Wii U Hard Drive Recommendations
mdoerty
I just discovered that the hard drive that I have had hooked up to my Wii U since launch is no longer being recognized.  This has occurred in the last two months.  And since it does not appear when I plug it into my computer, I am guessing it is toast.
Obviously, I need to get a new unit.
What recommendations do people have for a drive since the models Nintendo recommended years ago no longer exist.
Thanks
  • 2 weeks later...
I use a 500GB 2,5" HD I had from a notebook upgrade in a "generic" enclosure, attached to the rear USB ports with a Y-cable. Works fine so far and only very occasionally needs to be re-plugged.
My absolute preference would be a USB SSD that does not need the Y cable but all the ones I had around failed to work without the Y cable.
  • 4 weeks later...
I've used the same Toshiba HDD hooked up with a Y cable to the USB ports on the back and it works perfectly! I would LOVE to go SSD on it and see if it will load any faster...
I bought an SD card to try with a USB reader, but haven't tried it out yet.
Nintendo's official FAQ says not to use SD, but they don't say why. Every other console of theirs reads/writes SD... *shrug*
With the eShop going down, I'm going to have to try it real soon... ¬_¬
It's not going down soon. Purchasing is ending in March, but the shop is staying for now with no shutdown announced.
I have stuff I still need to purchase, but currently not enough internal space to do so.
That's what I mean. The store isn't disappearing anytime very soon for redownloading purchases. Only purchasing games is ending.
So you can make your purchases now and worry about long-term storage later on, if your solution doesn't work and you don't purchase an external drive before March.
  • 1 month later...
I think I need to get another thumb drive.
I tried using a Switch branded SD card with the WiiU...it formats it, then reports it as being 2000 something gigs (it is not), and it tries to copy files over and fails.
Popped it in the Switch and it formatted it and it worked just fine =|
Popped it back in the WiiU and still no dice.
It's a moot point now for you, but just in case it helps someone else, once again you actually didn't need to wait to figure out a storage solution before buying the games you wanted. What's ending in late March with the Wii U and 3DS eShops is purchasing, not the downloading of past purchases. You could've worried about downloading your purchases after March without an issue.
For an illustration, I bought what's likely my last round of 3DS downloads last night. They ended up way too much to fit on the factory installed SD card on the system (I believe it's a 4 GB micro SD card on a New 2DS XL). Yet I was able to buy all 11 of my games just the same. And while there needs to be enough room to download a purchase or the Wii U or 3DS eShop won't allow you to even buy it, all I had to do was keep the download queue cleared to maintain enough free SD card space for each purchase
The 1,000 blocks reserved for the first game that I purchased for instance might've prevented the next game that's 1,500 blocks in size (the 3DS doesn't measure download sizes in MB's) from being allowed to be purchased if I only had 750 blocks left free. But by cancelling that download of my first purchase, I cleared that 1,000 block reservation and freed up enough space to let me buy my next game. Rinse and repeat until finished.
I have some downloading to do when I upgrade to a larger card, but that doesn't have to happen by this deadline if I don't get around to it since the eShop is sticking around for the redownloading of past purchases. And now with all the games that I wanted purchased and tied to my account, I can download them at my leisure to my 3DS with no imminent deadline to beat.
Edited by Atariboy
So, what you're telling me, is that I DID need more free space in order to make a purchase... :ponder:
You need enough free space for the biggest game of the bunch that you plan to purchase, yes. But it's entirely optional to have enough free space to accommodate every single thing that you already owned and all your newly made purchases when all is said and done.
You've came up with your solution so this is all unimportant for you personally now, but just in case it helps someone else that waits until closer to the deadline that may read this thread, let's use my 3DS example again. Let's say that I have 40,000 blocks of space in total on my SD card and 39,000 blocks are occupied by previous downloadable games and such that I've acquired through the years. And the largest game size that I'm planning on purchasing takes 1,500 blocks. I can't actually buy that game as-is since I lack the space on my SD card with a 500 block deficit and thus the eShop won't let me purchase it. But now it's a trivial matter of simply deleting an existing download of at least 500 blocks in size to clear that room.
Now I can buy my 1,500 block game and as I long as I then clear the download queue after that purchase to clear the 1,500 block reservation that the download made, I can rinse and repeat this process as needed until I'm finished. Then it's a simple matter of acquiring a bigger SD card later on, transferring my existing SD contents to it, and then downloading all my recent purchases that are now in my purchase history to my new memory card (as well as remembering to redownload the 500 block game that I already owned but had temporarily deleted to clear some room).
Thanks to the eShop not actually closing this month (Only purchasing is getting disabled), there's not actually a need to rush to come up with a final storage solution. For instance if your USB thumb drive dies down the road (Nintendo actually recommends against using them for Wii U game storage), as long as the eShop is still online you'll be able to retrieve all your downloads.
Edited by Atariboy
4 hours ago, Atariboy said:
For instance if your USB thumb drive dies down the road (Nintendo actually recommends against using them for Wii U game storage)...
And I don't know why they do, because it's essentially the same technology that the internal storage is using. Ditto to the Switch.
Wii U software supposedly wasn't designed with flash memory wear out awareness and is heavy on disk I/O read/writing.
I personally think that it's fine for how I use it. Small programs like Virtual Console downloads that are load everything into RAM when starting a game and only writing back when something like a save state is made, storing rarely played games, etc.
While I intend to do something more proper down the road, a USB thumb drive has been a cost effective stopgap that has served well enough for several years. But with what I've learned, I'd personally avoid something like playing my download of Wind Waker HD directly off it from start to finish before transferring it to the system's internal storage.
Edited by Atariboy
I've been using a cheapo portable drive I got off Amazon (a Bipra or something like that).  I have all my discs backed up to and it works great.  I even played Xenoblade Chronicles X to 100% completion from it (about 180 or so hours) and had no troubles even though I left it on for 20 hours+ at times.  If that's not a stress test then I don't know what is.
