atarilux Posted August 25, 2022 Share Posted August 25, 2022 Hello, I have a licence for the Jetbrains software dev package, I mainly use it for Python stuff. However, has anyone here managed to set it up so that I can use CC65 to develop Atari stuff? I am using Notepad++ now which is ok, but more integration and tools would be better. Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 25, 2022 Share Posted August 25, 2022 I use Sublime Text 3 for cc65 development, it's a bit "clunky" until you get used to it, but it is a nice environment to develop in Quote Link to comment Share on other sites More sharing options...
danwinslow Posted August 25, 2022 Share Posted August 25, 2022 VS Code works, too. 1 Quote Link to comment Share on other sites More sharing options...
atarilux Posted August 25, 2022 Author Share Posted August 25, 2022 My thanks to @TGB1718 @danwinslow for your advice. I will check them out, right now I am using a combination of Windows and Macs, which I hope does not complicate either of the above... Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted August 25, 2022 Share Posted August 25, 2022 VS code runs on both 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 26, 2022 Share Posted August 26, 2022 15 hours ago, danwinslow said: VS Code works, too. I never managed to set VSCode to run anything, it seems so complex to create an environment. I used it initially for the Raspberry Pi Pico which was a long winded pain to install and get running, now when I run VSCode it won't do anything other than compile the Pico examples It's as clear as mud on how to set it up for anything else 1 Quote Link to comment Share on other sites More sharing options...
danwinslow Posted August 26, 2022 Share Posted August 26, 2022 (edited) I just use it to edit files, then use the integrated cmdline terminal to run my scripts. Not sure what else you're trying to set up with it. There are some extensions you can load, such as 'Atari Dev studio' and a few others. Use the extensions search feature and look for 'Atari'. And, we are talking about VSCode, right, not Visual Studio? Edited August 26, 2022 by danwinslow 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted August 27, 2022 Share Posted August 27, 2022 16 hours ago, danwinslow said: And, we are talking about VSCode, right, not Visual Studio? Yes, it is VSCode, I can see what your doing, I might try that, I was trying to fully integrate a build system into VSCode, but it's a nightmare to change when already set up for something else. Saying that, Sublime Text 3 once set up is a breeze to use. Quote Link to comment Share on other sites More sharing options...
danwinslow Posted August 27, 2022 Share Posted August 27, 2022 tbh, a big reason I use VS Code is that it supports a keymapping from an editor that I imprinted on long ago, has an Ada extension, and is free. Quote Link to comment Share on other sites More sharing options...
scottinNH Posted September 16, 2022 Share Posted September 16, 2022 I setup VSCode for CC65 and regular GCC, on Windows. I've also setup the same but using DevContainers. And I've setup CC65+gcc on macOS. Totally not an expert tho... I have it so I can just Shift-comand-b to run the default build for the project. I have to say the editor is real easy to start using, but if you want to customize it be prepared to RTFM and Google. That's equally true of any big IDE (and smaller ones w/ fewer options will always be less setup). I don't have any problem switching between these workflows because I start them by running command "code ." in the respective project. VS Code then picks up the way I previously configured it for "that" project... Quote Link to comment Share on other sites More sharing options...
