Patrick1123 Posted August 15, 2022 Share Posted August 15, 2022 Recently I have received a Mattel Intellivision from one of my parents friends, who kept the boxes and manuals to every single game. I running into a fuzzy image, even when I clean the cartridge slot I still have to fettle with it to work. Some games work fine, while others are completely unplayable even when they do work. From my research so far it may be a chip issue or bad capacitor. I also don't have the best soldering skills. I am using a hdtv, but I do not think that would matter because I have Atari 2600 and its image is crystal clear. Could anyone link me to a repair service that I can send my system to. I would really appreciate it. Quote Link to comment Share on other sites More sharing options...
walldog1 Posted August 15, 2022 Share Posted August 15, 2022 10 minutes ago, Patrick1123 said: I am using a hdtv, but I do not think that would matter because I have Atari 2600 and its image is crystal clear. Intellivisions are much fussier about getting a good picture than Atari. Are you running straight to the HDTV or through another device? And if yes, what is your set-up? It is possible that your INTV needs a good cleaning and needs some parts, but it would first be best to know the set-up you are using. Also, you can try other channel to see if same results. Quote Link to comment Share on other sites More sharing options...
Patrick1123 Posted August 15, 2022 Author Share Posted August 15, 2022 (edited) 22 minutes ago, walldog1 said: The Coaxial connection on the back of my tv. I use to have CRT I used with it, but I was running into the same issue, last I checked. Should I composite mod it. Tried different channel does not seem to help. Edited August 15, 2022 by Patrick1123 Quote Link to comment Share on other sites More sharing options...
walldog1 Posted August 15, 2022 Share Posted August 15, 2022 Usually to make an INTV work with a HDTV, they need a Mod Kit installed, or be run through a VCR, DVR, or anything with an analog Coax input and Composite output to run to HDTV. Also, click follow topic so you will know when anyone replies to it. You'll get an e-mail notification then. Quote Link to comment Share on other sites More sharing options...
mr_me Posted August 15, 2022 Share Posted August 15, 2022 What are you using for an AV cable? It should be RF shielded. A regular composite video cable can have interference. Are you using a switchbox or direct to the TV RF input. Cartridges not working is a separate issue. Can you give examples of cartridges that work and cartridges that don't work. Quote Link to comment Share on other sites More sharing options...
+fdr4prez Posted August 15, 2022 Share Posted August 15, 2022 Also if the RCA jack on the console is a little oxidized then take an emory cloth or really fine sand paper and give it a good wipe. Both the exterior and if possible get inside it so the RCA cable makes a good contact with the jack. My Atari 2600 had a fuzzy image, but after I cleaned up the RCA it worked well. The 2600 has a hard-wired cable on the console end, but I cleaned up the male end at the end of the cable. Also, I am using an old CRT. As others here have mentioned, if you are going directly into a modern HDTV then that ain't gonna work well. Modern TVs are looking for a digital signal and not the old boob-tube signals of the good ol' days. So if your Atari is crystal clear on it then lucky you. When I connect my consoles to my modern TV I have use a vcr to connect to the consoles and use composite out of the vcr into my modern TV. 1 Quote Link to comment Share on other sites More sharing options...
