Tursi Posted October 6, 2022 Share Posted October 6, 2022 On 10/4/2022 at 9:35 AM, TheBF said: vi99 Tip Due the clever design of Classic99 you can bring text files from vi99 to your PC with: :w clip Then pasted the windows clipboard to wherever you want it. Remember you can also write directly to text files... DSK1.?W.FILENAME.TXT will create a Windows text file so long as DSK1 is a FIAD folder. The .txt extension is important if you want Classic99 to read it back, but the ?W forces the mode. Admittedly I often use clip to notepad too, but there are cases where direct may be faster 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 22, 2022 Author Share Posted December 22, 2022 My apologies for the long time to fix this. I get distracted easily by things that peak my interest like almost everything. I found a serious problem with some of the routines in the previous version. In some conditions I was saving the cursor shape on the return stack so it could be changed for the new editing mode. If you exited normally the cursor was popped and all was well. But in my cleverness I provided a fast exit out if there was an error condition, but didn't cleanup the cursor character. Oopsie! This editor also is shift for me in that the VDP screen is the actual text editing buffer. (my choice) It means that I don't have to copy anything to the text save buffer in memory until you complete editing a line. That's is foreign to me from other editors I have written and so I found a case where I was trying to do both at the same time when pasting a line from clip buffer. I think this version is more reliable now. It has an ls-l command now so you can see file types and sector sizes. ls and ls-l default to the start up DSK which is retained in HOME$. I have not made a non-Forth syntax way to change HOME$ yet. If you really want to changed it use: (mind all the spaces and upper "caseness") S" DSK2." HOME$ PLACE Merry Christmas to anyone who is trying to use vi99 and special thanks to @dhe who seems to be the biggest fan of VI99. Things I can improve: Screen refresh is line by line a so very ugly make vi command use HOME$ as default path (should that be done?) Load editor into low ram leaving ~15K for text buffer (currently only 8K) Add more commands Which ones do you miss the most? I hope I didn't break more that I fixed... VI9980-1.41.ZIP 4 Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted December 22, 2022 Share Posted December 22, 2022 (edited) That’s some nice progress there, I like the use of $HOME and the ls command. Have the same feeling with my progress on Stevie. It has been slow due to changes at work and writing Stevie in assembly sure doesn’t help. But am also to release a new version in the next days (better menu system, goto line functionality, "uncrunch" TI Basic program + small changes) Thinking about it, I might steal the idea with the environment variables for a future version. Hope you don’t mind 😃 Also thought about integrating a forth interpreter and do some of the “high-level” stuff there. But that would really be a long-term goal. If I may make a suggestion, and it’s not directly an editor thing. But perhaps you could add the capability to load a FG99 cartridge from inside the editor. That way you can jump there from the editor. (that something I’m working on in stevie as well, but not for this release). With SAMS in place I can even return from a cartridge to Stevie and resume work in the editor without loading anything in memory, because it’s all just there. You just have to make sure that you switch SAMS pages upon program exit and switch them back in when you resume work) Edited December 22, 2022 by retroclouds 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted December 22, 2022 Author Share Posted December 22, 2022 6 hours ago, retroclouds said: That’s some nice progress there, I like the use of $HOME and the ls command. Have the same feeling with my progress on Stevie. It has been slow due to changes at work and writing Stevie in assembly sure doesn’t help. But am also to release a new version in the next days (better menu system, goto line functionality, "uncrunch" TI Basic program + small changes) Thinking about it, I might steal the idea with the environment variables for a future version. Hope you don’t mind 😃 Also thought about integrating a forth interpreter and do some of the “high-level” stuff there. But that would really be a long-term goal. If I may make a suggestion, and it’s not directly an editor thing. But perhaps you could add the capability to load a FG99 cartridge from inside the editor. That way you can jump there from the editor. (that something I’m working on in stevie as well, but not for this release). With SAMS in place I can even return from a cartridge to Stevie and resume work in the editor without loading anything in memory, because it’s all just there. You just have to make sure that you switch SAMS pages upon program exit and switch them back in when you resume work) Thanks for the encouragement. You can use any idea from my code that suits your needs. It's all public domain as far as I'm concerned. I added on variable for convenience and now realize I should read an init file on startup to allow personalizing. This a case where having the interpreter embedded makes it much simpler. These are good suggestions. This version of vi99 is expansion RAM only. I have some preliminary code that can swap out the entire memory map into SAMS so that sounds like what you are talking about. I will need some "personal" development to understand using FG99. I should probably buy one first. When that time comes I will reach out to learn what you are doing. 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted January 6 Author Share Posted January 6 I have been noodling on this vi99 editor over the holidays. This thing is a very deep rabbit hole!. I will never be able to emulate all the stuff that vi does but I got a bit closer. I figured out how to add the numeric argument to the system so you can do commands like 5dd and delete 5 lines, or d4w to delete 4 words. Still need to add that to the y command to copy lines. It's not a speed demon doing this, but it is working. There is also a limit at the moment of about 90 lines in the current clipboard buffer in VDP RAM because it is a fixed record size system so I will have to fix that with a different data structure. Also because there is only one clipboard buffer I had to add a ^K command to "kill" the buffer contents when you need to. No standard vi. Sorry. The number of lines in clipboard is also displayed on the bottom line. I keep breaking the sacred tradition. Such heresy. I decided to patch the Forth repl with a different loop that looks more like a linux prompt that shows the current path. And now you don't need to use the disk number with the file name. The current path is pre-pended to the filename if you don't add a dsk?. in the text. New commands view <filename> lets you look at files in read only mode cd "change disk" -R sets read only mode. BUT it is a Forth word so it goes before the vi command. -M sets modify mode. Same rule as -R. ^Z exit editor to the shell Fixed commands G goes to end of file 9G goes to line 9 I posted a quick video of what it looks like now. I hope to get a new version of the program on here soon. 5 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted January 6 Share Posted January 6 Brian this REALLY great! Loving this! 1 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted January 6 Share Posted January 6 Reminds me a bit of the AS/400. That OS prompts for user/ password and has many security levels that are set using"X" to toggle security levels. And on and on.. I spent many a day using. 1 Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted January 6 Share Posted January 6 Awesome work! This is progressing very nicely indeed! I love the fact that the text color changes depending on whether one is in view or edit/insert mode, not to mention the shell feature. The text buffer size limitation is definitely something that will need to be ironed out at some point as 60 lines is not nearly enough for larger projects. By the way how large of a file can the editor handle? Are you making use of the SAMS by any chance? 1 Quote Link to comment Share on other sites More sharing options...
+acadiel Posted January 6 Share Posted January 6 I really, really love the idea of this! As soon as you get a new version, I'll try and get it over to my /4A with F18A. (I need to get off my tail and update my F18A, with 1.9, too..) 1 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted January 6 Author Share Posted January 6 3 hours ago, Vorticon said: Awesome work! This is progressing very nicely indeed! I love the fact that the text color changes depending on whether one is in view or edit/insert mode, not to mention the shell feature. The text buffer size limitation is definitely something that will need to be ironed out at some point as 60 lines is not nearly enough for larger projects. By the way how large of a file can the editor handle? Are you making use of the SAMS by any chance? Thanks. Not using SAMS at the moment so memory is tight. I started this thinking it would be a super tiny editor. Was I wrong. It is now a ~18.K image. The largest file is 8K because I used low RAM for the text. It is kept as byte counted strings, packed end to end, so it's pretty tightly held. Still that would be only ~200 lines of code without many comments. I should be able to do something different in VDP RAM with the clipboard, but I might need a double linked list because I use it like a stack of strings. We shall see. The way the memory is storage is being used in this version will probably have to change if I go to SAMS. I need to do some testing on what happens if every byte read/write goes through virtualization translator. It could be way too slow. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted January 6 Author Share Posted January 6 I forgot mention that I finally have a rudimentary 1 level undo. I think that was all you got with the original vi as well. Just like 1976! It's better than nothing and with a couple more line buffers it could be three levels deep! 5 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted January 24 Author Share Posted January 24 (edited) OK right out of the gate I need to say there are some things that Forth makes so easy and then there are times... I made a lot of changes to the VI99 code and got myself down a rabbit hole or two mostly around keeping track of inserting and deleting counted strings. Fortunately I figured it out or I might have turned to drugs. The copy paste feature now can handle more than the contents of the primary editing buffer using all the VDP RAM from >0C00 up to about >3700 I had to create an pointer stack in High VDP RAM that grows down and holds the text string pointers, that are in low VDP RAM and grow upwards. If you put more than about 8100 bytes of text in the clipboard or there-about, it's going to blow up. You have been warned. Also copying and pasting is pretty glacial. I didn't do any optimizing yet and lines update the screen while shuttling those damned counted strings back and forth. Changes: I also added an rm command with an "Are you sure?" check. It doesn't work on Classic99 but "should" work on real hardware. (let me know. I don't have F18) Added dw (delete word) command and it takes a numeric arg. (does not save the deletion but you get one UNDO) Also all the cursor keys take a numeric argument (ex: 12j moves left 12 chars after the cursor) The default path is set from the boot disk you use. This disk is automatically appended to filenames that have no '.' character. The Zip file contains the 3 binary files. Start the program with DSK?.VI9980 The updated vimanpage file is included so you can see what works now. For the VI fans out there give it a good beat-up and let me know what you would like fixed or improved. I try to find problems but it's hard to catch everything. I also need to ditch the ROM font. Any suggestions for a font that would look better in 80 columns? Source code for the brave hearts among us is here: VI99/src at main · ForthHub/VI99 · GitHub EDIT: My humble apologies. V1.43d has a big bug in the pasting mechanism. Look down the post for the repaired version. Edited January 25 by TheBF Removed the buggy version 3 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted January 24 Author Share Posted January 24 (edited) Deleted duplicate Edited January 24 by TheBF Duplicate entry Quote Link to comment Share on other sites More sharing options...
Tursi Posted January 24 Share Posted January 24 8 hours ago, TheBF said: I also added an rm command with an "Are you sure?" check. It doesn't work on Classic99 but "should" work on real hardware. (let me know. I don't have F18) Remember you can test such things using the TI disk controller emulation. It's only the Classic99 DSR that disables delete. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted January 24 Author Share Posted January 24 1 hour ago, Tursi said: Remember you can test such things using the TI disk controller emulation. It's only the Classic99 DSR that disables delete. Ah yes. I forgot... again. Thanks Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted January 24 Share Posted January 24 10 hours ago, TheBF said: I also need to ditch the ROM font. Any suggestions for a font that would look better in 80 columns? Here are two font possibilities: CHAR@1 CHARA1 The first is from Funnel Web, I think. It has true descenders and a '0' that is clearly different from capital 'O'. It also is 2 KiB in size (256 chars) with the PC box-drawing characters in the upper 128 chars. The second is from TI Writer (Tony Knerr’s @Gazoo’s favorite font)—also with true descenders and a distinct ‘0’, but just 128 chars. The first 6 bytes are E/A-SAVE style, i.e., not part of the font. I have them with those 6 bytes removed (for fbForth) and the last char (127 or 255) fleshed out, if you like. ...lee 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted January 25 Author Share Posted January 25 Well this hobby is nothing if not humbling. V1.43d has big bug pasting long lines of text. This version has fixed that and it also fixes an off by one error on repetitions for cursor movements and dd dw yy commands. VI99-1.43e.ZIP 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted January 25 Author Share Posted January 25 On 1/24/2023 at 9:58 AM, Lee Stewart said: Here are two font possibilities: CHAR@1 2.13 kB · 3 downloads CHARA1 1.13 kB · 4 downloads The first is from Funnel Web, I think. It has true descenders and a '0' that is clearly different from capital 'O'. It also is 2 KiB in size (256 chars) with the PC box-drawing characters in the upper 128 chars. The second is from TI Writer (Tony Knerr’s @Gazoo’s favorite font)—also with true descenders and a distinct ‘0’, but just 128 chars. The first 6 bytes are E/A-SAVE style, i.e., not part of the font. I have them with those 6 bytes removed (for fbForth) and the last char (127 or 255) fleshed out, if you like. ...lee @Lee Stewart I can load this data but my font loader assumes the pattern table is at >800 for ascii char 0. These files seem to make a different assumption because I get random shapes. What is the first character defined in these files? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted January 25 Share Posted January 25 7 hours ago, TheBF said: What is the first character defined in these files? The first character is ASCII 0. If you are doing a DSR LOAD (opcode 5), you would need to load 6 bytes ahead of >0800. That is why I stripped those bytes out for fbForth. Here they are so you can load them at >0800 (or wherever ASCII 0 starts): CHAR@1FBF CHARA1FBF ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted January 26 Author Share Posted January 26 23 minutes ago, Lee Stewart said: The first character is ASCII 0. If you are doing a DSR LOAD (opcode 5), you would need to load 6 bytes ahead of >0800. That is why I stripped those bytes out for fbForth. Here they are so you can load them at >0800 (or wherever ASCII 0 starts): ...lee OK. I didn't understand the implication before. Thanks for the new files. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted January 29 Author Share Posted January 29 So I dug into this project for the last week or so. I went back and forth between VIM on my Mac and VI99 to try and get the features that I have, working like the real thing. I realize that this has been pretty painful for "dyed in the wool" vi users like @dhe so I hope this helps absolve me of my past sins. Part of the problem is that I am not a VI user regularly and I struggle to understand all the features of vi. Also I had so many data structure errors at first that I didn't pay attention to the operational stuff. This version works pretty close to the real thing from what I can tell within the limits of the features supported. (there are still warts) Here is what has been touched or changed: V1.43f Fixed lots of stuff. Improved screen list speed a bit Optimized where screen is re-drawn in the code to speed up deletions and yanks They are very fast on smaller files now 'o' command opens line below cursor 'O' command opens line above the cursor double letter commands are handled better 'dw' waits for the w key properly HOME$ named changed to $HOME (not needed by user) Startup tries to loaded VI99FONT file from the $HOME path VI99FONT is FONT0230 from a resource I found here with some tweeks by me. if VI99FONT is not found you get TI ROM Font like BASIC Added SAVEUNDO to 'a' command 'k' command fixed: does not jump 2 lines at top of screen BACK-SPACE works correctly when editing a line (deletes chars as it goes backwards) ENTER now does line splitting Added 'J' command (upper case J) to join lines Cursor stops at end of file+1 line edit command lets enter vi99 from the shell with the existing file in the buffer G command works as expected in visual mode STK= on the bottom line is a debug line to see what's on the DATA stack. It will go away in future. *Not Quite vi Functions* -------------------------- 'p' command adds text below CURRENT LINE, not at cursor 'P' command adds text above the current line, ^K kills the contents of the clipboard. (VI99 has only the " buffer in vi parlance {I think}) font command loads a font from the shell command line. The default font is called vi99font Lee graciously provided CHARA1FBF and CHAR@1FBF fonts that are in the ZIP file. You can load them but the default cursor is not correct for vi99. (more work) CHAR@1FBF appears similar to VI99FONT Things that I might fix in future The colon command line does not use the same interpreter as the visual mode key interpreter It uses Forth and so is "faking" the key commands that it handles VI99-1.43f.zip 6 1 Quote Link to comment Share on other sites More sharing options...
