hueyjones70 Posted September 30, 2022 Share Posted September 30, 2022 Syscheck indicates that my 800XL has a bad dram at location U9. Replacing U9 has no effect. I have replaced every IC on the board and nothing has changed. I believe this indicates a short; if so, where should I start looking. I replaced the socket at U9 and didn't see anything wrong there. Quote Link to comment Share on other sites More sharing options...
Beeblebrox Posted September 30, 2022 Share Posted September 30, 2022 Could be a short but syscheck has been known to throw up false dram errors when other faults are present as far as I recall. I seem to remember a failing rom was causing a bad ram diagnosis at one stage when I was using it. And visa versa. IIRC I replaced the rom and the ram errors no longer showed. It's been a while. Sys check ii is an amazing device and in the past it has saved me many hours whilst troubleshooting. Quote Link to comment Share on other sites More sharing options...
xrbrevin Posted September 30, 2022 Share Posted September 30, 2022 is yours an 800XLF? i think they have diff'rent IC numbers Quote Link to comment Share on other sites More sharing options...
hueyjones70 Posted September 30, 2022 Author Share Posted September 30, 2022 It isn't an XLF, and I changed the ROM, MMU, and every other IC on the PCB. Quote Link to comment Share on other sites More sharing options...
+scorpio_ny Posted October 1, 2022 Share Posted October 1, 2022 Maybe check to make sure that there are no bad connection with memory socket with the PCB? I had a perfectly working 800XL that went bad out of the blue. After two weeks of checking, I discovered that one of the pins of the OS ROM socket had a bad solder joint that may have broke due to the PCB flexing. After a solder reflow, it was back in action. Quote Link to comment Share on other sites More sharing options...
