E474 Posted February 23 Share Posted February 23 Hi @mozzwald, Thanks very much for your reply, the errors in the tnfsd.service file were causing the problem. When I changed them, I could start up the server correctly, and it would happily serve images to the FujiNet-PC: pi@pi3bp2:~ $ more /etc/systemd/system/tnfsd.service [Unit] Description=TNFS Server After=remote-fs.target After=syslog.target [Service] User=root Group=root ExecStart=/usr/local/sbin/tnfsd /tnfs -c tnfs [Install] WantedBy=multi-user.target I had to do a little bit more than just a systemctl start: pi@pi3bp2:~ $ sudo vi /etc/systemd/system/tnfsd.service pi@pi3bp2:~ $ sudo systemctl start tnfsd Warning: The unit file, source configuration file or drop-ins of tnfsd.service changed on disk. Run 'systemctl daemon-reload' to reload units. pi@pi3bp2:~ $ sudo systemctl daemon-reload pi@pi3bp2:~ $ sudo systemctl start tnfsd pi@pi3bp2:~ $ sudo systemctl status tnfsd ● tnfsd.service - TNFS Server Loaded: loaded (/etc/systemd/system/tnfsd.service; enabled; vendor preset: enabled) Active: active (running) since Thu 2023-02-23 13:07:40 WET; 9s ago Main PID: 31946 (tnfsd) Tasks: 1 (limit: 1596) CPU: 8ms CGroup: /system.slice/tnfsd.service └─31946 /usr/local/sbin/tnfsd /tnfs -c tnfs Feb 23 13:07:40 pi3bp2 systemd[1]: Started TNFS Server. Feb 23 13:07:40 pi3bp2 tnfsd[31946]: Starting tnfsd version 23.0207.1 using root directory "/tnfs" But everything works correctly now! 1 Quote Link to comment Share on other sites More sharing options...
