Hyperkin Retron 5 power supply….
homerj
I have a center positive 5v 3a that should do the trick. It's the same size as a Sega Genesis model 1, jaguar, etc. With the power brick unplugged, check to see if one of those fit if you have one. They're the wrong voltage but the same size as this power brick.
Send me a PM if you still need this.
7 hours ago, homerj said:
I’ve got a Genesis 1 & Jag.  I’ll check them tonight.  A local guy said he thought he had an OEM power supply but i haven’t heard back from him.
OEM for the retron? Because make sure you don't plug The Gen of Jag supply in while they're powered You will for sure fry it. I only want to know if it's the same size.
