Retrogamerrhys1 Posted October 20, 2022 Share Posted October 20, 2022 Does anyone have an archive of disassembly's from modern WIPs and completed games they would be willing to share with a new programmer? Quote Link to comment Share on other sites More sharing options...
+Bruce-Robert Pocock Posted October 20, 2022 Share Posted October 20, 2022 I've posted the sources for Grizzards at https://GitHub.com/brpocock/grizzards — but they may not be the most approachable thing, as it's a rather complex game. Always happy to answer any questions, however. 1 Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted October 20, 2022 Share Posted October 20, 2022 Minidig has a bunch of disassemblies. @DEBRO has a bunch of disassemblies on github. I used his disassembly of Kaboom! (on Minidig, not github) to create Kaboom! Deluxe! 1 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted October 20, 2022 Share Posted October 20, 2022 6 hours ago, Retrogamerrhys1 said: Does anyone have an archive of disassembly's from modern WIPs and completed games they would be willing to share with a new programmer? Sure! ICT2 (18).a26 This is the latest version of ICT2, V9. Have fun with it @Retrogamerrhys1! 1 Quote Link to comment Share on other sites More sharing options...
Retrogamerrhys1 Posted October 21, 2022 Author Share Posted October 21, 2022 (edited) 9 hours ago, Ecernosoft said: Sure! ICT2 (18).a26 This is the latest version of ICT2, V9. Have fun with it @Retrogamerrhys1! Do you have the source code for this, because the .a26 is a compiled assembly file? If I'm not mistaken, thanks. Good looking game however not sure what you have to do in it though? Edited October 21, 2022 by Retrogamerrhys1 Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted October 21, 2022 Share Posted October 21, 2022 I can't offer code for games. But for my demos, the full source code is always available. Either as tarballs at https://xayax.net/ or in my git repo at https://git.h8u.de/Atari_2600_Prods. So I don't have any game logic there, but show some nice stuff that you can do with the hardware of the 2600. Quote Link to comment Share on other sites More sharing options...
Arlasoft Posted October 21, 2022 Share Posted October 21, 2022 Source code for my finished games so far: https://github.com/1888games/Stepz-2600 https://github.com/1888games/top Quote Link to comment Share on other sites More sharing options...
LatchKeyKid Posted October 21, 2022 Share Posted October 21, 2022 Good resource to have. As someone just starting out with hacking myself, classic disassemblies are a big help with my limited knowledge base. Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted October 21, 2022 Share Posted October 21, 2022 You might also like to check out my tutorial, Collect, which covers writing a complete 2K game from scratch. Since it's a tutorial I went overboard with the comments, to an extent that you most likely will not see in other source code or disassemblies. Some examples from Collect, everything after a ; is a comment. Comments can occur on lines by themselves, as well as after code. ;=============================================================================== ; Initialize dasm ;=============================================================================== ; Dasm supports a number of processors, this line tells dasm the code ; is for the 6502 CPU. The Atari has a 6507, which is 6502 that's been ; put into a "reduced package". This packaging limits the 6507 to an 8K ; address space and also removes support for external interrupts. PROCESSOR 6502 ; vcs.h contains the standard definitions for TIA and RIOT registers include vcs.h ; macro.h contains commonly used routines which aid in coding include macro.h ;=============================================================================== ; Define RAM Usage ;=============================================================================== ; define a segment for variables ; .U means uninitialized, does not end up in ROM SEG.U VARS ; RAM starts at $80 ORG $80 ; Holds 2 digit score for each player, stored as BCD (Binary Coded Decimal) Score: ds 2 ; stored in $80-81 ; CODING TIP - The : is optional. However, if you remember to include the : ; in all of your labels you can then easily find where ; something is defined by including : in the search. ; Find "Score:" will bring you here, find "Score" will locate ; all places that the variable Score is used. ; Offsets into digit graphic data DigitOnes: ds 2 ; stored in $82-83, DigitOnes = Score, DigitOnes+1 = Score+1 DigitTens: ds 2 ; stored in $84-85, DigitTens = Score, DigitTens+1 = Score+1 ;=============================================================================== ; Define Start of Cartridge ;=============================================================================== ; define a segment for code SEG CODE ; 2K ROM starts at $F800, 4K ROM starts at $F000 ORG $F800 ;=============================================================================== ; PosObject ;---------- ; subroutine for setting the X position of any TIA object ; when called, set the following registers: ; A - holds the X position of the object ; X - holds which object to position ; 0 = player0 ; 1 = player1 ; 2 = missile0 ; 3 = missile1 ; 4 = ball ; the routine will set the coarse X position of the object, as well as the ; fine-tune register that will be used when HMOVE is used. ; ; Note: The X position differs based on the object, for player0 and player1 ; 0 is the leftmost pixel while for missile0, missile1 and ball 1 is ; the leftmost pixel: ; players - X range is 0-159 ; missiles - X range is 1-160 ; ball - X range is 1-160 ; Note: Setting players to double or quad size will affect the position of ; the players. ;=============================================================================== PosObject: sec sta WSYNC DivideLoop sbc #15 ; 2 2 - each time thru this loop takes 5 cycles, which is bcs DivideLoop ; 2 4 - the same amount of time it takes to draw 15 pixels eor #7 ; 2 6 - The EOR & ASL statements convert the remainder asl ; 2 8 - of position/15 to the value needed to fine tune asl ; 2 10 - the X position asl ; 2 12 asl ; 2 14 sta.wx HMP0,X ; 5 19 - store fine tuning of X sta RESP0,X ; 4 23 - set coarse X position of object rts ; 6 29 2 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted October 21, 2022 Share Posted October 21, 2022 (edited) 12 hours ago, Retrogamerrhys1 said: Do you have the source code for this, because the .a26 is a compiled assembly file? If I'm not mistaken, thanks. Good looking game however not sure what you have to do in it though? Lol... I meant to send the source Here it is @Retrogamerrhys1 ICT2 (1).a Edited October 21, 2022 by Ecernosoft Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted October 21, 2022 Share Posted October 21, 2022 7 hours ago, SvOlli said: I can't offer code for games. Sorry to ask... but.... WHY Quote Link to comment Share on other sites More sharing options...
Retrogamerrhys1 Posted October 22, 2022 Author Share Posted October 22, 2022 (edited) 18 hours ago, SpiceWare said: You might also like to check out my tutorial, Collect, which covers writing a complete 2K game from scratch. Since it's a tutorial I went overboard with the comments, to an extent that you most likely will not see in other source code or disassemblies. Some examples from Collect, everything after a ; is a comment. Comments can occur on lines by themselves, as well as after code. Thanks for your tutorial, it really helps me as a beginner, 14 hours ago, Ecernosoft said: Sorry to ask... but.... WHY I guess its because he wants to keep his source a secret as in Intellectual Copyrights, it would be nice if coders revealed the game logic in their games but people have the right not to share what they make. Edited October 22, 2022 by Retrogamerrhys1 1 Quote Link to comment Share on other sites More sharing options...
Retrogamerrhys1 Posted October 22, 2022 Author Share Posted October 22, 2022 14 hours ago, Ecernosoft said: Lol... I meant to send the source Here it is @Retrogamerrhys1 ICT2 (1).a 45.79 kB · 1 download Thanks for the source code. Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted October 22, 2022 Share Posted October 22, 2022 37 minutes ago, Retrogamerrhys1 said: Thanks for your tutorial, it really helps me as a beginner, I guess its because he wants to keep his source a secret as in Intellectual Copyrights, it would be nice if coders revealed the game logic in their games but people have the right not to share what they make. Yeah.............. true. Quote Link to comment Share on other sites More sharing options...
+splendidnut Posted October 22, 2022 Share Posted October 22, 2022 I've always been on the fence about sharing source code. For me, it's not about keeping secrets, but of providing something of HIGH value that's useful to others that they can learn from. Most source code just isn't commented / documented enough to really be useful. This is mostly because the developer/programmer has a lot of information in their head about the program that just isn't written down. I think the best source of information for someone who is new to Atari programming are the tutorials available here. If you have questions about game logic, then the best thing to do is ASK. People are more than willing to answer questions. If enough people ask, maybe someone will write up a tutorial about it. 1 Quote Link to comment Share on other sites More sharing options...
LatchKeyKid Posted October 22, 2022 Share Posted October 22, 2022 19 hours ago, SpiceWare said: You might also like to check out my tutorial, Collect, which covers writing a complete 2K game from scratch. Since it's a tutorial I went overboard with the comments, to an extent that you most likely will not see in other source code or disassemblies. Thanks! I'll take a look. Are the modules mostly plug and play for coding and work with each other? Quote Link to comment Share on other sites More sharing options...
+SpiceWare Posted October 22, 2022 Share Posted October 22, 2022 1 hour ago, LatchKeyKid said: Are the modules mostly plug and play for coding and work with each other? There are some subroutines, like the PosObject shown above and the sound effect routines in sfx.asm, that can be used as-is in other programs. Other routines, like the Kernel for drawing the visible screen and ProcessJoystick for player actions, tend to be game specific. You can use what's there as a starting point, but more likely than not will be making extensive changes to those routines for your game. 1 Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted October 22, 2022 Share Posted October 22, 2022 (edited) 5 hours ago, splendidnut said: I've always been on the fence about sharing source code. For me, it's not about keeping secrets, but of providing something of HIGH value that's useful to others that they can learn from. Most source code just isn't commented / documented enough to really be useful. This is mostly because the developer/programmer has a lot of information in their head about the program that just isn't written down. I think the best source of information for someone who is new to Atari programming are the tutorials available here. If you have questions about game logic, then the best thing to do is ASK. People are more than willing to answer questions. If enough people ask, maybe someone will write up a tutorial about it. Yeah.... You are right. And my source code isn't the best to use. Not only do I use ILLEGAL opcodes (LAX, SAX) in my source, as well as special techniques (Replacing lda VALUE and #$80 beq/bne LOCATION with lda VALUE bpl/bmi LOCATION and other things) to save ROM space, but sometimes I also use "random" label names. (Those are usually something going on at that time) When I don't really need an important name for a label (Or I barely ever use it) then I don't give it a super-descriptive name of WHY that label exists. Edit: I honestly don't know why I do that, but I'm weird like that. If you ever need me to, I can make a more newbie-friendly source for my games. Then again, there is a point where there are SO MANY COMMENTS that it just gets messy. Some of the 8bitworkshop sample programs suffer from this. Edited October 22, 2022 by Ecernosoft Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted October 23, 2022 Share Posted October 23, 2022 (edited) On 10/20/2022 at 10:50 AM, Retrogamerrhys1 said: Does anyone have an archive of disassembly's from modern WIPs and completed games they would be willing to share with a new programmer? Disassemblies, or source code? Disassembly is what someone who wants to know how it works comes up with. Source code is what the developer used. By "new programmer" I guess you mean the latter? Edited October 23, 2022 by ChildOfCv Quote Link to comment Share on other sites More sharing options...
Retrogamerrhys1 Posted October 23, 2022 Author Share Posted October 23, 2022 Yeah, I mean source code I think? Although I have come across disassemblies from archives which seem to offer what I want, a breakdown of the program. Quote Link to comment Share on other sites More sharing options...
Arlasoft Posted October 23, 2022 Share Posted October 23, 2022 28 minutes ago, Retrogamerrhys1 said: Yeah, I mean source code I think? Although I have come across disassemblies from archives which seem to offer what I want, a breakdown of the program. A raw disassembly wouldn't be much use, you can get this for any game using Stella in any case. The ones with comments, labels, constants etc have been reversed engineered to the point where it could be considered as good as having the original source code, probably better because back in the day they didn't have the space or time to put extensive comments. So there's a big difference between 'commented disassembly' and 'disassembly'. Quote Link to comment Share on other sites More sharing options...
Retrogamerrhys1 Posted October 23, 2022 Author Share Posted October 23, 2022 Yeah I mean commented disassembly Quote Link to comment Share on other sites More sharing options...
LatchKeyKid Posted October 23, 2022 Share Posted October 23, 2022 I recently saw there is a program called NESmaker that seems like making an NES game out of plug and play chunks (kind of like "hacking" in this scene). https://www.thenew8bitheroes.com/ Obviously this is not the best way to learn to code but for those just trying to make a functional game it might work. I messaged them about possibly making a 2600 plugin but it's not on the menu unfortunately. Quote Link to comment Share on other sites More sharing options...
Ecernosoft Posted October 23, 2022 Share Posted October 23, 2022 (edited) 6 hours ago, Retrogamerrhys1 said: Yeah I mean commented disassembly Commented dissasembly = Source code (Or similar) Edited October 23, 2022 by Ecernosoft Quote Link to comment Share on other sites More sharing options...
+SvOlli Posted October 26, 2022 Share Posted October 26, 2022 (edited) On 10/21/2022 at 10:55 PM, Ecernosoft said: Sorry to ask... but.... WHY I never coded a game. Just demos. Edited October 26, 2022 by SvOlli Quote Link to comment Share on other sites More sharing options...
