+Philsan Posted December 5, 2022 Share Posted December 5, 2022 How would you move a sprite representing a pointer/cursor with acceleration? This is my classic code but the cursor is too fast. At first it should move slowly then accelerate. proc READ_JOYSTICK j=stick(0) if (J & 8) = 0 then x0 = x0 + 1 if (J & 4) = 0 then x0 = x0 - 1 if (J & 2) = 0 then y0 = y0 + 1 if (J & 1) = 0 then y0 = y0 - 1 endproc proc CHECK_BOUNDARIES if x0>203 then x0=203 if x0<44 then x0=44 if y0>230 then y0=230 if y0<8 then y0=8 endproc proc MOVE_SPRITES poke 53248,x0 move adr(Player0),pmbp0+y0,18 endproc Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted December 5, 2022 Share Posted December 5, 2022 I think you would need to read the joystick value, store it, on the next read, see if it's the same value maybe set a counter so you can accelerate movement if same direction for "n" reads. I did something similar in an Art program I wrote in BASIC many moons ago, will see if I can find it, it moves a sprite pointer based on joystick reads too 2 Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted December 5, 2022 Share Posted December 5, 2022 2 hours ago, Philsan said: This is my classic code but the cursor is too fast. At first it should move slowly then accelerate. You can just apply some kind of pause, put into the function "READ_JOYSTICK". If the stick isn't moved at all (=15) set the duration of the pause to a high value, else reduce the value as long as you think it's enough. This way you can also move the object fast arround, as long there is only a transition, not a break, in movement. 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted December 6, 2022 Share Posted December 6, 2022 14 hours ago, TGB1718 said: I did something similar in an Art program I wrote in BASIC many moons ago I found the program, but I was mistaken, there are 3 speeds of cursor movement, but by manually selecting them via the keyboard. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted December 6, 2022 Share Posted December 6, 2022 18 hours ago, Philsan said: How would you move a sprite representing a pointer/cursor with acceleration? Quite often you can use a co-ordinate range larger than that of the screen, e.g. x4, and then quick divide to put in range when you want to draw. Then you use a 'velocity' variable, i.e. 0 is stationary. When you detect movement, increment this and then set a countdown delay (e.g. # of vb cycles). So the increment can work only if the delay is zero and less than the cap, e.g. 4. Then each vb you can add the velocity to x,y coordinates, so you have one velocity each for up/down, left/right and hence negative for up/left. You then have the option of ceasing movement (joystick centred) either resetting the velocities to zero (immediate stop) or use the vb to move the velocity toward zero based on another counter to provide deceleration. 2 Quote Link to comment Share on other sites More sharing options...
