soufian Posted September 13, 2022 Share Posted September 13, 2022 the mainboard does not want to connect i tried couple of usb cables i had . i think i need a otg cable ?? Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 13, 2022 Share Posted September 13, 2022 21 minutes ago, soufian said: the mainboard does not want to connect i tried couple of usb cables i had . https://pluscart.firmaplus.de/pico/?assembly BOOT1 on the STM32F407VGT6 breakout board has to be short for flashing and can be short during operation. This can be done with a jumper or by soldering: 21 minutes ago, soufian said: i think i need a otg cable ?? No Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 oh because the guy in the video says you need a usb cable with all the datalines so i thought a otg cable ! he never said anything about connecting those boot 1 or 2 just press the button insert usb cable and it should connect ,wil try out again i flashed it with succes ,installing the pcb i think iam doing something wrong the video is not clear the black board doesnt fit with the sd card board Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 13, 2022 Share Posted September 13, 2022 21 minutes ago, soufian said: oh because the guy in the video says you need a usb cable with all the datalines so i thought a otg cable ! he never said anything about connecting those boot 1 or 2 just press the button insert usb cable and it should connect ,wil try out again i flashed it with succes ,installing the pcb i think iam doing something wrong the video is not clear the black board doesnt fit with the sd card board 21 minutes ago, soufian said: You have to cut down the ESP8266 PINs after soldering for the STM Board to fit in later. I am not familiar with the SD card thing, but I think you have to remove the black plastics spacers before soldering. Maybe @Andrew Davie or @Fierodoug5 can help you out here. Link to comment Share on other sites More sharing options...
+Andrew Davie Posted September 13, 2022 Share Posted September 13, 2022 See in this thread/bottom of page... Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 (edited) i messed up 2 boards already damaged traces 🤣 i think iam going to give up the instruction in the video are not clear at all to me on the second card i made a mistake to install the wifi card first i also bought this wifi flasher thing in case i need to flash the wifi module https://www.aliexpress.com/item/32915870451.html?spm=a2g0o.order_list.0.0.7d2918029GgWvF Edited September 13, 2022 by soufian Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 13, 2022 Share Posted September 13, 2022 24 minutes ago, soufian said: i also bought this wifi flasher thing in case i need to flash the wifi module https://www.aliexpress.com/item/32915870451.html?spm=a2g0o.order_list.0.0.7d2918029GgWvF before soldering anything you should use the flasher and check the firmware version and functions of the ESP8266 see this forum about using the ESplorer: Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 to late already solderd everything in this is the best i can do where do i find the files for the sd card ? Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 iam getting nothing on the screen do i need somekind of extra files on the sd card ? Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 (edited) iam using this firmware on the blackboard atari-2600-pluscart-master inside is a firmware i dont see a menu system or anything what am i missing ? Edited September 13, 2022 by soufian Link to comment Share on other sites More sharing options...
Fierodoug5 Posted September 13, 2022 Share Posted September 13, 2022 If it my video you are referring to, I just checked and I pretty well covered the boot jumpers and clipping the pins of the esp01 after soldering Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 what files do i need for the sd card does the sd card need to be fat32 ? Link to comment Share on other sites More sharing options...
Fierodoug5 Posted September 13, 2022 Share Posted September 13, 2022 You don't need any sd card for the menu to come up. The SD card is fat32 and only needs to contain Atari 2600 roms Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 (edited) i think i flashed the wrong firmware ? can i reflash it ? Edited September 13, 2022 by soufian Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 13, 2022 Share Posted September 13, 2022 55 minutes ago, soufian said: iam getting nothing on the screen do i need somekind of extra files on the sd card ? 55 minutes ago, soufian said: To boot on the 2600 the boot0 jumper has to be set too. https://pluscart.firmaplus.de/pico/?assembly but as far as I can see from the PlusStore logfiles ther has been a new PlusCart connecting from the Netherlands about 20 minutes ago. If this was your PlusCart Duo, then you have the wrong firmware version for the standard PlusCart. You have to flash this firmware here to use the SD card too: Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 where can i find the correct firmware ? Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 13, 2022 Share Posted September 13, 2022 1 minute ago, soufian said: where can i find the correct firmware ? Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 this one ? PlusCartUnified 2021.02.13.zip182.4 kB · 127 downloads Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 13, 2022 Share Posted September 13, 2022 2 minutes ago, soufian said: this one ? PlusCartUnified 2021.02.13.zip182.4 kB · 127 downloads no this one: https://forums.atariage.com/applications/core/interface/file/attachment.php?id=913983 from this post: https://forums.atariage.com/topic/317039-pluscart-sd/?do=findComment&comment=4996990 Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 (edited) oke wil try again .oke its working now but it wont see my sd card ,itf formated fat32 ,can some one share the 3d files for the case thanks Edited September 13, 2022 by soufian Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 13, 2022 Share Posted September 13, 2022 @soufian don't post your device-id. Please delete your first picture with the device-id. Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 i dont know how to delete it 😅 Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 13, 2022 Share Posted September 13, 2022 Just now, soufian said: i dont know how to delete it 😅 @Albert can you delete the picture or give @soufian edit rights for his post Link to comment Share on other sites More sharing options...
soufian Posted September 13, 2022 Author Share Posted September 13, 2022 (edited) i think the picture is gone now thanks for letting me know i have it like this on the sd card Edited September 13, 2022 by soufian Link to comment Share on other sites More sharing options...
+Al_Nafuur Posted September 13, 2022 Share Posted September 13, 2022 24 minutes ago, soufian said: oke wil try again .oke its working now but it wont see my sd card ,itf formated fat32 ,can some one share the 3d files for the case thanks what do you see when you select "SD-Card Content" in the menu? Link to comment Share on other sites More sharing options...
