apocalypse
8 Tanks: a DPC+ (32K) game for the 2600 with Quadtari and four sets of Tennis paddles. (In theory, it should work with a Harmony cart, etc., and it works in Stella, but not in Javatari.)
Important note: the Quadtari only supports the paddle buttons, not the knobs. (see Quadtari thread)
This is a work-in-progress, and for now is just the tanks moving around and shooting without blowing anything up, so it's more of a demo until one of the next few releases.
To configure game to play in Stella 6.7 (you may have to do this for each release):
  1. Highlight the game in Stella
  2. Options -> Game Properties -> Controllers -> Quadtari button
  3. Select Paddles for each of the four controllers
  4. Click Ok, Ok, then Close
  5. Start game and use these default keys to emulate paddle buttons to control the tanks via the default key mappings:
    space, 4, F, 6, shift-space, shift-4, shift-F, shift-6.
Done:
  • Can control and move 8 tanks
  • If you leave the button unpressed, the tank spins slowly clockwise.
  • If you press the button, the tank moves forward and fires. (Using alternating frames using alt coords swapping through temp vars, ball is shared between player0-1, missile0 is shared between player2-3, missile1 is shared between player4-5, player9 dot is shared between player6-7.)
  • Sound when tanks shoot
  • Colors, playfield, and tank placement similar to Tank 8
  • Playfield looks similar to that of Atari Tank 8
  • Projectiles stop when hit playfield
  • Fixed some projectile bugs
Planned:
  • Collision detection for missiles hitting another player.
  • 8 player scores. Alternating 4-player scores with color matching tank color.
  • Blow up tanks when shot.
  • Sound when a tank blows up.
  • Some sense of game over (either some number of tanks per player or a time limit?). Note: time limit may be easier; it would only require a single indicator.
  • Bug: some tanks shoot in the wrong direction for some tank positions.
  • Bug: some tanks' playfield collision detection for projectiles doesn't seem to work.
Not sure yet whether I should try to add:
Note: If you want to compile it, DPCplus_kernel.asm in same directory extracted from bb-qt-DPCplus.zip in Karl's post with sample code for Quadtari support.
8tanks_0.5.bas.bin 8tanks_0.5.bas
Edited by Fort Apocalypse
  • Like 5
Release 0.1:
  • Can control and move 8 tanks.
  • if you leave the button unpressed, the tank spins slowly clockwise.
  • if you press the button, the tank moves forward.
This release is just a demo of the tanks being able to move around. Tanks can't shoot yet. Feedback is appreciated!
8tanks_0.1.bas.bin 8tanks_0.1.bas
Release 0.3:
  • Attempt to use one pair of swap coords for each of ball, missile0, missile1, and player9 to act as shots from all 8 tanks.
  • Sounds for shots.
Known bugs:
  • Sometimes projectiles initiate in wrong spot, go in wrong direction, may have multiple shots from same location going in different directions, shots get left on screen unmoving, shots don't fire or don't fire in every direction well, shot stays left of playfield and tracks similar to player's y coordinate.
8tanks_0.3.bas.bin 8tanks_0.3.bas
Planning to try to be close to Tank 8 colors with (starting with red in upper-left and going clockwise):
         ntsc pal  secam
red      44   64   44
blue     84   D4   82
green    CC   5C   B8
pinkish  3E   6E   66 (66 for SECAM is also magenta)
tan      FE   4E   0E (0E for SECAM is white)
magenta  5A   8A   86
cyan     AE   9E   9A
yellow   1E   2E   2C
Note: those are my approximations, not official color names, I just eyed it, and hopefully I wrote them down correctly.
(Attached is screenshot of original Tank 8. Note that I'm not trying to reproduce Tank 8.)
Very nice, this is a much cleaner control scheme than I thought of in the other thread. ? Good stuff!
- James
- James
This was the initial easiest effort version of it that just stuck so far! It feels a little vulnerable when you're having to wait on the tank to turn, but if there's anything I can do to make it work better, let me know!
I have a version locally where the projectiles stop on the playfield, but I've not yet gotten past the numerous bugs in the projectiles, which should probably work before doing projectile collisions with players.
I think it works well and is easy to understand right away, it's quite a challenge to make a game where you move AND shoot with just one button! The movement reminds me a lot of the constant rotation of the player in the 2600 homebrew Kuru Kuru Tsuchinoko. Plus, since every player has to use the same control technique everything evens out!
- James
  • 1 month later...
Release 0.5
  • shots stop at playfield
  • fixed: shots now independent between players (I think)
  • stopped using player0; now use player1-8 for tanks (and ball, missile0, missile1, and player9 reused between p1-4 and p5-8 for projectiles)
  • Thanks much to @Karl G for finding that I was dimming qtcontroller to a var that I was also using in another dim and attempting to use, which was screwing everything up in 0.5!
Known bugs:
  • 3 weeks later...
ZeroPage Homebrew is playing 8 Tanks on tomorrow's stream LIVE on Twitch, hope you can join us!
Games:
 WATCH AT 1080P60 FOR FULL QUALITY
